Capristo sound stage Vote.. You deccciiddee | Page 2 | FerrariChat
Discussion in '348/355' started by Harrydino, May 11, 2013.
  1. Extreme
    Extreme F1 Rookie
    May 26, 2010
    2,515
    Northern Utah
    Erick
    I had the stage 3 and loved it. Wasn't overly loud before the valve opens but when the valve opens the angels screeeeeeeeam... :)
  2. Harrydino
    Harrydino Karting
    Apr 9, 2013
    206
    London
    Harry
    Stage 3 def winning!! Ill be making my decision Wednesday! Youuu decideeee
  3. F355 Spyder
    F355 Spyder Rookie
    Sep 15, 2012
    28
    Toronto,Ontario
    Mine is only 6 months old.
    I personally wish it was louder.
    Loud pipes save lives is the old saying from my motorcycle days.
    In town I am not pushing the car so it's no problem.
    My next exhaust project will be to install hyper flow cats.
    You will love the capristo 3 on a 355!
  4. Harrydino
    Harrydino Karting
    Apr 9, 2013
    206
    London
    Harry
    I'm certainly swaying towards the 3
  5. junglistluder
    junglistluder F1 Rookie
    Mar 23, 2007
    3,610
    VA
    Brendan
    I have the Stage 2 on mine and love it, but would trade for a Stage 3. I wouldn't pay additional money to switch however.
    (the change from Tubi to Capristo was the best mod ever! :))
  6. Subarubrat
    Subarubrat Formula 3
    Apr 1, 2009
    2,072
    VA
    Scott
    I just wish there was a 4.
  7. Harrydino
    Harrydino Karting
    Apr 9, 2013
    206
    London
    Harry
    Stage 3 is dominating this vote
  8. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,834
    Richmond
    Pete
    They're all the same on bypass, the stage is just the sound level when running with the valve closed. I had a level 2 on my GTB and it was similar to stock in normal driving, maybe a bit louder but not too bad and much louder on bypass (as they all are). I traded it for a set of challenge rims as I don't see much point to being loud for the sake of being loud. It did save a little weight.
    For $4k I'd just build my own with a couple hundred dollars worth of (thin wall) SS pipe and a dual inlet/outlet muffler.
  9. junglistluder
    Mar 23, 2007
    3,610
    VA
    Brendan
    You actually need a triple inlet/dual outlet muffler unless you want to install custom/360 headers without the bypass pipe. And don't forget $1k for a welder! :)
  10. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,834
    Richmond
    Pete
    I was thinking straight pipe for the bypass (similar to the Capristo). Dual inlet/outlet for the primary out of one set of tails and then straight pipe out of the valve to the other set.
  11. J. Salmon
    J. Salmon F1 Rookie
    4,367
    VA
    Just got back from 1300 mile trip with my GTS, I have a 1. High way cruising is still reasonable. With the top off, the 1 is loud enough. What I REALLY want is a 1 that converts to a 3 with a button.
  12. Subarubrat
    Apr 1, 2009
    2,072
    VA
    Scott
    Charlie Hawkins likes this.
  13. ShineKen
    ShineKen F1 World Champ
    19,420
    Southern California
    Nostradamus
    Anyone know the weight of the Capristo systems?
    Ken
  14. Harrydino
    Harrydino Karting
    Apr 9, 2013
    206
    London
    Harry
    Sounds awesome where did you go on ur trip?
    Not sure on the weight, I know there def lighter
  15. brettb
    brettb Karting
    Jan 13, 2011
    57
    Can anyone confirm that the capristo on bypass is just a straight pipe, or is there some magic baby primary muffler that gives it that sound?
    Because if it is just a straight pipe, getting that sound from a custom made (and cheaper) muffler is much more cost effective!
    I have read before that the primary and bypass Gasses should never be mixed (this is also why the capristo is highly rated) because older Tubis and the OEM mufflers apparently mix the gases of the two in the muffler on bypass and this creates back pressure that creates more problems for an already heat stressed (because of cats) OEM header.
    Effectively, bobzdars hit the nail on the head in my book.
    If the Cappy does not have any hidden magic in their primary section?
  16. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,834
    Richmond
    Pete
    You'd have to cut it open to be sure. Somebody can just put their hand on one set of the tailpipes and let you know if gas comes out of one set or both at idle and you'll know if there are 2 separate paths. I believe I did this at one time but I have no recollection of the results, sorry.
    I do know that they use thinner gauge metal than the stock stuff which can definitely have an impact on the sound, especially if it's essentially a straight pipe on bypass. At some point I'm going to put together a track setup with just a muffler on the primary side and straight through on bypass. I have a feeling the length of the pipes could be a factor as well. I plan to use pieces that are clamped together instead of welded - at least at first - so I can change routing/length to see what happens. I also may leave the bypass clamped so I can swap in/out a muffler(s) on that path for street driving without having to swap the whole system, we'll see.
  17. Subarubrat
    Apr 1, 2009
    2,072
    VA
    Scott
    I never ran a borescope down mine, but I think it does have something to form that sound. is is a chamber, magic tube size, I don't know. But I ran a challenge exhaust on my 99 355F1 for a short while and it sounded nothing like the capristo on bypass. The challenge exhaust was just four tubes with sort of a bump out on the non bypass tubes.
  18. Harrydino
    Harrydino Karting
    Apr 9, 2013
    206
    London
    Harry
    Thanks for all the comments everyone. I've decided to go for a stage 3 generation 1! Hopefully have it fittin in 3 weeks :)
  19. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,007
    Indio Ca/ Alberta
    Grant
    I just installed a three six months ago and there's another benefit to the three with two bypass valves and that. Is that it does not seem to burn the stock headers out as quickly. Some say it doesn't at all, but I am not convinced yet. I also find its louder at idle than stock but not much louder when driving until bypasses start to open.
  20. zoowho2
    zoowho2 Formula Junior
    Oct 29, 2012
    269
    Arizona, USA
    Tom
    Loud pipe Harley riders?
    Some think a Ferrari sounds like a jap car
    Some love the sound of any revving motor
    Some don't think at all
  21. tf308
    tf308 Formula 3
    Dec 14, 2003
    1,168
    Virginia Beach
    Tim
    Thank you....I love the sound of Ferraris....but I HATE the Harley. Sounds like a giant mistuned fart.
  22. nostra
    nostra Rookie
    Oct 30, 2012
    30
    Munich / Germany
    Max
    I have a stage 3 since some months and I begin to hate it. It drones from 1500-3000 rpm like hell. With open flaps it is not driveable and even with closed ones it is way to loud to drive it in a city whit not getting the police attention.
    I will try to exchange it against 2 or 1...
  23. Charlie Hawkins
    Feb 1, 2019
    31
    Laguna Beach, CA
    Charlie Hawkins
    @nostra , An off topic question if you will? I see you are in Germany. Are the prices on F355 Spiders and 360 Spiders higher in Europe than in the USA?
    If so how much higher (or lower)?
