360 - Cat failure? | FerrariChat
360 Cat failure?
Discussion in '360/430' started by FerRrari, Jul 21, 2020.
  1. FerRrari
    FerRrari Formula 3
    Jan 11, 2009
    1,173
    WA
    Fernando
    Had my car at the track last week and SLOW DOWN light came on the front straight so the car went into limp mode. A tech from the dealer diagnosed on site as the cat overheating. This is the second time in 12 months the car goes into limp mode. How concerned should I be with the cats failing? The dealer mentioned Ferrari is not supplying one of the sides, and there's a 200 cell Tubi options. Anyone replaced their cats recently?
    74dino246gts likes this.
  2. Skidkid
    Skidkid F1 Veteran
    8,762
    Campbell, CA
    John Zornes
    The cat ecu is pretty notorious for failing so I would start there. It causes the slow down even when the cat isn't overheated; It can throw a slow down shortly after startup too. Did you use a temp gun on the cat? If so what temp was it?
    SpencerMarks and EastMemphis like this.
  3. FerRrari
    FerRrari Formula 3
    Jan 11, 2009
    1,173
    WA
    Fernando
    No temp was measured for the cat as we were at the track. I'll ask if it happens again. Is there no concern with the cats being 17 years old? What's the lifetime of the component?
  4. rotaryrocket7
    rotaryrocket7 Formula Junior
    Dec 7, 2011
    597
    Eden Prairie, MN
    Matt
    buy a temp measurement gun (very cheap these days) and shoot the cat next time it happens. Usually if it's bad it'd be glowing red. As noted above the ECU's that measure the temp as simple and fail. They're easy to get to and exchange, but confirm issue before you do anything. 200 cell cats will work fine, however you may end up with 0420/0421 error codes suggesting your cats aren't effectively filtering...
    FerRrari likes this.
  5. Skidkid
    Skidkid F1 Veteran
    8,762
    Campbell, CA
    John Zornes
    And no, no concern that the cat is 17 years old.
  6. FerRrari
    FerRrari Formula 3
    Jan 11, 2009
    1,173
    WA
    Fernando
    I don't think the cat was glowing red, so maybe it's just the ECU. I'll take it to the dealer for further diagnosis.
  7. 24000rpm
    24000rpm F1 Rookie
    buy a new cat ecu and replacing it with a new one(15 min job) is less expensive than a dealer diagnostic I believe?
    one4torque and Skidkid like this.
  8. JJ
    JJ F1 World Champ
    Jan 6, 2010
    11,357
    PA
    FerRrari and TheRealFlyingBear like this.
  9. TheRealFlyingBear
    Apr 27, 2020
    152
    SF Bay Area
    Ken
    Sorry Fernando about your cat. Not sure why they self destruct like that.
  10. RedTaxi
    RedTaxi F1 Rookie
    3,256
    New Zealand
    Glen
    Pretty sure cats are a service item in the manual. Will check when the are "supposed" to be replaced. But as above ^^^ an old cat may not be at it's best.
  11. FerRrari
    FerRrari Formula 3
    Jan 11, 2009
    1,173
    WA
    Fernando
  12. FerRrari
    FerRrari Formula 3
    Jan 11, 2009
    1,173
    WA
    Fernando
    LOL I'm a dog person myself :)
  13. BrettC
    BrettC Formula 3
    Aug 13, 2012
    1,978
    Calif
    Brett
    It can also be the thermocoupler's associated with the ecu's. Replace them all and the problem should stop or wait till it show's "slow down" again. Mine was showing slow down at start up so I knew it wasn't the cats.
  14. 24000rpm
    24000rpm F1 Rookie
  15. Skidkid
    Skidkid F1 Veteran
    8,762
    Campbell, CA
    John Zornes
    Possible but this is rarely the problem. Start with the simple stuff. Thermocouples are basically bimetal contacts in a sheath so not much to fail there.
  16. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,646
    Silicon Valley
    Most likely the cat ECUs but get a $35 infrared thermometer to be sure the cats are not actually overheating.
    one4torque likes this.
  17. one4torque
    one4torque F1 Veteran
    5,123
    Houston
    One4torque
    This particular cel is one of many 360 issues that can be diy for low $.... or can be farmed out for big $$$$$.
    Amazing spread between new oem bits and serviceable used or am items.
  18. wbt
    wbt Karting
    Nov 28, 2014
    231
    New Zealand
    Wayne
    Thermocouples are easily checked with a multi meter. Just set to continuity or resistance check, if the two pins don't measure close to zero ohms or continuity it's failed. They are a very simple device. Cat ECU info available at www.technistrada.com
    Skidkid likes this.
  19. Skidkid
    Skidkid F1 Veteran
    8,762
    Campbell, CA
    John Zornes
    Correct! Also check from the leads to the case, that should be an open.
