CEL flashing, then gone? | FerrariChat
Discussion in '360/430' started by bauer19f430, Jun 7, 2022.
  1. bauer19f430
    bauer19f430 Rookie
    Jun 7, 2022
    3
    Trevor
    #1 bauer19f430, Jun 7, 2022
    07 F430 with about 26k miles, new owner
    Had the CEL flash temporarily--slight panic attack, it went like this:
    downshifted from 3rd to 2nd at around 25mph
    right turn onto the street
    CEL starts flashing
    car sounded a little off
    CEL disappeared 4 seconds later
    everything sounded fine
    Car drove completely normal the rest of 4 mile drive home. Smooth, temps all normal
    Seemed and sounded fine under a brief acceleration
    The gas is pretty low (2 bars)
    Was thinking that could be it?
    I am going to get an OBD scanner to check it out, but it freaked me out a little bit
  2. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    how old is your battery?
  3. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,579
    San Jose
    dc
    Flashing is usually emissions based. Could of leaned out for a moment if the cornering was hard.
    flash32 likes this.
  4. bauer19f430
    bauer19f430 Rookie
    Jun 7, 2022
    3
    Trevor
    would say relatively cornered pretty sharply; any suggestions as to what to do next time I start it up?
    probably a year or two (at most) old?
  5. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,579
    San Jose
    dc
    Should be fine to drive and get more gas. Never a bad idea to invest in a decent scanner to read the freeze frame if there is data stored.
  6. bauer19f430
    bauer19f430 Rookie
    Jun 7, 2022
    3
    Trevor
    Yeah. First go running the gas this low. Scanner on the way, hopefully should provide some insight, thanks!!
  7. Qavion
    Qavion F1 World Champ
    13,806
    Ian Riddell
    Strange. I thought the F430 Motronic system would be smart enough to ignore low fuel induced problems. Even the F355 5.2 has an input from the fuel quantity system to the Motronic ECU to stop it generating an engine-related fault/CEL. It assumes fuel quantity is the issue.
    Perhaps the fuel has to be low for a certain period of time before it ignores low fuel-related engine problems. Experts?
  8. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,579
    San Jose
    dc
    If the fuel is physically not there what is the ECU going to do?
  9. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,905
    Isle of man- uk
    Mine runs fine on the low fuel alarm showing
  10. Qavion
    13,806
    Ian Riddell
    One or both banks will shut down depending on fuel levels in relation to pump pickup heights. If one bank continued to turn the engine for a while, I assume the alternator would continue to operate, so would you necessarily get a CEL if only one bank shut down with fuel level low?
  11. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,827
    The Cold North
    Tom
    Flashing engine light means misfire..nothing else. Investigate before you find yourself replacing melted down cats .
  12. one4torque
    one4torque F1 Veteran
    5,576
    Houston
    One4torque
    360- had flashing light from cat ecu temp.
  13. tbakowsky
    Sep 18, 2002
    19,827
    The Cold North
    Tom
    360/430 will flash slow down in main center info panel...misfire will flash check engine light..
    one4torque likes this.
  14. S F
    S F Karting
    May 13, 2016
    164
    Texas
    Flashing engine light is a sign of a severe misfire. Sounds like it may be time for new coils and plugs.
  15. tboniello
    tboniello Formula Junior
    Jul 17, 2012
    936
    Miami, FL/North Jersey
    Tony
    Sorry to hijack an old thread but my 360 just did this - CEL, misfire codes, then started flashing and displayed "Slow Down."
    Spark plugs/coils replaced, catalytic converters just replaced. Car has ~150 miles since. Battery charged and is fine too.
    Any thoughts would be appreciated.
  16. GogglesPisano
    GogglesPisano F1 Rookie
    2,939
    East Bay, California
    Joe
    Were the cats replaced with stock or aftermarket?
  17. tboniello
    Jul 17, 2012
    936
    Tony
    Stock.
    Aftermarket, I'd expect this
  18. jtn0514
    jtn0514 Rookie
    Aug 16, 2024
    26
    Austin, TX
    This ^^ Exactly.
    Check plugs/coils and gap on the plugs.
    Scanning for codes and seeing specific cylinder misfires would lead you down the right path here. Thats assuming you have stored codes in the one of the ECUs and generally with a flashing CEL you will have something stored in memory for you to pull using an OBD2 basic scan-tool.
