Challenge Stradale TCU Upgrade | Page 5 | FerrariChat
Discussion in '360/430' started by Markjayw, Feb 15, 2011.
Thread Status:
Not open for further replies.
  1. gobble
    gobble Formula 3 Owner Regional Sponsor
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    I went down this path a couple years ago before selling my 2000 360. I purchased a CS TCU and was going to borrow the data from it to flash onto my TCU but found the chips and processors were different. 32 bit vs 64 bit or something like that. Interesting that Eric figured it out. Nice work. Does this work on all original TCU's or only newer ones?
  2. gobble
    Jan 29, 2010
    1,672
    Milwaukee, WI
    Ferrarifobs.com
    Nevermind, I see in one of his earlier posts that it's not so that easy.
  3. eric355
    eric355 Formula 3 BANNED Silver Subscribed
    Nov 30, 2005
    1,224
    Toulouse (France)
    Eric DECOUX
    Bert,
    the 191701 contains basically the same software than the very early TCUs (176552), the main difference being the possibility to set the PIS value with a SD2/3, instead of the self learning procedure.
    If they are properly tuned, even those early versions can work quite well.
    Later versions from 193263 (03/2002) to 211023 include some refinements, mainly for clutch management, and are better choices.
    The best upgrade is obviously the CS TCU with amazing upshifts at full trottle and above 7000RPM, and so aggressive downshifts in Race mode. It's a lot more fun.
  4. eric355
    Nov 30, 2005
    1,224
    Toulouse (France)
    Eric DECOUX
    Up to now, it works with all CFC231F hardware versions of TCUs (F430 & Maserati).
    In a couple of weeks, I should have validated that is possible to put the CS software in earlier versions of TCUs (CFC201F.05 & CFC201F.50).
  5. jlobee
    jlobee Rookie
    Aug 1, 2006
    6
    Los Angeles
    Is this ecu swap possible for a manual car as well? And is it possible for a F430 scuderia to a F430?
  6. mike01606
    mike01606 Formula Junior
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
    No, it's the F1 gearbox control unit..
  7. Zcobra1
    Zcobra1 Formula 3
    Oct 9, 2012
    1,242
    So Cal
    Bert
    Thanks Eric/Mike-
    Still learning about the car, and since I do not have a lengthly history, this TCU may have been in the car for many years now.....
    Eric: will you be putting out any more CS level TCU's ? Pm me if you do and cost.
  8. hakankuy
    hakankuy Karting
    Jun 15, 2010
    127
    Earth
    Hi,
    What about 183 770 oem numbered TCU's is it available to install them to normal F1s?
  9. eric355
    Nov 30, 2005
    1,224
    Toulouse (France)
    Eric DECOUX
    183770 is for Challenge race cars only. It is not compatible with 360/CS because of the different dashborad.
  10. djempire
    djempire Formula Junior
    Apr 30, 2012
    613
    Toronto
    Serf
    PM sent Eric.
  11. jpk
    jpk Formula Junior
    Oct 29, 2012
    803
    Los Angeles, CA / Henderson, NV
    If you upgrade a 360 TCU to the 360 CS TCU, do you lose the Auto mode of the transmission?
  12. Skidkid
    Skidkid F1 Veteran Owner Rossa Subscribed
    Aug 25, 2005
    9,650
    Campbell, CA
    John Zornes
    Yes, I believe you do
  13. Philcat
    Philcat Karting
    Mar 8, 2012
    142
    MD
    Phil
    Don't think so guys. Mine still works with the CS TCU installed, not that I've used it more than once though.
  14. jpk
    jpk Formula Junior
    Oct 29, 2012
    803
    OK, good to know.
  15. italia458
    italia458 Karting
    Aug 28, 2011
    222
    help please.
    any ideas on how to contact the " EU " cs owners for the summer meeting please ,
    i don't know how to work this forum.
    i don't mean disrupt this line so happy new year to all
    colin
  16. rustybits
    rustybits F1 Rookie Professional Ferrari Technician
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    No.
  17. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,457
    Dublin, Ireland
    Greg
    Somewhere in this section perhaps........
    http://www.ferrarichat.com/forum/forumdisplay.php?f=16
    Best.
  18. eric355
    Nov 30, 2005
    1,224
    Toulouse (France)
    Eric DECOUX
    Salut Colin,
    it seems you got it, thanks to Greg.
    So disapointed, you don't speak dutch? :)
    A très bientôt ...
  19. eric355
    Nov 30, 2005
    1,224
    Toulouse (France)
    Eric DECOUX
  20. 360Jet
    360Jet Rookie
    Jan 18, 2013
    3
    brand new to the forum, its 1:35am and enjoying all the info! ive had a 2000 360 for about 4 years. dont use it much (less than 10K miles total). changed the clutch and throw-out bearing about 800 miles ago, and the launch and shifting are very slow! seems the PIS needs to be set and cant because the TCU is original. So... after reading this thread I am seriously considering installing a CS TCU. Also seems there are a couple of options. 1. offered by Eric355 2. an enhancement module offered by Formula Dynamics 3. buying a CS TCU from Ricambi or some other vendor with reasonable pricing.
    not sure which would be best and most cost-effective. also, which is the safest (meaning some sort of guarantee/warranty.
    really appreciate any thoughts/suggestions?!
  21. FerrariDublin
    Jun 14, 2009
    3,457
    Dublin, Ireland
    Greg
    I don't have F1 but you've identified three options and I suppose there is also a forth, that of sourcing a genuine CS TSU second hand. They're hard to come by and I think they run to $2500 +/- 500.
    Some have reported good results with the Formula Dynamics unit. I don't know the pricing from Ricambi but on the basis that this would be a new unit I can only imagine it would be quite expensive. I don't know Eric's pricing but he has a good reputation here on FC and has had very positive reports posted about his conversion.
    I think you'll need the assistance of someone with an SD2/3 machine to set up a CS unit properly on your car (whether a used, new or re-programmed unit).
  22. 360Jet
    360Jet Rookie
    Jan 18, 2013
    3
    Dublin, thanks for the speedy response! Yes, defiitely also an option to source a used CS TCU. i would have the local Ferrari shop (or independent) install and set the PIS. However, also read on this site that flashing, or changing the TCU could throw-off the car's mileage, etc. would hate that to happen since i have a low mileage car (even though i guess i could prove the miles via Ferrari's maintenance records), jowever, would require explanations if/when i sell the car.
  23. DrDon
    DrDon F1 Rookie BANNED
    Jul 11, 2012
    3,627
    Infractionville
    Armando Decredenza
    Anyone here had experience with the Formula Dynamics Enhancement? They say it can be installed and then switched out for service or if there i a problem. The description on their website sounds as though it does more than change TCU setting though - that could be hype - or true.
  24. RedTaxi
    RedTaxi F1 Rookie Silver Subscribed
    Mar 1, 2012
    3,365
    New Zealand
    Glen
    Dont know but 1200 british pounds new for the real thing (as mentioned earlier in this thread) + 1 hour at the F-dealer has to be the best option. Was for me anyway.
  25. rustybits
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    It's not a substitute for an upgraded TCU. You can't alter any clutch settings so it won't change clutch wear directly. It changes the way the throttle input works.
Thread Status:
