Changing the battery on a 360 alarm fob | FerrariChat
Discussion in '360/430' started by djastral69, Dec 12, 2009.
  1. djastral69
    djastral69 Formula 3
    1,896
    Fl
    David
    Any special procedure on changing the battery on the alarm remote for the 360 fob or just pop it in? Also battery # if possible plse. Thanks fellas!
    'D
  2. dicin
    dicin Karting
    Sep 6, 2009
    78
    Montreal / Canada
    Nick
    Remove the screw from the back and the it should simply open with no force.
    Go to Staples and buy a 12 volt auto remote alarm battery. I believe it is a C23.
    It is the only small 12v battery and simply replace it.
    Manual says to replace them every 6 months.
  3. djastral69
    1,896
    Fl
    David
    Thank you sir, off to office depot after work...;-)
  4. tazandjan
    39,069
    #4 tazandjan, Dec 12, 2009
    David- Nick is 100% correct. I just picked up some Duracell batteries for my alarm remotes and the package is marked 21/23. In the fine print it says "12V MN21/A23". They look like 2/3 length AA batteries.
    Taz
    Terry Phillips
  5. andrew911
    andrew911 F1 Rookie
    2,893
    Northern NJ
    got mine at rite aid...fairely common size
  6. RayJohns
    RayJohns F1 Veteran
    7,858
    West Coast
    Ray
  7. tazandjan
    39,069
    Ray- Moving the antenna is a great idea and it works. Some misinformation in the thread. There is no worry about someone receiving and copying your signal because the remotes have a rolling code like a garage door opener to prevent that from happening.
    US/Canadian remotes for 360s (and other models through the 575 SA) are 315 Mhz to prevent interfering with TPMS systems, which are 433 Mhz in the US 575 series. Here is a list of frequencies from the parts catalog.
    Note 1
    Countries with a frequency of 433 MHz:
    Italy, Denmark, Luxembourg, Austria, France, Spain, Portugal, Sweden, Finland, Germany (with specific complete ECU kit), Switzerland (with
    specific complete ECU kit), Belgium (with specific complete ECU kit), Netherlands (with specific complete ECU kit), United Kingdom (with
    specific complete ECU kit), Ireland (with specific complete ECU kit), Greece, Tuerkey, Cyprus, Saudi Arabia, Kuwait, Bahrain, Brunei, Hong
    Kont, China, Thailand, Taiwan.
    Note 2
    Countries with a frequency of 315 MHZ:
    USA, Canada, Mexico, Puerto Rico, Brazil, Argentina, Venezuela, Lebanon, United Arab Emirates, Oman, Japan, Singapore, Australia.
    Taz
    Terry Phillips
  8. djastral69
    1,896
    Fl
    David
    Got'em thanks fellas. Yeah, I moved the antenna already. Yes, greatly extends the range....
