430 - Cheapest odb reader that can read clutch life? | Page 6 | FerrariChat
430 Cheapest odb reader that can read clutch life?
Discussion in '360/430' started by goto35march, Apr 4, 2020.
  1. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,158
    Central NJ
    Dominick
    the pro mini (for sure) and I believe the cheaper thinkdiag can do relearn/ bleed etc
    There is someone on here I recommended it to and was very happy - search for "thinkdiag" to find thread
  2. dom1172
    dom1172 Karting
    Mar 26, 2005
    152
    Sarasota, FL
    Dom
    Just to close the loop on this - I ordered a ThinkDiag last week & am returning it tomorrow. Didn’t realize you have to buy more software to actually scan?? Thier support stinks too
    Anyway, does everyone like their x431 mini pro? May buy a used one - do I have to maintain an account/subscription to use it, or only for updates? Thanks for insight
  3. Jaymac
    Jaymac Formula 3 Silver Subscribed
    Dec 18, 2020
    1,001
    New Hampshire
    Jeremy McCurdy
    Looks like the x431 line starts @ $800 USD on Amazon… unless I’m missing something?
  4. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,158
    Central NJ
    Dominick
    The thinkdiag comes with one free brand for one year for the 100 plus dollars depending on where you buy it
    If you choose Ferrari as the manufacturer when you activate it as the one free item you should have all the special functions..ie bleed self learn etc
    The reset functions are pay as you go but you really don't need them for the f430 ...
    Did you use your free activation as Ferrari?
    Here is the link i was referring to that another ferrarichatter i recommended it to bot it and had success
    https://www.ferrarichat.com/forum/threads/best-100-you-will-and-can-ever-spend-on-your-car-specially-if-you-work-on-it-yourself.639922/
    dom1172 likes this.
  5. dom1172
    dom1172 Karting
    Mar 26, 2005
    152
    Sarasota, FL
    Dom
    This helped, thank you! Is there a place to read wear as a percentage on the ThinkDiag? Otherwise it as a four digit number and I’m not clear how that plugs into the formula above? Again, thank you. -Dom
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,158
    Central NJ
    Dominick
    What year do you have ?
    Tell us calculated closed position and new clutch position and if you have a 360 or 430
  7. dom1172
    dom1172 Karting
    Mar 26, 2005
    152
    Sarasota, FL
    Dom
    430, are the these the right values to retrieve? I did not see a live stream field for “auto calibrated closed”. Thanks for the assistance & patience!
  8. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,158
    Central NJ
    Dominick
    those are not correct ... use the either 2.31 or 3.0 .. the other one you are not using
    Launch has a flaw and you have to use the other software type
  9. dom1172
    dom1172 Karting
    Mar 26, 2005
    152
    Sarasota, FL
    Dom
    Got it - ok, looks like I am at 60% (which was expected). Hopefully lasts another year or so but then I’m ok with replacing (it drives great currently) :) Thanks again for the help and clarification
    flash32 likes this.
  10. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,158
    Central NJ
    Dominick
    Probably another 15-20 miles of "gentle" driving and not many reverses
    My pleasure
    dom1172 likes this.
