News
Clutch Knock in a 78 308
Discussion in 'Technical Q&A' started by walawdog, Nov 9, 2004.
  1. walawdog
    walawdog Formula Junior
    Nov 9, 2004
    819
    Bluefield, WV
    Anthony
    I noticed that my clutch is starting to make a "knocking" noise when I am out of gear. If I depress the peddle just a bit, the noise goes away. I am wondering what this may be a sign of? The clutch peddle is also quite heavy, but doesn't seem to be slipping. Any thoughts on this?
    Thanks,
    Anthony
  3. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,920
    Outside Detroit
    Don the 16th
    It's your Throwout bearing.
    Mine's noisy, too.
  4. walawdog
    Nov 9, 2004
    819
    Bluefield, WV
    Anthony
    How serious is the throwout bearing anyway? If it fails, what are the consequences? Does the engine need to be pulled to replace this? It's my first Ferrari....
  5. matteo
    matteo F1 World Champ
    Aug 1, 2002
    13,748
    On a plane somewhere
    Heir Butt
    The clutch can be replaced in the car. You have to remove the drive side wheel and innner fender to get to it.
    I would change it. Also change the clutch disk while you are there.
