Coils - Tootsie Roll Style | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by enio45, Mar 13, 2019.
  1. enio45
    enio45 Formula 3
    1,634
    Gilbert, AZ
    Ed
    Im getting ready to fire the engine for the ellena and discovered i have the wrong coils.
    Im told and by other examples I have seen that the Tootsie Roll Style is the correct ones.
    I have also seen an example where they were not used but were vintage type with no resister on them.
    I have a build sheet for the car after mine and there is no indication on the build sheet what type of coils were designated. It does call out the single distributor on the build sheet - BUT no coil designation.
    Looking for some education, advise, what to look for - are all tootsie roll coils create equal??
    Appreciate the thoughts...
  2. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,515
    romano schwabel
    when you use a coil without resistance then on the bottom there is no letter or only a K, if with resistance then there are the letters KW or only W ( bosch coils ).
    never heard about tootsie roll coils
  3. enio45
    enio45 Formula 3
    1,634
    Gilbert, AZ
    Ed
  4. turbo-joe
    Apr 6, 2008
    9,515
    romano schwabel
    the resistor is connected separately to the coil; not where the wires from the ignition switch and the distributor goes to?
    would be great to see a photo from the top if the coil, but this one looks original?
  5. John Vardanian
    John Vardanian F1 Rookie
    Jul 1, 2004
    3,080
    San Francisco Area
    John Vardanian
    TJ, the tootsie roll is a classic American candy that in some ways looks like those cylindrical resistors. We just made that up and it term stuck.
    Not to hijack Ed's thread, but I would be interested in learning the advantages/disadvantages of having a resistor in the ignition, as it seems like some cars have resistors and some do not--and I am not referring to just Ferraris. Thanks.
    john
  6. MiuraP400
    MiuraP400 Formula Junior
    Feb 3, 2008
    949
    Arizona
    Jim
    I do not have proof of the following, but in my opinion cars with the coils and distributors mounted at the front of the engine had internal ballast resistors. These were mounted on the inner inner fender in a fairly cool area. When Ferrari moved the distributors to the rear of the engine the air was hotter so they had to switch to an external ballast resistor to reduce the heat build up in the coil.
    Cheers Jim
  7. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    2,037
    John: Every 12 volt car has to have a resistor in the ignition system, otherwise the points will burn up. Many cars use a resistor wire from the ignition switch to the coil to drop the voltage, and some use an external resistor to achieve the same results.
  8. enio45
    enio45 Formula 3
    1,634
    Gilbert, AZ
    Ed
    This is interesting, as my old and new wiring harness, and ill double check this before i say 100%, does not have resistor wire
    running from the fuse box to the coils.
    So if that is the car, ill need to put some resistance in the wire......or use the tootsie roll coils.....
    This a true assumption?
    This is timely Dyke as I'm working thru my single dizzy and going to adapt your cap and rotor change. Now with the dizzy all apart, i can do this - hopefully easily.......
  9. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    2,037
    Ed: Ferrari always used separate resistors as opposed to resistance wire. Ford and GM (but not all their cars) used resistance wire and Chrysler used stand alone resistors. The Germans tended to place the resistance internally in the coils, and the British had no clue.
    turbo-joe, Rifledriver and 375+ like this.
  10. enio45
    enio45 Formula 3
    1,634
    Gilbert, AZ
    Ed
    SO i see that greg jones makes vintage coils and he said his has a 3 ohm resistance , oil based.....
    so running these qualify for the necessary resistance needed?
    Is this the same thing as an external resistor?
    Sorry for all the questions, I'm a bit in the dark on this and trying to define the correct coil type for the car.
  11. John Vardanian
    Jul 1, 2004
    3,080
    San Francisco Area
    John Vardanian
    #11 John Vardanian, Mar 14, 2019
    Dyke, thanks. I have generally not seen resistor blocks around the earlier types that predate the "tootsie roll". Are the resistors internal? But that would overheat the coil probably.
    john
  12. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    2,037
    John: I am trying to answer complex questions with too simple answers. Yes, the early Ferrari coils are internally resisted.
    Ed: Greg makes repro coils for the ones shown in Post #11 (and possibly other versions as well). i would try to find a set of the original tootsie-roil units. Since you are in Arizona, get in the car and personally go to GT Car Parts. I would bet, somewhere on the premises are the coils you are looking for.
  13. MiuraP400
    Feb 3, 2008
    949
    Arizona
    Jim
    Coils with approximately 3 to 4 ohms of resistance have an internal ballast resistor and do not need an external resistor. Coils with approximately 1 ohms of resistance need an external resistor.
    A resistor is needed in the system to prevent the points from burning up. The resistor drops the voltage to the points so they do not pit to as fast as they would with 12 volts. If you measure the voltage to the distributor you will find the voltage in the 6 to 9 volt range. Some systems supply the full system voltage while the engine is cranking to offset the voltage drop from starter motor current draw.
    Cheers Jim
    John Vardanian likes this.
  14. enio45
    enio45 Formula 3
    1,634
    Gilbert, AZ
    Ed
    ok thanks for the info....i saw bill yesterday and we discussed some of this as well as the GTC/4 dizzy cap and rotor.
    let me see what he has.....
  15. John Vardanian
    Jul 1, 2004
    3,080
    San Francisco Area
    John Vardanian
    Jim, appreciate the explanation.
    john
  16. Lowell
    Lowell Formula 3
    Apr 17, 2005
    1,165
    Santa Fe, NM
    Lowell Brown
    The coil has an inductance. The resistor has a resistance. The are not the same thing. The primary and secondary coils, the spark plug, the capacitor, the resistor all from part of a damped electric oscillator. The purpose of the capacitor is easy to understand. When the points open, there is a rapid change in voltage because of Faraday's law. Capacitors act like short circuits to rapid voltage changes and thus keep the points from sparking. I am afraid that I never have thought before about the role of the resistor. But now I guess that it is there to keep the current low in the primary coil when the capacitor acts like a short circuit and the Faraday law is placing more than usual current into the primary coil circuit and to damp down the oscillations in the otherwise LC circuit that now becomes an LCR circuit. (Neglecting the coupling to the secondary coil.) ON THE OTHER HAND, what I just said off the top of my head may well be nonsense. Perhaps someone else has the correct reason and can explain it and save me the time and trouble of solving the equations of the electrical circuits.
  17. dodici
    dodici Karting
    Mar 24, 2007
    101
    Bay Area, CA.
    Dale
    The engine can also stop with the points open or closed. If closed, the current to the coil is only limited by whatever total series resistance there is. That's probably a consideration also.
