430 - Cold start issue | FerrariChat
430 Cold start issue
Discussion in '360/430' started by drmc, Mar 19, 2021.
  1. drmc
    drmc Rookie
    Dec 12, 2013
    36
    Australia
    Danny
    Ever since I purchased my F430 about 1-year ago it’s had a cold start issue. When the engine is cold (car hasn’t been started for 12 hours+), upon starting the car it will splutter for 10-seconds or so before commencing a normal idle, or it will totally stall out (like in the attached video). When this happens, I turn the ignition off then straight back on again, start the car and it fires into life normally.
    I took it to Ferrari and they just said this is F430 personality!
    Has anyone else experienced this problem? I found some old threads on the issue but no conclusions seemed to be reached.
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    You are very quick from turning the key to pressing the starter, give it a few more seconds. It sounds like it is not firing on 1 bank on your 1st start. Engine is controlled by 2 ECUs and system needs time to talk to each other. ,if you start mine too quick the heater will not work.
    Red 27 and flash32 like this.
  3. craze
    craze Formula 3
    Mar 5, 2021
    1,038
    Melbourne
    Michael
  4. kes7u
    kes7u Formula 3
    1,148
    Shorewood, MN
    Kevin
    Not sure if it is normal, but also happens on my 360. Sometimes twice.
    Kevin
  5. hessank
    hessank Formula 3
    1,748
    Canada, Florida
    Fred
    My 360 starts up first time, every time. However, if I do it quickly as Danny did it will complain,
    buck and fart and sometimes I have to shut it down and then do it slowly.
    Maybe, as Mike32 said, the ECUs need to wake up and start talking to each other.
    No wonder why we refer to our cars as 'she and her'
    flash32 and kes7u like this.
  6. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,231
    Santa Clarita, CA
    I turn my key to the on position and wait until I get the OK on the dash. Then I press the start button. It blubbers for about 5 seconds then clears up.
    I actually like the blubbering sound because I back my car into the garage and the sound resonates off the walls.
  7. vv23
    vv23 Karting
    Jan 8, 2009
    245
    Edmonton, Alberta
    V V
    Check for vaccum line leak near the throttle bodies.
    I had a slight leak near the MAF which caused it to have to restart twice and bounce the idle.
    mathewr likes this.
  8. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    My previous neibour over the road came over to complain about my 430 starting up, telling me to fix the exhaust leak. My exhaust pipes pointed at his conservatory and made the glass vibrate. The next owner of the same house loves the noise it makes- u cannot please everyone
    mathewr likes this.
  9. mathewr
    mathewr F1 Rookie
    Sponsor Rossa Subscribed
    Dec 7, 2011
    2,803
    Deep in the Heart of Texas
    Ferrari Wheel Guru
    #9 mathewr, Mar 19, 2021
    Not normal.
    Open Door.
    Slide in.
    Twist key
    Sit for 20 seconds or so, AFTER the OK light.
    Push the round red button.
    The car comes to life in a nice (scare the neighborhood way) Take the time to understand that you have a very very rare car.
    Don’t get in a hurry. When you leave your driveway the car will most of the work for you.
    Stoplight.
    Mercedes to your right, Dodge RAM to your left. You know where you stand in this mix, however they don’t, they just think they do. Let them take off and race each other. Fly by and throw them the piece sign.
    drmc likes this.
  10. mathewr
    mathewr F1 Rookie
    Dec 7, 2011
    2,803
    Ferrari Wheel Guru
    Also make sure you keep her on a battery tender. A strong battery in our cars is a VERY key ingredient.
  11. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,231
    Santa Clarita, CA
    My new neighbors across the street have a dragster. I just came home and he was running it in his trailer. Love it!!!
  12. drmc
    drmc Rookie
    Dec 12, 2013
    36
    Australia
    Danny
    Thanks for the replies.
    - I tried turning the key then waiting ~20 seconds before pressing the start button which did not change the issue (trialled 10 times).
    - There weren't any vaccum line leak near the throttle bodies.
    - Car has a new battery and is always kept on a tender.
    One thing I have noticed: the more frequently I drive her, the less rough the idle is. I went through a period of 2 months where I drove her 4-5 times per week and the start up issue went away entirely. Turn the key, press the start button and she would fire up and settle straight into a normal idle.
    But now that I'm only driving her 1-2 times per week I get the stalling out problem every time I start her. The longer since her last start, the quick she stalls out.
  13. tazandjan
    38,085
    Dirty and dripping injectors will give you the symptoms you describe and the second start works perfectly because the excess fuel in the chamber has been cleared. When I had my injectors cleaned and resealed with Viton seals, the cold start problem went away. Three of them (V12, but also 7.1.1) were dripping and the others were not flowing well. Aaron was my tech. A bottle of high concentration Techron will often make a difference, and if it helps, have the injectors serviced.
    drmc likes this.
  14. craze
    craze Formula 3
    Mar 5, 2021
    1,038
    Melbourne
    Michael
    Ive found since leaving my car on tender it starts fine
  15. drmc
    drmc Rookie
    Dec 12, 2013
    36
    Australia
    Danny
    I had my injectors cleaned about 6 weeks ago and the issue has totally gone away. Thanks Tazandjan
    Qavion likes this.
