Connecting Battery Conditioner to 355 | FerrariChat
Discussion in '348/355' started by Senshi458, Oct 17, 2021.
  1. Senshi458
    Senshi458 Formula Junior Sponsor Owner Rossa Subscribed
    Oct 17, 2015
    886
    Norway
    Reza
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,965
    Central NJ
    Dominick
    Any good chassis ground .. look for grounds that are attached to chassis and you can use that ..or in a pinch ..look for any screw /bolt go into the chassis and loosen that and use it
  3. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,632
    Elliott Caras
    There is a ground point on the subframe below the 3 positive terminal junction. It’s there for this reason. If has a hex head on it undo, insert the ground strap and refit the hex head bolt.
    Senshi458 and flash32 like this.
  4. Pepsi10
    Pepsi10 Formula Junior
    Nov 24, 2008
    855
    InlandNorthWest
    Mike M
    Just a strange suggestion. I bought a plug that goes into the cigarette lighter in the center console, you know, the 12v adaptors. I fused that to an extra trickle charger plug I had lying around.* And now I can just plug into my cig lighter to trickle charge the car. Your way looks more professional.
    *Meaning cut off the alligator clips or whatever, and replaced with the cig lighter adapter.
  5. Qavion
    Qavion F1 World Champ Silver Subscribed
    Feb 20, 2015
    14,388
    Ian Riddell
    308 GTB and Senshi458 like this.
  6. Senshi458
    Oct 17, 2015
    886
    Norway
    Reza
    Qavion likes this.
  7. michaelz
    michaelz Karting
    Jul 7, 2017
    79
    Melbourne Australia
    I just ran that cable directly to the battery terminals through the frunk opening for the battery isolator.
    PhilB likes this.
