Considering 308 QV - Looking for advice | FerrariChat
Discussion in '308/328' started by ToddFC, Jun 11, 2022.
  1. ToddFC
    ToddFC Karting
    Jun 11, 2022
    140
    Charleston, SC
    Todd
    1st time post here and possibly 1st time Ferrari Owner in the making. Owning a Ferrari would be a dream since my teens and feeling like its time for everything else to stop getting in the way so I've had my eyes out for a few months now.
    Admittedly I'm just diving in so do apologize if I have overlooked some other resource where this can be found.
    I'm considering jumping in on a 308 QV. Aesthetically its in very good condition, with nothing that is concerning.
    There are is just over 100K on the clock though. The seller has not been the owner long and acknowledges the previous owner had let needed maintenance lag. They have done a major service and shared that report with me. My question is with 100K on the car, what else should I be looking for or asking about from a service perspective. Here is the list of what has been done I can get from the invoice (left out the little bits):
    1. plugs wires caps rotors
    2. timing belts
    3. wp / alt belts
    4. water pump & t-stat
    5. belt tensioner
    6. intake manifold refinished
    7. new tires
    8. seats dyed
    9. rotary ac conversion
    10. cooling system hoses (says all hoses)
    11. tank vent line
    12. engine oil
    13. trans fluid changed
    14. flush bleed brakes
    15. replaced all fuel injectors
    16. wire sets for Front/Rear banks
    17. fixed sticking parking break
    18. LM1 mixture check / adjustment
    19. fixed fuel accumulator and fuel press regulator leaks
    20. radiator removed and sent out for cleaning/service
    21. engine lid struts
    I did drive the car and it seemed to ride/drive excellent to me. However I have zero frame of reference for this car. I'm enough of a car guy to pick up the obvious but wouldn't trust that to mean I wouldn't miss something so looking for any advice or thoughts.
    If you have any thoughts on what a clean (now) well serviced 308 should be worth with 100K on the clock I'd like to know, here or in PM.
    Thanks to all in advance.
  2. s219
    s219 Formula Junior
    Aug 26, 2021
    473
    There is a pretty good list of things I would look at but I wouldn't be afraid of 100K miles if the car was good and the pricing was realistic. Best bet is to find a local expert to do a PPI, since it can really help identify issues and also provide you with data to adjust valuation and make an offer (if you decide to go forward).
    Offhand, two age/wear things I didn't see on the list were the undercarriage (bushings, joints, etc) and fuel lines/hoses/sleeves (low pressure hoses, tank connection sleeves, filler neck sleeve, etc).
    Can you get underneath the car and look around? That can be quite educational.
  3. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    At 100k I'd be thinking about valve guides. I don't know how long they last, but there have been a few heads rebuilt here around 100k miles. The other thing is synchros. But if it shifts nicely with no crunching - the 308 is notchy by nature, not buttery - then I'd call it good.
    For sure if you are looking for a car that won't need constant feeding and fiddling then any 308 isn't a good choice.
    ferrariowner likes this.
  4. ToddFC
    ToddFC Karting
    Jun 11, 2022
    140
    Charleston, SC
    Todd
    I didn't get under the car. The repair invoice does say they pulled the wheels, liners, did a fully underbody wash and inspection. They have cleaned and detailed every square inch of the car, the engine bay is spotless clean.
    If I was going to make an offer I'd go back down and go through things a little more thoroughly than I did.
    It shifted fine enough. I think "notchy" is a good word. I also drove a Pantera while I was there (I need one more inch of headroom) and it was noticeably smoother shifting, again "buttery" is a good word by comparison. However, the 308 wasn't rough, or crunchy, nothing forced nothing grinded. Movements are just more specific.
    I don't mind "fiddling" and in fact can appreciate a certain amount of it. I just want to be able to enjoy more driving time then fiddling time :)
    I'll ask if they did a compression check when they pulled the plugs. This would have sniffed out the valve / head issue, yes?
  5. Cuddy K
    Cuddy K Karting
    Oct 30, 2017
    181
    Ian Karr
    #5 Cuddy K, Jun 12, 2022
    First, the fact that you're going in with eyes open and asking for help is a really good indicator you'll do just fine.
    I totally agree with getting a PPI from someone very knowledgeable. Maybe even put the request here on this forum. Where is the car located? Assuming it's not too far away, people are generally happy to help. Often for free. I like to ask for a donation to my favorite charity to pay things forward.
    As for the things on your list, in addition to the suspension bushings and condition of hoses, I'd add a compression/leakdown test...and a request to see whatever records the seller has. That will tell you a lot. Sometimes, in situations where there are lots of unknowns about a car, it works well to agree on a price and put money in escrow, pending further inspection. A service like escrow.com is perfect for this (no affiliation). By actually putting some money up, it locks in the deal while you sort through all the unknowns...and proves to the seller you're serious. Best case, you leave the price as agreed and close the deal. If other stuff is discovered, you can renegotiate, and if you can't agree, your deposit is refunded.
    The most important thing I've learned buying collector cars is that buying the seller is equally, if not more important than buying the car. If the person is known in the community and you feel good about how the deal is going, that's a good sign. Best of luck with the purchase!
  6. ToddFC
    ToddFC Karting
    Jun 11, 2022
    140
    Charleston, SC
    Todd
    Thanks for this. The Car is in Savannah GA, so if anyone is interested please let me know. I will ask about the compression/leakdown Monday. If I make an offere I was planning on a final inspection contingency. I'm only a couple hours away.
    The current Owner hasn't had it long. It was purchased, serviced and then decided at 6-4 he was a little big for it. I'm 6-2 and while I'm completely comfortable, I'm not sure I would be at 6-4 so it seems a reasonable explanation. I'll ask about any other service records but they have acknowledged it was a little service deficient when taking possession and why so much work was done right off. The paint is stunning and I meant to ask if/when it was re-done. The interior shows that it is original but also in truly very good condition for 35 years.
  7. s219
    s219 Formula Junior
    Aug 26, 2021
    473
    If it was a recent purchase, do a google search on the VIN -- that may turn up some helpful info as well. Some of these cars get around and have quite a history.
    smg2 likes this.
  8. Cuddy K
    Cuddy K Karting
    Oct 30, 2017
    181
    Ian Karr
    Cool. Suggest you start a new thread called “PPI needed in Savannah, GA”. If possible, travel out for the inspection. Plane tickets are way cheaper than Ferrari repairs. Or at least they used to be!
  9. ClydeM
    ClydeM F1 World Champ
    11,595
    Wayne, NJ
    Clyde E. McMurdy
    I have a 100K car. They like to be driven so the mileage wouldn't bother me too much. Just the additional wear.
    Additions to your list;
    Check steering rack
    Check engine mounts
    Check the suspension bushings
    Check for rust around the fenders & battery tray
    How's the directional/light stalk. cracking yet?
  10. dyerhaus
    dyerhaus Formula Junior
    Nov 4, 2012
    810
    Santa Rosa, California
    Christopher Dyer
    Believe it or not, for a 308, mileage really isn't that big of a deal provided it's been properly maintained. I have a friend with a 1984 QV that has damn near 300,000 miles on it. He's owned it since 1991, and it's still a concours winning car today.
    It sounds like you are headed down the same path I did. My dream was always a 308 GT4 when I first saw one as a teenager. Like you, I decided it was now or never, and I quit letting other things get in the way. Last October, I bought my dream car and finally became a Ferrari owner, whilst fulfilling a life-long dream.
    My advice is the same that was given to me: Find and buy the best one you can. When I found my 308 GT4, it needed nothing, in fact I could have driven it straight on to a concours field and taken home some sort of award. The 308 is a great car, but it's only getting older, thus parts are harder and harder to find, and getting more and more expensive. If you buy something that needs some work, then it could be sitting in the shop for months just waiting on parts to be found, ordered, and delivered.
    Find one that's well documented. I got lucky with mine, I have all the records of the car since it was new (1975), I know the complete ownership history, and I'm even in contact with the original owner. If it's well documented, you can look through all the paperwork and form the life story of the car. Obviously, like others have mentioned, have a PPI done by someone who knows 308s.
    Also, think about what your goal is with the car. Is this a car you just want to drive and enjoy? Is this a car you want to show at small gatherings like cars and coffee? Is this a car you want to show at concours events? Your goal with the car makes a big difference in things you might look for. If you're going for concours shows, then it needs to be a 100% correct car. If you're just driving it for fun and pleasure, and don't care to show it, then 100% originality isn't a major concern. For me, I wanted to drive the hell out of it, but also take it to concours events, so originality was key for me… plus, I don't tend to like after-market additions or upgrades anyway, on any car.
    Drive other 308s!!! You said drove this one, but that you have "zero frame of reference for this car" because you haven't driven others. Find others, and drive them. It's not always easy, but in my case I did find and drive two other 308 GT4s before I found the one I bought. You need a frame of reference, these cars are old analog cars that will drive completely different than another one. That has certainly been my experience. I recall driving one that I was considering and thinking it was amazing, then I drove the one I bought and couldn't believe how much better it was than the other one. Don't marry the first car you meet. :)
    Lastly, visit Ferrari mechanics and see if maybe any of their customers are selling their car. That's exactly how I found mine. Forget the online auctions and whatnot, those are too popular and you'll overpay for it (and likely without the opportunity to even see it first). If a local mechanic knows of one for sale, you're likely not competing with anyone on the purchase (unlike the internet).
    Good luck!! Maybe the one you've already found it the one for you, but definitely do your homework before making the leap.
  11. Dr Tommy Cosgrove
    36,083
    Birmingham, AL
    Tommy
    I have 126,000 + on my QV if that makes you feel any better. Factory sealed engine. Runs strong. Bought it in 1997 with 57,000
    4re308, Jbrauer and miketuason like this.
  12. ToddFC
    ToddFC Karting
    Jun 11, 2022
    140
    Charleston, SC
    Todd
    Well I spent too much time getting my head around this one and lost it. I guess the good news is I've learned a bit about what I'm looking for, what I'm willing to spend on it, and will be more ready to jump when the next right deal comes along. I literally called to make an offer and he had just sold it.
    A little remorseful as the color was rare and condition was pretty amazing. ... On we go
  13. s219
    s219 Formula Junior
    Aug 26, 2021
    473
    There will be other cars. It's good to ease into this carefully and not make impulse decisions. As you gain experience, you'll be able to make smart/educated decisions and have proper perspective.
    I can tell you I am glad I missed out on the first couple cars I looked at, and I am glad I backed away from some other cars, due to condition or pricing. When the right one comes along you'll know it -- be prepared to jump on it.
  14. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,785
    Mike 996
    I looked for two years before finding/buying my 328 in August, '08. So, as has been stated, don't get in a hurry. As has also often been stated, buy the best car you can; it will cost more to pay less/put a car in the condition you want than it will to buy one already in that condition.
  15. JimMA
    JimMA Rookie
    Sep 6, 2018
    21
    MA, USA
    JimMA
    If the car doesn’t come with complete ownership info, is there a way to track it?
  16. dyerhaus
    Nov 4, 2012
    810
    Christopher Dyer
    If the car doesn't come with it, I'm not sure how to go about it. My car, amazingly, came with almost all the DMV records as well as insurance records from the previous owners. You might need to "know" someone at the DMV in order to get the history, but then again, not sure if that's legal? Maybe old service records can help (looking at who's name is on the receipts). Dealerships or repair shops? Hire a P.I.? I don't think there's any one, easy way to do it, just lots of research down every conceivable avenue (and even then you may turn up nothing).
  17. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,785
    Mike 996
    I wouldn't bother. What real purpose does it serve UNLESS you are interested "just because" OR you are researching a car with a high price due to alleged connection with a famous person or historical use of the car.
    IOW, what is important is the condition of the car right NOW which is easily determined by an appropriate inspection.
    dyerhaus likes this.
  18. JimMA
    JimMA Rookie
    Sep 6, 2018
    21
    MA, USA
    JimMA
    It was more of a “why not” kind of process.
  19. dyerhaus
    Nov 4, 2012
    810
    Christopher Dyer
    Mike is correct in it really doesn't matter, unless there's some sort of ownership provenance (but then proof of that would probably come with the car). I just think it's cool knowing where the car has been since it was made, how long each person kept it, and so on. It's interesting, and if mine hadn't had all the records, I might have tried to research it myself for the "why not" aspect of it.
    JimMA likes this.
  20. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,785
    Mike 996
    I completely agree if the reasoning is that the buyer wants to do it out of interest - heck, I like the fact that I have all the records for my 328 beginning with the window sticker and sales receipt from the original purchase. I was thinking more in terms of whether the info was vital toward a purchase decision. OTOH, I admit that if I was trying to decide between two cars that were in the same condition and price, if one had all the the records and the other didn't, I'd choose the one that did.
  21. s219
    s219 Formula Junior
    Aug 26, 2021
    473
    Ownership info isn't super important to me, but condition and maintenance records are.
    I do happen to think that historical information and documentation adds to a vehicle's appeal. I have a binder full of records for my 328 that includes the original window sticker, the "sold" tag that was put on the car when it was bought, the salesman's card, the brochure, magazine articles from the time period, etc. It is fun to look through that info and I suspect it will appeal to a collector if I ever sell the car. None of that entered into my decision to buy the car (I was strictly focused on condition, maintenance records, and the PPI results) but I think it would sweeten appeal to a collector. I have been adding records and receipts to the binder so the next owner will have a nice continuous record going back to the beginning.
  22. JimMA
    JimMA Rookie
    Sep 6, 2018
    21
    MA, USA
    JimMA
    These are the same thoughts I have. I got this 308 because it is exactly what I was looking for. The record search is for my own curiosity and for “the next person”, having it is more interesting then not having it. So any advice on where to obtain any historical info would be appreciated!
