355 - Convertible Top Control Module Repair | Page 3 | FerrariChat
355 Convertible Top Control Module Repair
Discussion in '348/355' started by DanRC30, Feb 10, 2025.
  1. Qavion
    Qavion F1 World Champ
    14,672
    Ian Riddell
    Perhaps you mean the roof emergency bypass switches. These bypass the Roof ECU (and it's logic), allowing you to close the roof even if the seats are in the wrong position or other roof sensors have failed). The handbrake must still be on.
  2. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
  3. Qavion
    14,672
    Ian Riddell
    Yikes... You have some serious roof issues. Sounds like one or more of your pistons is leaking. Big $$$. If you watch the video I provided a link to, the specialist recommends not topping up the fluid if it's that low. Does the car reek of hydraulic fluid? There are four pistons. Two big, two little.
  4. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
    Well, my friend did have the driver's seat removed when he was going to refurbish the leather........ The plot thickens......
  5. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
    No, I do not smell hydraulic fluid. I've seen the full rebuild kit. $4000
  6. Qavion
    14,672
    Ian Riddell
    I think I would still remove all the leather covers on the pistons and check for leaks before attempting a refill. Leaks have also been noted in the pipes which run across the firewall. More leather removal required.
  7. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
    Probably not even worth investigating at this point since all of the components are old and will likely fail in the near future anyway. I think my options are I either go with the replacement kit from Top Hydraulics or I convert it to a manual system. FUN! :)
    Qavion likes this.
  8. Qavion
    14,672
    Ian Riddell
    So with that diagnostic avenue closed, we are back to changing Roof ECU relays...
    If you have a boroscope /smartphone snake cam.... I guess you could check that the seat potentiometers are at least plugged in.
    (EDIT) You can do wiring checks at the ECU connectors to see what the potentiometer values are like on both seats.
    Roof electrical diagram here:
    https://www.dropbox.com/t/kgi7SKxkhTDQeDZx
    Link expires in 6 days.
    DanRC30 likes this.
  9. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
    Are you an electrical engineer? This level of troubleshooting is above my knowledge and experience level. I'm sure I could learn though... :)
    I do have a smartphone borescope so I can look under the seat with it. Would/could the problem with the power seat be intermittent if the potentiometers aren't working properly? Wouldn't it be all or nothing?
  10. Qavion
    14,672
    Ian Riddell
    Just trying to establish that the potentiometers are NOT influencing the manual movement of the seat. I suppose I could disconnect one of the potentiometer plugs on my seats to see if the seat still operates manually.
  11. Qavion
    14,672
    Ian Riddell
    Ok.. the seat potentiometers do not affect the manual control of the seats (at least not with the seats in the mid range, I didn't try it at the endstops). I pulled the white potentiometer plug at the front of the driver's seat. No boroscope required, just good lighting.
  12. RED HEAD
    RED HEAD Karting
    220
    London
    H
    I reckon your seat potentiometers are the issue and need repairing (gear gone/broken inside) and they are out of sync to where the module thinks they should be in relation to the roof cycle. Just had both of mine replaced. Drivers would only go forward so far and at one point only backwards and got stuck. Your fluid is clearly way too low and desperately needs a top and probably bleed amy air in the system. I think my garage said there is a rebuild px with your old component (note surcharge) via Maranello Classic Parts (UK). https://www.ferrariparts.co.uk/part/ferrari/64978300?id=10227
    This video is also very helpful:
  13. Qavion
    14,672
    Ian Riddell
    I just proved on my own car that this is not true for manual seat operation. The OP has an issue with manual seat control.
    DanRC30 likes this.
  14. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
    2Q's:
    So we're back to swapping out that relay, correct?
    Regarding the top, I think I'm going to convert it to manual as I can always go back and do the rebuild kit at a later date. Correct?
  15. Qavion
    14,672
    Ian Riddell
    #66 Qavion, Feb 11, 2025
    Yep.... Just remember where all the pieces go.
    As a test, could you pull the white plug on the front of the driver's seat to see if the seat still doesn't operate with the seat switches. You just have to lift one plastic release clip to get the plug off. I've tried every which way to get the seats to stop working.
  16. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
    According to that video, the only parts that get removed are the lower pistons. That seems simple enough to take pictures of to document...
    But my problem is the seat working in the forward direction intermittently when using the switch all by itself. What will pulling that plug do? Wouldn't that just make it not work more?
  17. Qavion
    14,672
    Ian Riddell
    It's just to prove that the potentiometer has no influence on your seat when using manual controls.
    I've just positioned the seat at the fore/aft endstops to move the potentiometer to the limits, then disconnected the potentiometer. Either way, the seat continued to move normally.
    DanRC30 likes this.
  18. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
    Here's a pic of what the wires under my seat look like... Looks like a connector for wiring up a trailer! And then some other things attached to it....
  19. Qavion
    14,672
    Ian Riddell
    Just realised a flaw in my logic. Whenever I disconnect the pot connector, it will always produce an open circuit (very high resistance), no matter the seat position, which, according to the wiring diagram, would simulate a greater than fully aft seat position.
  20. Qavion
    14,672
    Ian Riddell
    Interesting. Ignore the orange wire harness. That's a seat interlock which will stop the roof operating if the seats are not in the car (i.e. the orange wire plug is disconnected). Can you see any plugs with the same wire colours as mine? Grey/yellow (2 off), black (2 off), grey/blue.
    My car is a RHD, so I don't know if the seats are the same.
  21. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
    Here's what I have....
  22. Qavion
    14,672
    Ian Riddell
    Can you figure out where the grey/yellow wire goes? Does it go to a plug with 3 pins?
    The blue/black and white/black wires should be the seat motor wires. Unless that blue (with black stripe) wire is actually black (with blue stripe)
    I don't recognise that 4 pin plug. Potentiometers should have a 3 pin plug.
  23. DanRC30
    DanRC30 Karting
    Dec 8, 2011
    208
    NJ
    Dan
    I can't tell what goes where without removing the electrical tape off the connector wires. It looks like someone hacked in this connector in there because I think there are crimp splices under that electrical tape. Plus, I stuck my head under the passenger seat and it looks like the pic you posted above and not like my driver's seat. I wonder if maybe there's a loose connection under there?
    Maybe I'll get brave and pull back that tape and see what I have...
  24. Qavion
    14,672
    Ian Riddell
    Weird. Apart from the orange wires, can you see how many wires there in the driver's seat harness? I have 8 wires (plus 2 orange) on the driver's seat.
    Assuming the pot has no influence on manual seat operation, only the motor wires would affect seat operation. i.e. blue (black stripe) and white (black stripe) on the driver's side (on my car at least). Solid white and solid blue on the passenger side.
