Converting Boxer from Fuel Injection to Carbureted | FerrariChat
Discussion in 'Technical Q&A' started by jselevan, Feb 29, 2004.
  1. jselevan
    jselevan Formula 3
    Nov 2, 2003
    1,873
    Curious about what would be involved in converting a BBi to a BB. Aside from the obvious of obtaining manifolds and proper carburetors, removing injection system and obtaining proper fuel pumps, what other modifications would be required? Are cams, timing, valves different? Could one leave the injectors in place as plugs, or would inserting a threaded plug to seal the injector seat a better idea?
    Simply an intellectual exercise, but one that would ultimately provide the sound and fun of a curbureted Boxer with the modernization that crept into the series over 10 years.
    Thanks.
    Jim S.
  2. Edward 96GTS
    Edward 96GTS F1 Veteran
    9,303
    Can you elaborate more on the advantages of such an exercise.
    My advice would be to simply sell the bbi and buy a bb. The loss in value to the bbi would be prohibitive, not to mention, do you really want to be in such unchartered waters? The cost in $ and loss of driving time would surely make this a maddening experience.
    Now, if it's not too late......put the wrench down and step away from the tool box........
  3. Edward 96GTS
    9,303
    ps- Jim, did your friend ever buy the yellow boxer? Can you pm me w/ details?
  4. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    Jim
    The French importer, Charles Pozzi, converted three carburetted boxers to fuel injection for LeMans in June 1979.
    Russ Turner ("snj5") has documented at some length the conversion of a 4v 328 to carbs, without (at least from a far) too much drama and a lot of delight at the end of the process. As the Boxer was never a car intended for US consumption, I'd be surprised if the cams went through much of a change over the years to deal with any emissions related stuff.
    If the desire were to use individual throttle bodies, but retain a form of injection, I'd guess TWM or the Porsche types could work something up (I believe the triple choke Webers were the same as the 911 units). Unbounded by any form of reality, well, not much anyway, a TR (4v) engine in a boxer along with the above, would be, well, interesting...
    Idle speculation or something in mind?
    Philip
  5. jselevan
    jselevan Formula 3
    Nov 2, 2003
    1,873
    Mostly idle speculation. The thought was precipitated by my friend that did purchase the yellow 1974 365BB. The car was like new, with approximately 5,000 original Kilometers. Yellow with black interior. Tools, books, oriignal everything. There is something about an engine bay chocked full of Webers.
    Thanks for the help on the intellectual exercise. Edward, I agree that the value proposition is not there. Not even close.
    Jim S.
  6. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    You could sell your BB512i and buy a BB512 and should have enough left over to have a major service done.
  7. Drew Altemara
    Drew Altemara Formula 3
    Feb 11, 2002
    1,505
    Tuscaloosa, AL
    Drew Altemara
    I'd like to see someone put IF3C carbs on a TR. That would be a blast.
  8. Chiaro_Slag
    Chiaro_Slag F1 Veteran
    Oct 31, 2003
    7,789
    CA
    Jerry
    Nice! Is your friend in the area? Will he be bringing it to CC? Would be nice to see another fine BB next to yours! :)
  9. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,269
    Its IDF3C.
  10. Drew Altemara
    Feb 11, 2002
    1,505
    Tuscaloosa, AL
    Drew Altemara
    Hi Mitch,
    The carbs listed in the sales brochure, in the Mel Nicholes boxer book and on my car are shown as 40 IF3C; no "D". The 40 IDF's listed in my Weber books are 2 barrel. There are also some 40 IDA3C's also listed which is very similar to the 40 IF3C but these are identified in the Weber book as Porsche carbs.
    Regards,
    Drew
