Converting F1 to manual | FerrariChat
Discussion in '348/355' started by Senshi458, Sep 28, 2021.
  1. Senshi458
    Senshi458 Formula Junior
    Sponsor Owner Rossa Subscribed
    Oct 17, 2015
    874
    Norway
    Reza
    Hi
    I have F1 GTS Im considering to convert the car to manual stick gear. I think keep the F1 parts in case one day will sell the car then can convert it back to F1.
    Is there any negative if I get the car convert to manual from F1?
    Also what parts do I need if will get it done right
  2. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,628
    Elliott Caras
    All you need to know:
    26street and Senshi458 like this.
  3. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,448
    Los Angeles
    No disrespect to my buddy Ken (who was a hugely helpful source of info and tips when I did my conversion) but there's a lot more to it than the video. Pedal box, routing the clutch line, wiring harness removal, several other things. I'll have a thread up soon. The video is a great overview and I referenced it a bunch of times.
  4. ShineKen
    ShineKen F1 World Champ
    19,870
    Southern California
    Nostradamus
    Considering the parts are unobtanium, you should sell him your spare sets and make his life easier. Maybe someone should've told him manual conversion parts are unobtanium before he bought the car.
    Senshi458 and Targatime like this.
  5. 0.0.1.99
    0.0.1.99 Formula Junior
    Jan 14, 2012
    424
    Carolinas
    Ken
    Virtually everything needed is located in the service guide on tables 25 (Clutch release control and pedal support) and 35 (Outside gearbox controls). Understanding the most efficient approach (purchase new, used or pattern, fabricate, etc.) to obtaining the parts is the most difficult part IMO. If an owner is interested in doing the work one day, it is best to get started acquiring the parts now before they are NLA. At that point, the only route is via a company who fabricates everything from scratch.
    Senshi458 likes this.
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,868
    Central NJ
    Dominick
    No mention of tcu reprogramming or a change ?
  7. Senshi458
    Oct 17, 2015
    874
    Norway
    Reza
    I will buy new ECU from 5.2 manual car, in case one day I want to change back my car to F1 then can change back to old ECU :cool:
  8. 26street
    26street Formula Junior
    Jan 30, 2021
    465
    Westchester New York
    Mark k
    What a great video looks like after installing the pedal box most of the other stuff is not that hard to do
    I think it’s well worth doing anyway but knowing you can go back to the f1 if you want is nice option
  9. Senshi458
    Oct 17, 2015
    874
    Norway
    Reza
    I have bought this now:
    Pedal box + clutch master cylinder
    Shifter
    What more do I need now?
    I think need this:
    164540
    Ferrari
    355 (5.2 Motronic)
    GEAR SELECTOR
    160480
    Ferrari
    355 (5.2 Motronic)
    Gear knob
    164392
    Ferrari
    355 (5.2 Motronic)
    FRONT CONTROL BAR FOR GEARBOX
    64234400
    Ferrari
    355 (5.2 Motronic)
    TUNNEL SWITCHES HOLDER PLATE
    176224
    Ferrari
    355 (5.2 Motronic)
    CONTROL UNIT IGNITION
    157491
    Ferrari
    355 (5.2 Motronic)
    ANALOGIC CLOCK
    Here is some picture of stuff I have bought, waiting for deliver
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  10. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,448
    Los Angeles
    That pedal box won't work, it's for the early 355. The late (Bosch ABS) pedal box is basically impossible to find since there were so few manual '98-'99 355's made. The good news is that there are a few parts you can scavenge from it to make your pedal box. I will try to post on how to do this today.
    pilotoCS and Senshi458 like this.
  11. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,448
    Los Angeles
    I would buy the shift gate and knob from Hill Engineering, the factory gate is impossible to find.
  12. Senshi458
    Oct 17, 2015
    874
    Norway
    Reza
    Aha thats bad :( So its still possible use this? Or should I contact the seller and tell him I pass?
  13. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,448
    Los Angeles
    It depends on how much you're supposed to pay for it :) If it's a lot of money, I would pass. But there are parts on it you'll need, specifically the clutch pedal arm, the pedal stop/clutch MC actuator arm (it's one piece), one return spring, the pedal covers, and the clutch MC. So it's got a bunch of valuable parts. I bought a complete pedal box to scavenge parts for like $250, but that was a very good deal. I wouldn't pay $1,500 for a pedal box but for around $500 it's probably worth it.
  14. Senshi458
    Oct 17, 2015
    874
    Norway
    Reza
    I paid 900-1.000 USD for it have paid for it but not picked up, maybe better keep if possible use the parts like you say
  15. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,448
    Los Angeles
    You're going to cut the clutch arm and pedal stop/MC actuator off the donor pedal box and weld them in the correct places on your F1 pedal box. The F1 brake pedal is welded on a shaft that is identical to the manual shaft, except it doesn't have the clutch arm and MC actuator.
  16. Senshi458
    Oct 17, 2015
    874
    Norway
    Reza
    When you do this to your car can you please take pictures and share?
  17. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,448
    Los Angeles
    I've got everything documented, pictures, measurements, etc -- I just need to find time to write it up and post.
  18. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,014
    NE FL
    Ken
    There is a part two explaining that.
    26street and flash32 like this.
