Coolant header tank removal questions | Page 2 | FerrariChat
Discussion in '206/246' started by need4speed, Aug 26, 2015.
  1. need4speed
    need4speed Formula 3
    Nov 3, 2003
    1,616
    Pacific Palisades
    My tank will be repaired today so I'll be putting her back together this weekend. I just started thinking about the process and it dawned on me that I'm probably going to need to bleed the system once the tank is back in, correct? Or if I very slowly pour coolant back into the tank, will this be sufficient to allow air to escape as coolant is reintroduced back into the system?
  2. Nuvolari
    Nuvolari F1 Veteran Owner Silver Subscribed
    Sep 3, 2002
    6,672
    Toronto / SoCal
    Rob C.
    You defiantly want to bleed the system once you have replaced the tank and this is very easy to do:
    NOTE: Make sure your heater is set to FULL HOT so that you are sure to be bleeding the whole system. If not you can get a big air pocket in the system (ask me how I know)
    1 Park the car on a slightly uphill rise and loosen the bleed screw that is on the top of the radiator (passenger side).
    2. Start filling the coolant bottle until it reaches the correct level and leave the rad cap off.
    3. Start the engine and monitor the level of the bottle as well as the coolant bleed screw.
    4. As the coolant circulates the level of the bottle will likely drop a little and eventually coolant will dribble out of the bleed screw. At this stage close the bleed screw and re-fill the bottle to the correct level.
    5. Let the engine continue to run with the rad cap removed and as it builds temperature the level of the coolant bottle will start to rise. At this stage make the coolant bottle has not dropped in level (top up if so) and then re-install the rad cap.
    6. Last step is to return to the front bleed screw on the rad and open it again with the engine running. Be sure to protect your hands as the coolant will be hot but what you are after is a steady flow of coolant without air hissing out. Once you achieve this tighten the bleeder and you are done.
    The whole procedure should take about 5 minutes. Good luck
  3. need4speed
    Nov 3, 2003
    1,616
    Pacific Palisades
    Rob, thank you very much.
  4. Ken Ivey
    Ken Ivey Formula Junior Silver Subscribed
    Jan 6, 2013
    257
    Portland, OR, USA
    Ken Ivey
    If you have to resort to cutting one or all of the hoses to remove them, who has the proper braided hoses for replacement?
    Thanks,
    Ken
  5. need4speed
    Nov 3, 2003
    1,616
    Pacific Palisades
    Thanks for all the advice guys. The installation went like a charm. With the exception of getting a wrench onto the nuts. I just used my fingers for now. I'm thinking I need one of those wrenches that's bent? Anyways, I was unsure about the bleeding but I just let the system run for a long time. And no issues driving to work this morning. So thank you all very much.
    Oh, the radiator shop did a phenomenal job. It looked like a new unit, inside and out!!!
  6. Nuvolari
    Sep 3, 2002
    6,672
    Toronto / SoCal
    Rob C.
    Do try and bleed the system even if the car is not overheating. All you need to do is park it uphill, and open the rad bleed screw while the engine is running. Let some coolant dribble out and you are done. An air lock can cause a sudden heating spike without warning so an occasional bleed is a good idea.
  7. need4speed
    Nov 3, 2003
    1,616
    Pacific Palisades
    Hi Rob, I did bleed the system. Sorry, I should have said I let the system run a long time with the bleed valve open. My bad.
