Countach engine and engine bay refresh | Page 3 | FerrariChat
Discussion in 'LamborghiniChat.com' started by sp1der, Nov 20, 2019.
  1. raymondQV
    raymondQV F1 Rookie
    Aug 22, 2007
    4,063
    Switzerland
    Raymond S.
    #51 raymondQV, Jan 3, 2020
  2. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    Jim sure will sort some pictures out over the week-end for you, all I know is the standard location is a right pain for service tucked behind the vac tank and air filter housing, I will be moving it and the fuel lines for a more sensible set-up.
  3. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #54 sp1der, Jan 5, 2020
  4. MiuraP400
    MiuraP400 Formula Junior
    Feb 3, 2008
    955
    Arizona
    Jim
    Thanks Raymond and Simon, it looks like the four screw filter king is the way to go for a 5000S. I agree the location is a bear to get too.
    Cheers Jim
  5. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    There is probably space down near the fuel pumps or in front of the vac tank will study more easily serviced location.
  6. raymondQV
    raymondQV F1 Rookie
    Aug 22, 2007
    4,063
    Switzerland
    Raymond S.
  7. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #58 sp1der, Feb 2, 2020
    Well got the extension pipes straightened out, or at least as good as when they were manufactured, from images looks like a quicksilver system as for each bend there is some squashing of the pipes which is consistent with the quicksilver manufacturing methods, a load of fasteners ready for re-plating I prefer where possible to wirebrush the fastener clean, in some instances this is not always possible. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    DaniT, Peter K., EarlyCat and 2 others like this.
  8. joe sackey
    May 23, 2006
    57,525
    Southern California
    Joe Sackey
    If you pay Quicksilver enough money for a custom system, they can manufacture perfect mandrel bends in the pipes for headers & exhausts.
  9. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #60 sp1der, Feb 2, 2020
    Just having a laugh at the crazy prices for some parts - how about £84.21 for a standard M35x1.5 lock nut for the diff input shaft (item 23). Lamborghini now only seem to supply standard nyloc ring nuts not the original lock nuts. Image Unavailable, Please Login
  10. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #61 sp1der, Feb 3, 2020
    Sump now fully stripped, the engine clearly has been to pieces before as has the sump by the looks of it as the large ring nut clearly had been re-used as the original staking position was not aligned with the slot it had just been hammered into the thread to try and stop rotation. The ring nut retaining the splined collar was a PITA to get off even with an impact gun as the washer under it has a very fine dimpled pattern to stop anti rotation as well as it being a proper locking nut, the OE Lamborghini replacement is just a Nyloc ring nut. Image Unavailable, Please Login
  11. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #62 sp1der, Feb 26, 2020
  12. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #63 sp1der, Mar 1, 2020
  13. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    Will be time to get ordering some big bits soon, Will be going with new higher compression pistons just debating now on what to do with liners, either re-bore to 86mm, or just get new Westwood liners to original dims. Just concerned with over-bore these are getting a bit on the thin side at 1.75mm wall thickness at the base. Manley will be making new stainless valves. Hopefully Omega will be able to make the pistons.
  14. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #65 sp1der, Mar 15, 2020
  15. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    New engine bay harness on the way as well from Autosparks who now have the full RHD harness patterns for an LP5000s.
    EarlyCat and Spyder-Man like this.
  16. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #67 sp1der, Apr 11, 2020
    adesalos, Aficior, Peter K. and 3 others like this.
  17. Downdraft1
    Downdraft1 Formula Junior
    Nov 13, 2008
    804
    Looks like your doing a great job! Keep up the good work!
    Spyder-Man likes this.
  18. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    Engine block all cleaned up the same way, the castings for the block and heads have a slight purple tinge to them. Also started working up a push type clutch conversion which I believe can be made to work with a 365BB clutch assembly and a Tilton CSC, that simply becomes a bolt on kit.
  19. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #70 sp1der, Apr 14, 2020
    Just out of curiosity had a quick look at the release bearing, if you are careful the dust shield is easy to prize off working round the circumference with a Stanley knife blade to pop it up, this then allows the bearing to be re-greased, probably half the reason these bearings go bad is lack of lubricant as there is not a lab Image Unavailable, Please Login rynth seal. I will pop an o ring under the seal at least in an effort to keep the grease in. Worth checking at your next clutch service as it really is a 5min job that could save you thousands on the replacement of this part.
    Spyder-Man and Jalpa_Mike like this.
  20. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    It appears with some very small modifications to the cover housing (basically to dowel locations) that a BMW E34 M5 clutch will bolt straight up to the flywheel, couple that to a new flange for the guide tube to house a Tilton release bearing and looks like there is a viable route to a push type clutch - just waiting on some feedback from a supplier in the UK to fully confirm.
    Whilst the old clutch can be rebuilt a number of times, eventually the fingers fatigue at the ends where the release bearing digs in and the release bearing also has a finite life. The current cost of these parts is a joke even taking into account low volumes and L tax.
  21. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #72 sp1der, May 23, 2020
  22. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    After a bit of help has anyone got pictures of the oil cooler lines and where they run in the front wheel arch? Not sure my lines are in the right place want to get it right now I have swapped them out which is a fun job!
  23. It's pretty tight. Beyond the cooler, I can't see anywhere the lines go. They are not visible under the fender (when looking up past the tire). Do they run inside of the rocker panel?
  24. raymondQV
    raymondQV F1 Rookie
    Aug 22, 2007
    4,063
    Switzerland
    Raymond S.
    The oil lines are passing through the tubular frame section, the triangle under the sill, but don't have a Picture at hand currently.
    There must be a hole in front of the water radiator where they dive.
