Countach engine and engine bay refresh | Page 4 | FerrariChat
Discussion in 'LamborghiniChat.com' started by sp1der, Nov 20, 2019.
  1. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    Got the lines routed from the engine bay to the front and up behind the heater matrix, I assume they pop out at the end of here and route around the headlamp motor, for whatever reason however on my car there is a hole further up in the liner panel that they both pass through which gets the lines close to the upper wishbone, will get a picture posted up as I don't think it is right.
  2. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #77 sp1der, May 28, 2020
    I believe the hoses should exit on top of the chassis rail and loop under the headlight headlamp lifting motor not through the hole that is currently there, can understand why this is so as the stainless braided hoses fitted previously would not be flexible enough to make that bend, the new ones are. Image Unavailable, Please Login
  3. I think you are correct, they definitely go up on top. Mine are hidden by the inner fender well.
  4. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    Not a biggy to sort hard job done routing through chassis.
    Spyder-Man likes this.
  5. Redlambo
    Redlambo Formula 3
    2,417
    Pendergrass GA
    Vic Woloschinow
    #80 Redlambo, May 29, 2020
    I would reroute them properly.
    The wheel / tire may rub on them while turning and they could rupture.
    If this were to happen you would dump hot oil inside the wheel well all over the tire and brakes.
    Not good, as you not only could loose traction you also have a fire hazard as well as the possibility of starving the engine for oil.
    Below are a few photos of the proper routing of the oil lines. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    joe sackey likes this.
  6. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #81 sp1der, May 29, 2020
    Thanks for the info, yes I will re-route, Image Unavailable, Please Login I think they come over the chassis rail between the plates by the headlight motor are, and then are fully guarded by the inner wheel house panel.
  7. raymondQV
    raymondQV F1 Rookie
    Aug 22, 2007
    4,063
    Switzerland
    Raymond S.
    I would guess the holes are to attach the holders for the oil hoses.
  8. The hoses are fully guarded by the inner wheelhouse. There is no visible hose when I look up at mine, which is on a lift.
  9. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    Cool, thank you at least this bit is easy after the knuckle grazing job rear to front :)
    EarlyCat likes this.
  10. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #86 sp1der, Jun 10, 2020
    Just taken off one of the inlet cam sprockets as was curious as to part number as I have inlet cams with approx 10.5mm lift. Seems a strange number? Image Unavailable, Please Login
  11. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #87 sp1der, Jun 12, 2020
    Curious as to what the 009 is at the end of the number? Exhaust cams are 007. Looks as if original numbers from part book have been replaced by new ones. Image Unavailable, Please Login
  12. MiuraP400
    MiuraP400 Formula Junior
    Feb 3, 2008
    955
    Arizona
    Jim
    From everything I have seen the 13171 is a standard European spec cam. The other part numbers listed could be FI cams. I don't know what the 009 is, it is not common but some manufactures list the print revision number in the part number.
    Cheers Jim
  13. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    They seem higher lift than standard as I believe inlet were 9.5mm valve lift and exhaust was 8.4mm, these are more like 10.5mm inlet and 9.5 exhaust even accounting for lash adjustment.
  14. MiuraP400
    Feb 3, 2008
    955
    Arizona
    Jim
    The part number is stock but they could be reground to a new profile. I have measured three sets of cams taking a measurement every 5 degrees so I have some good data. One set is a custom grind that was done by Iskydarian (spelling?), it was an emissions profile for a FI engine. They made 3 sets of cams in late 1984 for Lamborghini of North America. One set was a standard European spec I believe it is the part number you have. The last set is a custom grind with a higher lift and a shorter duration. The isky cam had it's identification vibropeened on the cam between cylinders 5 and 6. You had to look close to see it. Your photo shows the stock identification. The custom high lift cam is vibropeened on the same surface as the factory part number. My recommendation would be to look the cams over for signs of identification from a regrind. Follow up on the identification if you find it. Next I would double check the lift measure, if it is still high I recommend plotting the complete lift profile taking measurements every 5 degrees. I recommend every 2 degrees for the take up ramp. You will need the ramp data to establish the valvelash you need.
    Cheers Jim
    DaniT, joe sackey and EarlyCat like this.
  15. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #91 sp1der, Jul 29, 2020
    EarlyCat and Peter K. like this.
  16. MiuraP400
    Feb 3, 2008
    955
    Arizona
    Jim
  17. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    Possibly, just keeping things moving forward is hard enough in the present unfortunate climate. On my 308 with the nail head valves picked up close to an 18% improvement.
  18. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #94 sp1der, Jul 30, 2020
    EarlyCat and Tu160bomber like this.
  19. What size pump jets are you running?
  20. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    45's, for some reason whoever rebuilt the carbs last time has taken the bottom parts off so the additional spray was not in the airflow - very odd
  21. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #97 sp1der, Aug 1, 2020
  22. The one on the right is what I'm familiar with, is the one on the left the correct one?
  23. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    Hard to tell as manual shows one on left, will try each variant as both are 45's
  24. MiuraP400
    Feb 3, 2008
    955
    Arizona
    Jim
    My car has the one on the right. I am more use to seeing the one on the left in other cars.
    Cheers Jim
