Countach engine and engine bay refresh | Page 5 | FerrariChat
Discussion in 'LamborghiniChat.com' started by sp1der, Nov 20, 2019.
  1. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #101 sp1der, Aug 5, 2020
    New liners arrived from westwood liners, the new bearing shells from Lamborghini less so, 3 bearings will need to go back due to excessive burrs, chipping and contamination of the surface...... less than impressed. Image Unavailable, Please Login
  2. raymondQV
    raymondQV F1 Rookie
    Aug 22, 2007
    4,063
    Switzerland
    Raymond S.
    Typical, we faced the same in the past... is called NOS, in reality Garbage
  3. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    They should be new as were no back order for quite a while, zero care for quality control both at the manufacturer and Lamborghini, this is why I generally source aftermarket as quality and materials are generally far superior to factory spares.
  4. raymondQV
    raymondQV F1 Rookie
    Aug 22, 2007
    4,063
    Switzerland
    Raymond S.
    I would bet these were NOS, check for the VW sign (Vanderwell - not Volkswagen) since they were the original supplier back in the days.
    And you are right, aftermarket is in many cases much better quality.
  5. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    Yes they are Vandervell for the mains, will see how Eurospares/Lamborghini react as not willing to accept these parts.
  6. Redlambo
    Redlambo Formula 3
    2,417
    Pendergrass GA
    Vic Woloschinow
    The correct ones for the Countach engine is the one on the right as they were especially made for this engine.
    The reason they are not like the ones on the left which protrude into the venturi area of the carburetor, is because at high RPM's the engine can start to siphon additional gas through that style accelerator pump jet and cause a overly rich mixture.
    Do not lose the ones on the right as I doubt you will ever find them unless you know someone at the Lamborghini factory.
    Furthermore they are the ones that need to be in the carburetors because of the reason mentioned.
    Sincerely Vic
    joe sackey likes this.
  7. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
  8. Redlambo
    Redlambo Formula 3
    2,417
    Pendergrass GA
    Vic Woloschinow
  9. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #109 sp1der, Aug 27, 2020
    Last of 4 nos bearings obtained that are getting very hard to find, this one a bargain at 49euros. Pistons finally on the way so hopefully only a few weeks away from it all going back together. Image Unavailable, Please Login
    Spyder-Man and EarlyCat like this.
  10. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #110 sp1der, Sep 24, 2020
    Busy day today, heads dropped off for guides and seats and new higher compression pistons from cps in Italy, great job and quite quick turn round, quite a bit lighter too.
  11. What compression are you planning on? Those look great.
  12. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    Will be a tad under 10:1
    EarlyCat likes this.
  13. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    20g a piston lighter than oe as well
  14. Nice. Reducing rotating mass is good.
  15. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    Hopefully will have all the bits back in 4-5 weeks so re-assembly can begin, the pistons were bought via MV Special parts in Italy who provided great service and did all the interface with CPS to avoid any language problems, contact there is Max who speaks perfect English, from order to pistons arriving was 3 weeks.
    Ellagirl and Spyder-Man like this.
  16. jjeffries
    jjeffries Formula Junior
    Sep 4, 2012
    254
    Connecticut
    John Jeffries
    Simon your projects are always excellent to follow. I remember when this car was painted.
  17. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #117 sp1der, Nov 3, 2020
  18. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #118 sp1der, Nov 14, 2020
  19. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #119 sp1der, Nov 24, 2020
  20. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #120 sp1der, Dec 1, 2020
    EarlyCat and Spyder-Man like this.
  21. Ellagirl
    Ellagirl F1 Rookie
    Aug 20, 2014
    2,736
    Florida
    Nils johnsen
    Qv is 944/928 Porsche,AL170X poss also used on other brands
  22. The 928 Alt did not fit on my 5000s. Much bigger.
    Oddly I saw an Opel Cadet yesterday. Have not seen one for years. Pretty cool design.
  23. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #123 sp1der, Dec 17, 2020
    Spike and Peter K. like this.
  24. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #124 sp1der, Feb 5, 2021
    Engine work progressing slowly, all valve guides now out, will be getting new ones custom made. As it's an early car the guides are cast iron. Image Unavailable, Please Login
    Spyder-Man likes this.
  25. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #125 sp1der, Apr 6, 2021
