Countach engine and engine bay refresh | Page 7 | FerrariChat
Discussion in 'LamborghiniChat.com' started by sp1der, Nov 20, 2019.
  1. randomlambo
    randomlambo Formula Junior
    Feb 3, 2013
    396
    RI & MA border
    DT
    If you recall how much was the wear on the liners? We found mine to be minimal wear, a few are slightly out of round, and we found they have inverse taper? They are wider at the bottom rather than at the top.
    Did you end up re-boring to the next size up or considered that option?
    Finally, is there a link to a Dino manual online somewhere? I've been spending the last two weeks translating the first half of the Lambo L406 manual to English :)
  2. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    I had a couple of scored liners, and the rest would have needed an oversize re-bore which sourcing pistons for became a touch tricky, so it was easier to get new standard size liners and new pistons. Will try and get the relevant pages of the Dino manual scanned.
    randomlambo likes this.
  3. randomlambo
    Feb 3, 2013
    396
    RI & MA border
    DT
    Thanks Simon for the info. I have looked at the options with replacing the liners and the worry from the machine shop was that they are glued in and they need special handling to remove and replace with new ones.
    Also it looks like Lamborghini wants around 1000 UKP per liner! for these, but I think they can be had aftermarket for less (?).
    The shop I talked to was willing to bore/hone the block for around the same price and recommended we custom make the pistons + rings. In the US this appears to be around 2000-2500 UKP for the 12 pistons/matching rings and they would be made to the size of the overbore (+0.2 mm?).
    Do you have any concerns with this approach or any other recommendations?
    [Sorry I don't want to hijack your thread - we can take to PM but I think many would benefit from your wealth of knowledge]
  4. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    As yours is an LP400 there would be no issue with over-boring and going with oversize pistons, the liners on the 4.0L engines were shrunk into the block (the block was heated and then the liners dropped in), on the LP5000s they are a push fit at room temp with a spacer ring so are a bit easier to remove and replace. The shop needs to make sure they use a torque plate when doing this.
    randomlambo and DaniT like this.
  5. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #155 sp1der, May 4, 2021
  6. MiuraP400
    MiuraP400 Formula Junior
    Feb 3, 2008
    955
    Arizona
    Jim
    FYI bearing clearance is a function of the crank diameter. As a rule of thumb use 0.001 inches of diametral clearance per inch of shaft diameter. This rule works for a rotating shaft down to one inch in diameter. Below one inch use 0.001 inches of clearance.
    Cheers Jim
  7. randomlambo
    Feb 3, 2013
    396
    RI & MA border
    DT
    What is the engine block color and was this paint originally?
    Thanks!
  8. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    As cast aluminium it has a slight purple tinge. Will be left that way.
  9. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #159 sp1der, Jul 29, 2021
  10. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #160 sp1der, Aug 18, 2021
    Spyder-Man likes this.
  11. Adamo
    Adamo Karting
    May 17, 2014
    142
    CANADA
    Adamo Cerquozzi
  12. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    I had them made by Arrow Precision in the UK, I took 0.5mm out of the top pad, so will run slightly thicker valve shims. Pad depth is now 3.5mm instead of standard which is 4.0mm. Plus with modern materials, design they are just much better optimised.
    Adamo Cerquozzi likes this.
  13. Adamo
    Adamo Karting
    May 17, 2014
    142
    CANADA
    Adamo Cerquozzi
    You wouldn’t have the part number would you?
  14. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    Will dig out the invoice to see if there is a reference.
  15. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #165 sp1der, Oct 7, 2021
    Spyder-Man, Peter K. and EarlyCat like this.
  16. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #166 sp1der, Oct 25, 2021
    white out, Peter K., EMILIO and 2 others like this.
  17. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #167 sp1der, Jan 2, 2022
  18. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #168 sp1der, Jan 11, 2022
    EarlyCat, Spyder-Man and Peter K. like this.
  19. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    #170 sp1der, Jan 17, 2022
    EarlyCat and Spyder-Man like this.
  20. Spyder-Man
    Spyder-Man Formula 3
    May 11, 2004
    2,098
    Rob
    Ohh you rebel you! To match the interior ?
    EarlyCat likes this.
  21. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    They were red before but gloss red so just changed to crackle.
  22. Spyder-Man
    May 11, 2004
    2,098
    Rob
    OK, obv black originally, watch out, you may have comments about originality soon ! :D
  23. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    I spoke to Del Hopkins a while ago and he remembers the car being delivered and his recollection was that the car had red wheels when delivered.
  24. Spyder-Man
    May 11, 2004
    2,098
    Rob
    Red exterior paint was original right?
    Red wheels too, era of excess. love it. Any period shots available do you know?
