Countach Technical Thread & Questions | Page 12 | FerrariChat
Discussion in 'LamborghiniChat.com' started by jollygood, Mar 18, 2013.
  1. jollygood
    jollygood Formula 3
    Oct 24, 2005
    1,096
    jollygood
    Thanks Mikael.
    Think I first need doing as you suggest, twist the rotor slightly to check the mechanical advance.
    Car was running well prior to misfire occurred.
    If the mechanical advance is stuck, will cap internals look like in the above picture?
    Or can it just be that timing is slightly off?
    Car is a 1986 Quattrovalvole and yes, the MSD is a Multispark system.
  2. mikael82
    mikael82 Formula Junior
    Nov 18, 2007
    869
    Finland
    Mikael
    Timing wheel is under pointer, inside distributor, if it is stuck to one end, allthough it does not move that much, timing and pointer will point towards where ever it is stuck.
    But these are just my random thoughts from these symptoms, have fun!
    btw, just remember; I broght some of Countach photos and instructions here to this forum.
    http://www.ferrarichat.com/forum/boxers-tr-m/451351-my-512bb-diy-thread.html
  3. Peter K.
    Peter K. F1 Rookie Silver Subscribed
    Jan 9, 2004
    4,448
    Connecticut
    Peter K.
    Can someone post a picture of the Countach fuel tank(s) out of the car. More than one angle would be great.
  4. MiuraP400
    MiuraP400 Formula Junior
    Feb 3, 2008
    949
    Arizona
    Jim
    Looking at the inside of the cap the arc marks are 60 crankshaft degrees out. The advance weights at best could only account for 20 crank degrees. I believe the distributor was set up incorrectly. Judging by the markings it appears half of its life it was set correctly and half it was incorrect. I cannot tell based on the cap if it is correct or incorrect now. I recommend verifying the setup as is now i.e. the number one cylinder goes to the number one location on the cap along with the number one cylinder on its firing stroke with magnetic trigger in the right location.
    Cheers Jim
  5. silverlambo
    silverlambo Karting
    Oct 16, 2012
    93
    Rancho Santa Margari
    Dan Ellis
    My manual says the 5000s holds 13.5 quarts of oil, I know this is not correct. Can someone tell me the official number
  6. Spirit of Italy
    Spirit of Italy Karting
    Jan 3, 2015
    143
    Norway
    Hans S
    Any specific angle or just a pair of tanks?
  7. Peter K.
    Jan 9, 2004
    4,448
    Connecticut
    Peter K.
    Thanks Hans, Chad B had sent me photos back in he spring.
  8. randomlambo
    randomlambo Formula Junior
    Feb 3, 2013
    379
    RI & MA border
    DT
    Can somebody confirm the control arm lengths such as shown in the picture?
    This is for a LP400S; I think the suspension is closer/similar to a LP500S rather than a LP400?
  9. GraemeS
    GraemeS Karting
    Jun 6, 2005
    166
    Auckland New Zealand
    Graeme Stebbing
  10. randomlambo
    Feb 3, 2013
    379
    RI & MA border
    DT
    Very cool shots.
    For the experts - have there been different paint schemes of the gas tanks over the years? The ones in an early S2 LP400S are gold-color painted.
  11. Chadbourn Bolles
    Chadbourn Bolles Formula Junior BANNED
    Aug 5, 2005
    820
    Leesville, SC USA
    Chadbourn Bolles
    Hope this helps. See the attached.
    Chadbourn Bolles
    803 532 6257
    803 798 3044
  12. Countachqv
    Countachqv Formula 3
    Apr 25, 2007
    2,350
    USA/France
    I have such a stupid question after confusing myself in an embarrassing way but I just don’t want to screw this up.
    This winter, I had to remove my dead battery and I ordered a new Interstate.
    I would swear my prior optima red top battery, which I dumped 1 month ago, had the positive on the passenger side terminal, just like the new interstate on the pictures below.
    But here is the confusion. I realize the wire that is supposed to go to the positive on the passenger side is actually connected to the car's chassis (wire with quick disconnect circled red). Are the Countach positive grounded?
    If not then I am not sure what is going on and how I will handle this because the other wire that I think connects to the battery negative (yes it has some red wire to confuse me more) is not long enough to go to the positive terminal on the far passenger side. Also it appears my battery tender positive wire is connected to the chassis.
    I should have taken picts or not remove the old battery until getting the new one. I dont know why I am so confused on such a simple job.
  13. Jalpa_Mike
    Jalpa_Mike F1 Rookie
    Apr 2, 2004
    3,019
    Sequim
    Michael Wilson
    Definitely a negative ground on the Countach.
    I use an Interstate also, an MT-24F and as you can tell the terminals are reversed on mine.
  14. Spyder-Man
    Spyder-Man Formula 3
    May 11, 2004
    2,097
    Rob
    My postive is also on the right hand side on my QV, as you look at it, standing in front of the car.
    R
  15. Countachqv
    Apr 25, 2007
    2,350
    USA/France
    arghh! I got an mtp34. when i bought the car it had an MT34. So the terminals are reversed on the MTP34? i asssumed if mt34 was good so would mtp34. or may be it comes with both configurations
  16. Ellagirl
    Ellagirl F1 Rookie
    Aug 20, 2014
    2,736
    Florida
    Nils johnsen
    I use a Deka 734MF ,wich i turned installed with the poles towards the back , this way the compartment looks uncluttered and clean,and the pos pole remains on the driver side, also i use a 1/2 inch stud style shoe,wich makes exelent countact and easy dissconect.
  17. gday
    gday Formula 3
    Sep 10, 2004
    1,086
    CA, USA - NSW, AUS
    Mick
    +1 for the MT-24F.
    The proper/original fit for a Countach is a group 24 - a group 34 is original for the Diablo. Using interstate, for the group 24 you want the F suffix for proper/original terminal orientation. Using the group 34, you would want the R suffix, again for proper/original terminal orientation.
    See: http://www.interstatedealers.com/ibcatalog/common/automotive_spec.pdf
    -mick
  18. Countachqv
    Apr 25, 2007
    2,350
    USA/France
    I got it now. There is an option for terminal location which i did not specify so of course i got the wrong one. I assumed it would be correct as this was the model i bought the car with. Thanks to all of you guys. You are the best.
  19. DRAnderson
    DRAnderson Rookie
    Dec 19, 2014
    9
    Colorado, USA
    David Anderson
    I have a 19system to a PerTronix ignition system. I am looking for advice from people that have tried this on the 3.292 liter engine. Ease of installation? Cost? Effect on tachometer? Reliable? Increased performance? etc.? I have 2 distributors -- that must complicate things.
    I am leaning toward PerTronix as I do not want a system that can be noticed -- I want to keep the car as nearly stock as I can and I believe the PerTronix system adds a wire but otherwise fits within the distributor cap.
    David
  20. randomlambo
    Feb 3, 2013
    379
    RI & MA border
    DT
    One question for the group - can somebody shed some insight about the typical oil pressure that goes through the Countach hoses to the radiator and through the rest of the system?
    We're looking to pressure test the entire system before putting the engine back in the car and connecting everything up.
    Thanks.
  21. raymondQV
    raymondQV F1 Rookie
    Aug 22, 2007
    4,059
    Switzerland
    Raymond S.
    It depends if QV or not.
    LP400-LP5000S have a high pressure circuit with max 10 bar, the QV engine has a separate low pressure pump.
  22. randomlambo
    Feb 3, 2013
    379
    RI & MA border
    DT
    This is a Lp400S; so testing would have to be with a compressor if it was at that high pressure. 10 bar is ~150 psi so that sounds quite high?
  23. Chadbourn Bolles
    Aug 5, 2005
    820
    Leesville, SC USA
    Chadbourn Bolles
  24. randomlambo
    Feb 3, 2013
    379
    RI & MA border
    DT
    Quick request for the group - is there a list of the correct hose clamps that are used on the Countach?
    Thank you
  25. EarlyCat
    EarlyCat Moderator Moderator
    Mar 9, 2005
    9,956
    Shot gun shack n another prt of the World GS KW KY
    Any source for cv joints? The boots are 930 Porsche from what I've read.
