Couple of questions 2004 360 Spider | FerrariChat
Discussion in '360/430' started by 8202632, Dec 13, 2020.
  1. 8202632
    8202632 Karting
    Jul 9, 2017
    168
    Memphis, TN
    CDC
    My car is running cold it seems. After 30 min of driving are the attached temps low? If so what could it be? Had a major done last year.
    second, my interior heat is starting to not blow hot. It’s intermittent but on chilly mornings not fun. Any ideas there?
  2. EastMemphis
    EastMemphis Formula 3
    May 25, 2019
    1,880
    Memphis, TN
    I suspect your thermostat has stuck in the open position.
    sparetireless, E60 M5 and armedferret like this.
  3. armedferret
    armedferret Formula 3
    Mar 24, 2018
    1,343
    Maryland
    Mark
    Definitely an indicator of a thermostat that's stuck open. 65 pound on eurospares, 125 and change on ricambi.
    EastMemphis likes this.
  4. fotostars
    fotostars Formula Junior
    Feb 6, 2015
    345
    Bay Area
    170 is normal operating temp... Not sure there is an issue here... Those reading are similar to mine after reaching full operating temp (and driving)
    SoftwareDrone and Apollo 11 like this.
  5. 8202632
    8202632 Karting
    Jul 9, 2017
    168
    Memphis, TN
    CDC
    Ok 10-4. Appreciate the feedback I’m used to my others running at 205-212
  6. armedferret
    Mar 24, 2018
    1,343
    Maryland
    Mark
    Open thermostat can still let the car reach normal op temp, just takes a while for it to get there. The other possibility is that the heater core is clogged. it's occasionally possible to push water through the reverse direction and remove whatever's gunked it up, but that doesn't always work. If it's been a while since coolant was flushed, and/or the heater core and thermostat haven't been replaced, i'd replace the thermostat first, and if the heater issues continue you'll be needing to at least try flushing the core (but be ready to replace entirely).
    And yes OP, both mine and my wife's daily drivers are typically in the 190-220 range for water and oil temp both, depending on weather.
  7. EastMemphis
    May 25, 2019
    1,880
    Memphis, TN
    At the temperature shown on the oil temp gauge, it would be difficult to properly check the oil level.
  8. fotostars
    Feb 6, 2015
    345
    Bay Area
    I'm still of the "opinion" that your readings are normal and not to worry about. The 360 engine runs "cooler" than other cars I've had. I was surprised too when I first got my car. It's a 170* instead of a "standard" 185* thermostat.
    This is coming straight from the Workshop Manual for reference (copy/paste here):
    Cooling cycle
    Fill the system as described (B 5.07). Before reaching 77°C - 170.6°F (B 5.03), the thermostatic valve is closed
    and the radiator circuit is temporarily cut out. The cooling mixture flows out from the engine through the water
    outlet manifolds (14) and cools the cylinders and heads through the special slits and channels. The coolant
    then flows through the exchanger (15) and into the centrifugal pump (1).
    Over the 79°C - 174.2°F threshold (B 5.03), the thermostatic starts opening, thereby allowing the mixture to pass
    and flow to the radiators. The mixture then flows through the line (9A) and into the radiators (6) and (5). Once
    cooled down, it will flow into the engine through the line (9B): the cycle will be so repeated.
    System
    The engine is cooIed by a pressurised circuit system (0.98 bar) through circulation of an anti-freeze mixture.
  9. SilverF360
    SilverF360 Rookie
    Feb 9, 2011
    20
    Great Falls, VA
    Michael
    That's also about where my 05 spider sits while cruising.
    Apollo 11 likes this.
  10. ihavearedferrari
    ihavearedferrari F1 Rookie
    Nov 23, 2007
    3,316
    Adam
    That is normal temp whilst driving. Let it idle and it will hit much closer to 190 before going back to your photo.
  11. Jda550911
    Jda550911 Rookie
    Jul 1, 2020
    36
    Florida
    James
    I have an 09 430 and I was thinking the same thing you are. Even after banging around some corners and over a bridge with 8k rpm shifts the coolant temp never gets near 210. Seems like its under 200f even. This seemed weird seeing as my 911's temps regularly get over 212 oil and just over 200 coolant, with similar driving.
    Going in for yearly maintenance with a trusted mechanic that has the same exact car in a couple weeks, so will update the thread if he says these temp reading aren't normal.
    Different car for sure, but funny i thought the same thing and have the same readings.
  12. 24000rpm
    24000rpm F1 Rookie
    Ah..... what? I don't see any problem with the temp readings in the photograph。 Why?
  13. sparetireless
    sparetireless Formula 3
    Nov 2, 2003
    1,596
    on the heater, rotate the fan know back and forth a few times, it should fire up.
  14. 8202632
    8202632 Karting
    Jul 9, 2017
    168
    Memphis, TN
    CDC
    Thanks y’all for the replies. I’m going to leave as is for now then. Have to get a couple of yearly maintenance items done so I will ask them to check out the thermostat.
    is there an easy way to check and diagnose the thermostat? Or just secure the part, replace, and see if it makes a difference? Thanks!
  15. derekmines
    derekmines Formula Junior
    Dec 12, 2013
    284
    Melksham, UK
    Derek
    Mine's sat at the same temps as yours whilst driving for the whole 7 years I've had it, even in the heat of Dubai it seldom got much higher than you're showing unless I was in very slow moving traffic.
    The 360 is one of the coolest running cars I've ever had.
  16. 360+Volt=Prius
    360+Volt=Prius Formula 3
    1,762
    Western Mass
    Raimondo
