cracked ignition wires | FerrariChat
Discussion in '456/550/575' started by DZ-96, May 7, 2013.
  1. DZ-96
    DZ-96 Formula 3 Silver Subscribed
    Mar 7, 2010
    1,907
    South Germany
    Daniel
    Hi
    During a larger service, i changed the ball bearings from the lower timing control gear wheels, the oil pump chain with tensioners, the seal rings of the camshafts, some new silicone water hoses (the small 7 or 8 mm hoses and the short 21 mm hose) and finally the timing belts with tensioner bearings, i saw, that the ignition wires are very hard and with cracks.
    I think this is a common problem, the rubber is old and the heat from the engine makes the rest, so you should check the wires.
    The car is a 1999 model with 52000 Km.
    Chain an tensioners were like new, camshaft seal rings began to lost some oil.
    So i bought 9 meters of Beru silicone copper cable (55 Euro) with 30 sawtooth connectors (12 Euro) and a special crimping tool from knippex (24 Euro).
    Important : crimp the connectors to the same diameter as the old connectors so you can conncect them inside the ignition connector. If the diameter around the wire is larger, you cannot connect it into the ignition connector. 2 hours for the ignition wires, now like new.
    Also i found the cause for the rrrrrrrrrr noise between 2200 and 2500 rpm.
    One of the tensioner pulleys (water pump, steering pump) had a bearing seat which was run out about 0,3 mm.
    So the bearing had tolerance.
    Thanks to Ron (rmfurzeland) for his help and tipps !!!
    Daniel
    F456M likes this.
  2. DZ-96
    Mar 7, 2010
    1,907
    South Germany
    Daniel
  3. philfrench
    philfrench Karting
    Jan 3, 2012
    104
    France
    I bought and install genuine F parts from factory (about 1200euros) and like on my 456M the rubber was a little craked.after installing the ignition harness ,the iddle seems to be very constant without any missfire like it was a little .Very important for me for a 13 years old car ( like the two accesory pulley bearings ,hoses ,for 456 gas accumulators,new manifold gasket and ...engine mounts).
    Congratulation for your perfect ignition harness...at what price?if not indiscret
  4. DZ-96
    Mar 7, 2010
    1,907
    South Germany
    Daniel
    Hi
    I have updated the prices for the parts.
    9 meter silicone copper wire : 55 Euro
    30 connectors (6 more for testing) : 12 Euro
    crimping tool : 24 Euro
    Daniel
  5. philfrench
    philfrench Karting
    Jan 3, 2012
    104
    France
    Congratulation for your whole work...And happyness to do yourself a nice job.For the Fchatters can you give the adress of your suppliers please ?this new ignition harness is a must for ours cars.Regards
  6. DZ-96
    Mar 7, 2010
    1,907
    South Germany
    Daniel
    Bought the parts at the local parts dealer (here in Germany) for common car parts.
    Daniel
    F456M likes this.
  7. bay
    bay Formula 3
    Mar 13, 2011
    1,275
    Belgium
    Bernard
  8. philfrench
    philfrench Karting
    Jan 3, 2012
    104
    France
    Many thanks from the community,,,Now i will have to repair a camseal above the alternator ,it was too oily and the diods failed one after the other in few kilometers...Red battery warning lights ( two) and airbag ,asr ,and .stop engine and ....breakdown vehicle (just behind us in the traffic!!)
    I thought to fix the leaking camseal problem with the cambelt in few mount but now i ll do that in few days!! With the Marine denso alternator from Cribj indication indeed !! Many thanks from the chat because when a failure like this happen you say ´i had better to take my M3'..
  9. maranello72
    maranello72 Formula Junior
    Jul 4, 2009
    354
    Munich, Germany
    Stefano
    Daniel,
    once you've crimped the sawtooth connectors onto the cables, do you simply slide them inside the spark plug and ignition coil headers? How are the headers fastened to the cables?
    Thanks,
    Stefano
  10. DZ-96
    Mar 7, 2010
    1,907
    South Germany
    Daniel
    Hi Stefano
    When you pull the wires out of the spark plug and ignition coil headers, you should turn them against the clock, when you connect them, you should turn with the clock.
    It helps to connect/disconnect when turning into the right direction (like a screw).
    Daniel
  11. rmfurzeland
    rmfurzeland Formula Junior
    Jan 7, 2005
    559
    Houston, TX
    Ron Furzeland
    Daniel,
    Sorry coming late to your thread. If you mean you are replacing the spark plug wires I solved this by using Cribbj Coil on Plug (COP) solution, see this forum or email John direct.
    You throw away the high voltage wires and all their issues and run low voltage to an individual coil on top of each spark plug.
    Regards,
    Ron
  12. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    This is by far the best solution. I've been running John's (Cribbj) COP system for a year now. Put it on and forget about ignition problems forever but you should probably change the plugs every 50,000 miles or so.
  13. bay
    bay Formula 3
    Mar 13, 2011
    1,275
    Belgium
    Bernard
    Beru Distributor and Coil Connector :
    connector 0 300 332 121 5kΩ ( x12 )
    connector 0 300 413 311 1kΩ ( x6 )
    connector 0 300 5513 119 1kΩ ( x6 )
  14. Playframe King
    Playframe King Formula Junior
    Jan 31, 2010
    320
    update on my recent purchase of same parts , from onlinecarparts.co.uk, which is really pkwteile.de - in Germany:-
    0300800023 ignition cable is now £4.13 plus 20% VAT per metre
    0901300002 - connectors are £0.79 plus 20% VAT each
    Standard shipping to UK cost £9.54
    and they gave me 5% off overall.
    Loom is off the car and stripped this evening, hopefully find the time to rebuild tomorrow. pics to follow...
  15. 360modena2003
    360modena2003 Formula 3
    Jul 11, 2009
    2,438
    Are you sure copper wires are the correct ones?
  16. DrJan
    DrJan Formula Junior
    Feb 28, 2015
    553
    Grand Cayman
    Dr Jan P
    How have you solved the interference supression?
    Had you used carbon resistor cables then you could have used the plain copper connectors. Is the sparkplug boot a special one?
  17. Playframe King
    Jan 31, 2010
    320
    see post 13 - Ferrari already solved when first built - not going to revisit - using exactly what was spec'd with Beru part numbers
  18. DrJan
    Feb 28, 2015
    553
    Grand Cayman
    Dr Jan P
    Super! All I needed to know when I undertake that task.
    I am used to restore cars where these things did not matter much, where a valve radio was the height of technology!
  19. r456
    r456 Rookie
    Sep 22, 2018
    1
    Richard
    Hello and thank you,
    i am new here and would like to ask for wiring diagram Motronic 2.7 ignition coils to spark plugs for 1995 456.
    Reg. the silicon beru wire, it is copper and silver coated (prevent corrosion).
    Tks a lot
  20. rviani
    rviani Karting
    Jun 22, 2005
    81
    NJ
    Ron Viani
    Daniel,
    I see you were able to remove the timing cover with leaving the timing gears in place. Can you advise how you did this and what tools you used ?
    Ron
  21. DZ-96
    Mar 7, 2010
    1,907
    South Germany
    Daniel
    Ron, if i remember correct, it was not possible to leave the gears in place.
    The photo was taken after installing the new bearings inside the engine block and assembling the gears.
    Daniel
  22. rviani
    rviani Karting
    Jun 22, 2005
    81
    NJ
    Ron Viani
    Thanks Daniel
