News
Cracked Wheel Inserts
Discussion in '348/355' started by lindsey, Mar 22, 2010.
  1. lindsey
    lindsey Karting
    Sep 20, 2009
    79
    Henderson, NV
    Lindsey Freeman
    #1 lindsey, Mar 22, 2010
    After buying my third lady 98 355 GTS F1 I soon discovered that almost all of my wheel inserts were cracked. Probably due to someone over torquing the lug bolts. I'm happy to report there is an easy fix. This is what I did. Ricambi has the replacements made by Hill Engineering very early 355s use 22mm all the others are 23mm http://www.ricambiamerica.com/product_info.php?manufacturers_id=&products_id=224405
    8.60 each. A 16mm socket to remove 22mm socket to install. Be sure to clean around and in the whole after the insert is removed, I used a little locktite on the insert around the new insert.
  3. 2NA
    2NA F1 World Champ
    Professional Ferrari Technician Consultant Owner
    Dec 29, 2006
    17,752
    Twin Cities
    Tim Keseluk
    Looks good.
    I hope they never have to come out, that green Loctite is as close to welding as you can get.
  4. AceMaster
    Feb 6, 2009
    31,043
    Calling a penalty
    Very inexpensive fix if you ask me.
  5. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    Looks good :)!!!
  6. James-NZ
    James-NZ F1 Veteran
    Jun 26, 2007
    5,760
    Hamilton, NewZealand
    James
    Nice work.
    Thanks for sharing.
  8. Vegas-Guy
    Vegas-Guy Formula 3
    Nov 25, 2007
    1,817
    Austin, TX
    Reg
    Looks great! I'll need to do mine at some point..:( found about 5 total that are starting to crack!
  9. rbellezza
    rbellezza F1 Rookie
    2,733
    Henderson, NV
    Roberto Bellezza
    Lindsey got some extras, hopefully he doesn't need them anymore !
  10. cf355
    cf355 F1 Rookie
    Feb 28, 2005
    4,145
    chris
    Excellent post and pictures.
    I went out and checked my inserts but they are ok for now.....however when they go I will know how to remedy the situation.
  11. PAP 348
    PAP 348 Moderator
    Moderator Owner
    Dec 10, 2005
    86,852
    Mount Isa, Australia
    Pap
    Nice thread! Very informative! :):)
  13. TRScotty
    TRScotty Formula 3
    Oct 12, 2006
    2,419
    Tyler, Texas
    Scotty
    Great info and I love those metal center caps, where did you get those??
  14. Ricambi America
    Sponsor Owner
  15. PAP 348
    PAP 348 Moderator
    Moderator Owner
    Dec 10, 2005
    86,852
    Pap
  16. TRScotty
    TRScotty Formula 3
    Oct 12, 2006
    2,419
    Tyler, Texas
    Scotty
    Thanks Daniel, but you know I just received my replacement OEM caps!! (beautiful, by the way)
    Now I have to add these to the "wish list" LOL!!
  17. lindsey
    lindsey Karting
    Sep 20, 2009
    79
    Henderson, NV
    Lindsey Freeman
    #14 lindsey, Mar 26, 2010
  18. darrenliu
    darrenliu Formula Junior
    Jun 24, 2008
    440
    Melbourne Australia
    Darren Liu
    I have to replace some wheel inserts, but I don't want to Loctite the new ones in just in case they crack again. Do the new ones have to be 'cemented' in? or can I just bang them in with no 'glue' ?
  19. hjp
    hjp Formula Junior
    Feb 23, 2013
    591
    Kansas City, Mo.
    Jerry Peterson
    Just tap them in gently. They don't fit that tight. The lug bolts will hold them just fine without the need for anything else. I have a set used 23mm inserts in excellent condition if you need some.
  20. mseals
    mseals Two Time F1 World Champ
    Sep 9, 2007
    24,468
    Kuwait
    Mike Seals
    Why the loctite?
