Dashboard lights out..partly.... | FerrariChat
Discussion in 'California(Portofino)/Roma(Amalfi)' started by NeroDaytona2020, Jun 15, 2022.
  1. NeroDaytona2020
    Feb 13, 2021
    36
    Szy
  2. 695
    695 Formula Junior
    Mar 19, 2021
    359
    Denmark
    Chris
    Backlight on the yellow rev counter is special - nothing wrong. If you had a black all the light you want, but not on the yellow.
    Other users have posted the 'problem' before, read this answer or this thread
  3. NeroDaytona2020
    Feb 13, 2021
    36
    Szy
    I am pretty sure it was light on the numbers before. This picture is taken when it s normal. Picture taken at same place and same light condition. Image Unavailable, Please Login
    Sent from my LYA-L29 using FerrariChat.com mobile app
  4. 695
    695 Formula Junior
    Mar 19, 2021
    359
    Denmark
    Chris
    I don't have the yellow tacho, but people seem to have 'issues' with the lighting that are not reported with the black ones.
    If it is behaving differently, then it may be one of the led strips behind that is the issue as explained here
  5. NeroDaytona2020
    Feb 13, 2021
    36
    Szy
    Tried everything I could but seems not working (obviously I don't have the gut to take the entire dashboard off...), maybe will send to the dealer... thanks for your reply
  6. Mark Penniman
    Mark Penniman Rookie
    Apr 19, 2023
    6
    Nashville
    Male (M)
    My 2013 has the exact same issue. Yellow Tach with numbers not illuminating. Horse and inner ring still light up and gear indicator functions.
    Taking it to the dealer this week.
  7. Matt Fussell
    Matt Fussell Rookie
    Jan 16, 2020
    10
    Matt Fussell
    Mine had the same issue. Had to be sent off to fix.
  8. Mark Penniman
    Apr 19, 2023
    6
    Nashville
    Male (M)
    Dealer Technician is looking at issue today. Will report back once they have resolution and what the recommended fix was.
  9. Mark Penniman
    Apr 19, 2023
    6
    Nashville
    Male (M)
    Dealer is saying they have to ship the entire cluster assembly to a repair shop in California to have them repair the unit. Will be out for 1-2 weeks.
  10. Mark Penniman
    Apr 19, 2023
    6
    Nashville
    Male (M)
    FAI replaced ribbon light and power supply for the ribbon light. Back in car and working beautifully now.
    Dealer covered the cost. I believe it was $800 for the repair.
    Willl likes this.
  11. Klas
    Klas Formula Junior
    Mar 17, 2014
    364
    Gothenburg, Sweden
    Klas Nilsson
    Hi, Interesting. What exactly is the "ribbon light"?
  12. Mark Penniman
    Apr 19, 2023
    6
    Nashville
    Male (M)
    Willl likes this.
  13. Klas
    Klas Formula Junior
    Mar 17, 2014
    364
    Gothenburg, Sweden
    Klas Nilsson
    Have similar problem, the speedometer back light was dead so I replaced the backlight disc and now it works but the light is weak and it's the same with the tachometer. Can't see the figures well at day time. At night it's visible but I want it to be more enlightened at daytime. There is a light sensor in the middle of the upper part of the windscreen. Maybe that one is bad....who knows...
