355 - Dave Wins! | Page 2 | FerrariChat
355 Dave Wins!
Discussion in '348/355' started by carnutdallas, Mar 3, 2019.
  1. INTMD8
    INTMD8 F1 Veteran Owner Silver Subscribed
    Jun 10, 2007
    6,850
    Lake Villa IL
    Wish you were closer, I'd grab a lane with that Chevy
    :D
    BOKE likes this.
  2. BOKE
    BOKE Beaks' Gun Rabbi Rossa Subscribed
    Jul 13, 2009
    33,965
    600 East Fremont Street
    Lucky
    https://www.atomicmotors.net/Pre-owned-Inventory-1963-Chevrolet-Car-BELAIR-Atomic-Motors-2022388?ref=list
    This Beautifully restored car was built to Power Tour. It has been 4 times with zero issues. This car was a barn find with 43,000 on the odometer when found. Odometer was zeroed when built. Features a 2002 LS1 350hp Corvette engine with matching 4L60E transmission, 3.70 posi-traction gears, custom all aluminum radiator, electric fans, custom tank with Corvette fuel pump, 4-wheel disc brakes with hydro-boost master cylinder, Vintage Air, 100 shot of wet nitrous oxide in the trunk, quick ratio steering, tubular A arms, all original sheet metal, all trim was polished and reanodized, all doors, floors, trunk and quarters were sound deadened, AM/FM/CD player with amp concealed in the trunk, Hotchkis suspension, large sway bars, tilt wheel and cruise control.
    Every part of this car is built to a high, show quality standard. Cost to build was over $120,000.
    INTMD8 likes this.
  3. INTMD8
    Jun 10, 2007
    6,850
    Lake Villa IL
    Yes I knew what it had before I made that post. Nice ride!
    BOKE likes this.
  4. intrepidcva11
    intrepidcva11 F1 Rookie Rossa Subscribed
    Jan 12, 2009
    3,232
    Saratoga Springs NY
    Seth
    exactly right, same as shifting a non-synchro box. I raced a TR3 in California during my Navy active duty service. Sixty years ago at the SCCA Spring races at Stockton entering the hairpin before the pit straight the clutch blew and I spun; fortunately the car stopped when hedaded in the right direction, and in 2d gear. I finished the race shifting up and down with no clutch, just by slightly lifting the throttle and correctly timing the shift.
    ..............so long ago! ;)
    ShineKen likes this.
  5. ShineKen
    ShineKen Two Time F1 World Champ Silver Subscribed
    Aug 3, 2007
    20,190
    Southern California
    Nostradamus
    Sounds like a “clutch” performance :). That’s what life is all about. Unforgettable moments.
  6. johnk...
    johnk... F1 World Champ Owner
    Jun 11, 2004
    11,299
    CT
    John Kreskovsky
    Ok, that helps. So it's like a manual. You can drive it smoothly if you know how; you can beat it to death; or anything in between. :)
    PDK much different since the throttle is fly by wire, rev match and all that controlled by the TCU.
  7. taz355
    taz355 F1 Veteran Owner Silver Subscribed
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Thats the way i see it as well
  8. taz355
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    The thing I like about it is you can use both feet just like the f1 drivers of the early 90s
  9. johnk...
    Jun 11, 2004
    11,299
    CT
    John Kreskovsky
    Every watch NASCAR on TV? They used to have an in car camera that showed the driver's feet. Left foot on the brake, right on the gas. Didn't use the clutch to shift. Clutch was for starting, stopping and doing burnout if you win. :)
  10. ShineKen
    Aug 3, 2007
    20,190
    Southern California
    Nostradamus
    Nice video. Great timing.
    I could be wrong but I think the commentator made a few errors explaining the technique.
    He first says the driver blipped the throttle and downshifted to 3rd in an earlier sequence. Didnt see him reach for the lever at that moment to do any shifting.
    In another sequence as the driver was downshifting from 4th to 3rd, the commentator explains the driver blipped the throttle before reaching the lever to shift to 3rd. Unless Nascars are setup differently, this discription could very well be inaccurate although the driver does it so fast and smooth its hard to tell.
    The sequence is lift off throttle, reach for lever, shift into neutral, blip (rev match) then shift into 3rd. So its not blip first (you shouldn’t be able to blip with the transmission in gear) then shift. Driver does a superb job with timing to make it seem like its all in one motion. But you’ll see him lift off throttle and reach for the lever at the same time.
  11. taz355
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    No not a fan ever since I went to one. Huge dissapointment and a longstory.
  12. johnk...
    Jun 11, 2004
    11,299
    CT
    John Kreskovsky
    Best video I could find on the fly. I recall watching drivers both up and down shifting w/o clutch, particularly on road courses.
    Unfortunately, NASCAR has gone down hill over the last decade.
  13. carnutdallas
    carnutdallas Formula 3 Rossa Subscribed
    Nov 11, 2010
    1,978
    Dallas Burbs
    Rob
    You don’t have to shift into neutral as you down shift to rev match in a 1-2-3 fashion.... you blip throttle as you pull it out of 4th into 3rd passing thru neutral gate in one smooth motion..... it happens so fast. Not easily done in synchromesh standard gearbox for most road going cars. Purpose built Richmond style race transmission, pretty easy with practice and experience.
    When I am warmed up and in practice on an 18-speed hi/low class 8 truck trans, you would never know I was up or down without watching the gear selector if you could not here truck. Never touch clutch after start out. Gawd I love that! So much fun to drive. Every truck and trans different. Takes me about 3-5 days to know and feel truck, engine and trans. Last few rental trucks were all 10 speed autos and wow, what a well designed system. Boring, but keeps it in the power without thinking. I was pretty good, but some guys - hell most old truckers would walk all over top of me “floating” the gears. Sure is fun though.
  14. ferraridriver
    ferraridriver F1 Rookie
    Aug 8, 2002
    4,152
    Bay Area Calif.
    Dave
    There were several venues for the Port of Stockton races, I raced my Merlyn MK6A at two of them. In one I was leading when Harry Banta rear ended me parking his Genie's left front wheel over my right rear.
    I raced the Merlyn for about four years, all over California. Laguna, Stockton, Cotati, and one time at an abandoned Army base in Pittsburg Ca. Image Unavailable, Please Login
    This pic is of another Merlyn I raced in Vintage racing. I bought and restored it to be an exact replica of the one I bought new in 1964.
    BOKE and Dave rocks like this.
  15. ShineKen
    Aug 3, 2007
    20,190
    Southern California
    Nostradamus
    Yes. This is what I meant. The blip occurs after you move out of 4th and right before going into 3rd. The blip occurs at the neutral point of the transition. Not supposed to stay into neutral for long. One smooth motion.
    carnutdallas likes this.
  16. RudyP
    RudyP Formula Junior Silver Subscribed
    Dec 6, 2018
    815
    Philadelphia suburbs
    What F355 book are you reading?
  17. carnutdallas
    Nov 11, 2010
    1,978
    Dallas Burbs
    Rob
