David Piper restores the Talacrest P4 | Page 72 | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by Streetrod, Sep 6, 2012.
  1. Ney
    Ney F1 Veteran
    7,466
    I will reserve judgement until I know for certain what engine tipo is in the car when complete. If it is the 247, than indeed the car is largely a 350 CanAm with a incorrect P4 body. If it is 0858 tipo 237, then your "facts" are no longer factual. ;)
    The reconfiguration has happened. The question is whether they do a complete job or not.
  2. Vincent Vangool
    Vincent Vangool Formula 3
    Oct 6, 2007
    1,250
    Zanskar, Kargil district, Ladakh, India
    Vincent Vangool
    What is your definition of complete?
    What will the title of this car state it is:0858 330P4, 0858 350 P4, or 0858 350 Can Am?
  3. miurasv
    miurasv F1 World Champ
    Nov 19, 2008
    10,841
    Cardiff, UK
    Steven Robertson
    #1778 miurasv, Jul 21, 2013
    Apart from the tipo 237 engine in 330 P4 0856 do any others exist?
    Also, how many tipo 237 engines were made? Were there more made than the originals in 0846 P3/P4 and P4s 0856, 0858 and 0860?
    Were there spare tipo 237 engines made?
  4. Vincent Vangool
    Oct 6, 2007
    1,250
    Vincent Vangool
    Think this sums it up.
  5. miurasv
    Nov 19, 2008
    10,841
    Cardiff, UK
    Steven Robertson
    Thanks. Does anyone have a link to Jim's PDF that he refers to?
  6. GTE
    GTE F1 World Champ
    Jun 24, 2004
    10,117
    The Netherlands
    Marnix
    I think that if Talacrest had the opportunity to put a 237-engine in it, they would have made a big deal of it, because it would matter a lot for this particular 'endeavor'.
  7. Ney
    Ney F1 Veteran
    7,466
    Yes.
  8. miurasv
    Nov 19, 2008
    10,841
    Cardiff, UK
    Steven Robertson
    Thank you. How many?
  9. Ney
    Ney F1 Veteran
    7,466
  10. miurasv
    Nov 19, 2008
    10,841
    Cardiff, UK
    Steven Robertson
  11. Ney
    Ney F1 Veteran
    7,466
    #1786 Ney, Jul 21, 2013
    My own preference would have been for the car to remain 0858 350 CanAm. It has not. I think it would be acceptable to return it fully to 0858 330 P4. The assumption of most here is that it might end up as 0858 350 P4, which I would view as an incomplete job and as Jim has pointed out, a bit fraudulent. It is the engine that will determine that.
    Complete would be a 330 P4 type 237 engine in classis 0858 with the P4 body.
  12. Vincent Vangool
    Oct 6, 2007
    1,250
    Vincent Vangool
    There's more to it then that.
    Gearbox, wheels etc. But I'm guessing you are aware of that as your posts seem quite informed.
  13. Ney
    Ney F1 Veteran
    7,466
    correct, hence my comment about the shade of gray. The more correct P4 components, the more complete the reconfiguration. The more 350 Can Am bits, the less complete. Regardless, the body should have been done by Allegretti if it was going to be done.
  14. miurasv
    Nov 19, 2008
    10,841
    Cardiff, UK
    Steven Robertson
    #1789 miurasv, Jul 21, 2013
    The Tipo 603 R Gearbox in 0858 was used in the car when it was a 330 P4 as well as a 350 Can Am. I have this in writing from Ferrari Classiche. I have stated this a number of times in this thread.
    Regarding the 350 Can Am wheels on 0858, how wide exactly are they? Is someone actually going to answer this?
  15. tomgt
    tomgt F1 Veteran
    7,234
    Netherlands
    Tom Wiggers
    correct
  16. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    Ferrari was both smart are frugal. When they needed to fit taller gears and stronger shafts into 603 P4 gearboxes for the VMAX and Torque required for Can Am they revised the P4 gear box as the photo I posted of original 603 P4 and 350 Can Am 603R gearboxes shows. They used the revised boxes in The 350 Can Am, the 612 Can Am, The 712 Can Am and the 512S and 512M.
    As I said earlier and the photo of the dual stamped block I posted prove Ferrari reused blocks when they could in different Tipo's and as the 237 Tipo block can be built as either a 3 or 4 liter as per Sparling (my pdf) the 237 block was still useful to Ferrari for may years for F1.
  17. tongascrew
    tongascrew F1 Rookie
    Jan 3, 2006
    2,989
    tewksbury
    george burgess
    I can only speculate on this which I try not to do. Without knowing the de what was done in the USA,Australia and South Africa we can only guess.Wait till 0858 comes out of Talacrest and experts crawl all over it shall we get some idea. There is also the work done a S.F. in converting it into the Can Am machine. As far as I know there isn't much available on this subject. tongascrew
  18. tongascrew
    Jan 3, 2006
    2,989
    tewksbury
    george burgess
    Thank you Ney.It's nice to have a reasonably balanced opinion. Hopefully it will be resolved for most when the restoration is complete. For those not in agreement I am sure we will hear from them. tongascrew
  19. tongascrew
    Jan 3, 2006
    2,989
    tewksbury
    george burgess
    The issue of the sn at the 2009 RM auction is part of the cause of the sn controversy.I am sure you are familiar with this. I completely agree with you about #0858.Aparently the lawyers at RM had other ideas. Comment? tongascrew
  20. tongascrew
    Jan 3, 2006
    2,989
    tewksbury
    george burgess
    So how much P4 do you know came with the car to Talacrest.? So far I have not heard anyone who really knows. If you do tell us what you know and your sources. I have asked this before and have yet to hear any specifics from anyone. tongascrew
  21. tongascrew
    Jan 3, 2006
    2,989
    tewksbury
    george burgess
    Advertising this car an original Can Am car when the whole world knows it was originally 0858 P4 and a great deal of the chassis still is sounds pretty fraudulent to me. But let's see what it's called when it leaves he nest. tongascrew
  22. tongascrew
    Jan 3, 2006
    2,989
    tewksbury
    george burgess
    The lawyers at the RM auction of 2009 insisted that the car could not be sold as 0858 but as 603C. It's all there in he record. That's where the second sn came from. tongascrew
  23. Ney
    Ney F1 Veteran
    7,466
    This is not correct. The 512 and 612 gearboxes are not tipo 603R or 603C. They are tipo 613. This links to the original 612 chassis design documents.
    Fwiw, in addition to tipo 237, my records show tipo 241 as being linked to P4's.
  24. miurasv
    Nov 19, 2008
    10,841
    Cardiff, UK
    Steven Robertson
    Tipo 241 engines were used in 0844 when it was converted from a P3 to a 412P and also 0850 and 0854 which are model 412P. 2 valve engines with Webers.
  25. Ney
    Ney F1 Veteran
    7,466
    Thank you. My notes simply listed both numbers, but did not provide details as to the differences or serial numbers.
