DIY: Upgrade your stock exhaust manifolds W/ Agency Power headers. | FerrariChat
Discussion in '360/430' started by whatheheck, Aug 2, 2017.
  1. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    #1 whatheheck, Aug 2, 2017
    DIY: Upgrade your stock exhaust manifolds to Agency Power headers.
    Situation:
    Stock exhaust manifolds is a known weak design by Ferrari. Its not a matter of IF they will crack but when it will crack. And when they crack it can feed metal particles into the engine which could be very costly to repair.
    On my 2006 F430 Spider, during PPI, sure enough inspection showed Stock OE Headers and Exhaust brackets are cracked.
    I was quoted $9,800.00 by a Ferrari dealer to replace stock exhaust manifolds. I don’t think so. Not when I can upgrade to headers made of stainless steel that costs a lot less & weights a lot less with a lifetime warranty.
    There are 4 available aftermarket headers that I am aware of:
    1. Capristo headers = Super expensive.~ $6,500.00.
    2. Fabspeed headers = Expensive.~ $3,995.00
    3. Agency Power = less expensive. Lifetime warranty. ~ $2,700.00.
    4. Top Speed headers = much less expensive but not the best build quality. ~$1,200.00 in eBay.
    Im not rich by any means so I chose the best bang for the buck = Agency Power headers. I ordered it from James @ Vivid Racing. Excellent customer support!
    Contact James for FChat member pricing.
    1st, thanks to Trent, Daniel, Aldus Voice & Flea7 for their excellent write up on R & R of headers. They listed must have tools to do the upgrade. Links to those threads below.
    Thanks also to Dan for his post & excellent video.
    So here is my experience:
    1) Took me a total of 16 hours from start to finish and that includes a few trips to the fridge a day to get beer and peanuts. Chinese and Mexican food for lunch. I also scrubbed and cleaned the bottom panel and rear diffuser inside portion so my engine bay is clean.
    2) The tools listed by Trent & Flea7 is a must have. Include a hex bit socket set for removing Oxygen sensor caps on the AP headers.
    3) Pull the step by step procedure on the service manual. PM me if you need a copy.
    4) The stock exhaust manifold weights 18 lbs. Agency Power headers weighs 10 lbs each. 16 lbs weight savings on the car.
    5) AP headers are very well made and you have excellent support from James at Vivid Racing.
    6) The AP headers comes with nuts but it doesn’t come with bolts so don’t destroy the bolts as you will have to reuse it.
    7) Patience is the key as its extremely tight in there trying to remove the header nuts. Installation is much easier.
    8) Torque the header nuts properly per Spec. DO NOT overtighten.
    9) The result is amazing. An increased in exhaust volume which I like and improvement on overall sound of the stock exhaust (Although I will be replacing mine soon with Kline Innovation exhaust.)
    10) I wrapped mine with volcanic wrap tape to reduce engine bay heat. You can find these wraps at Amazon.
    11) Summary: Highly recommended upgrade for our pride and joy. Now I don’t have to worry about cracked headers which can feed metal parts into our engines damaging it.
    12) I feel the increase in power by my recently calibrated butt-o-meter :)
    Hope that helps some of you.
    Photos below.
    Dan
    Ray Smith and Performify like this.
  2. Flea7
    Flea7 Formula 3
    Feb 25, 2010
    1,963
    PNW
    SKIM
    Dan,
    Awesome job!
    The fact that you cleaned all the parts and areas available when the covers were off tells me you LOVE your Ferrari! :)
  3. 911-AL
    911-AL Karting
    Nov 22, 2009
    159
    Chicago
    My friends call me Al!
    Great writeup. I performed the same swap early this spring with my father. It took HOURS but the sound and piece of mind is well worth it.
    Looking forward to hearing some sound clips!
  4. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Thanks Skim!
    Yes, I love my car. A dream car come true for me.
    Next is Kline Innovation exhaust like yours. I can't wait to get & install mine!
    I plan to be at ERTC car show this Saturday. Hope to see you there.
    Dan
    Ray Smith likes this.
  5. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Thanks!
    Congrats on getting your upgrade done too!
    I will try and shoot some video this weekend.
    Dan
  6. Mikael-F360
    Mikael-F360 Formula Junior
    Apr 3, 2017
    754
    Finland
    Mikael E.
    Great writeup Dan! Very helpful as I plan to tackle this same operation soon. Thanks.
  7. f355spider
    f355spider F1 World Champ
    18,044
    Nice job Dan, thanks for sharing your project and photos.
  8. SCKOMS
    SCKOMS F1 Rookie
    3,903
    Lake County, IL
    Spiro
    Nice write up! However with regard to wrapping the headers, how will you be able to inspect them to see if there is a crack? I had one of mine crack within 18 months of installation. I noticed an exhaust smell in the car with the top down. Of course the header was replaced free of charge but I had to pay to remove and reinstall.
    Sent from my SAMSUNG-SM-G890A using Tapatalk
  9. Mikael-F360
    Apr 3, 2017
    754
    Finland
    Mikael E.
    And it was an AP header? It's good that they have a great warranty.
  10. CarAholic
    CarAholic Formula Junior
    May 10, 2016
    519
    One quick thing I would like to add to help those out. A day or two before get the car up on stands and take off the diffuser and under tray. Then PB blast all of the nuts on the headers. Let it sit for a day and come back and respray all the nuts. I did the entire job with this gear swivel wrench GearWrench 9553 12mm Stubby Flex-Head Combination Ratcheting Wrench https://www.amazon.com/dp/B000HBDWNO/ref=cm_sw_r_cp_api_kCVGzb3QX816R
    Only took me 5 hours total but the wrap itself was at least 2 of those hours.
    shifter, KBR54 and Aaronholmes220 like this.
  11. SCKOMS
    SCKOMS F1 Rookie
    3,903
    Lake County, IL
    Spiro
    Yep, AP
  12. LorenzoR
    LorenzoR F1 Rookie
    yep i second this. I PB blasted mine quite a few times for 2 maybe even a third day before i started on mine. Glad i did cuz the job went easy
  13. Doug2D
    Doug2D Karting
    Mar 29, 2015
    136
  14. I'm 360 Canuck
    I'm 360 Canuck Formula 3
    Nov 21, 2015
    1,911
    Ontario, The Real One in Canada
    Lars!
    Performify likes this.
  15. f355spider
    18,044
  16. dvb247
    dvb247 Karting
    Nov 4, 2012
    235
    I DIY'ed mine to AP headers, long job but not hard and that from a guy that really doesn't do mechanicals, for me I hated the massive increase in volume, couldn't live with them, went back to stock asap, strongly advise every stock F430 owner to go for a long drive in a 430 with aftermarket headers like Fabspeed/AP's 1st before you take the plunge.
    I must say they look amazing and I did want that piece of mine they offer but the volume was simply crazy loud.
    Also considered all your helpful advise, closing off valves, controllers, even earplugs!! but that sadly didn't take away the shear embarrassment each time I use her.
  17. Doug2D
    Doug2D Karting
    Mar 29, 2015
    136
    Be proud. I love making a lot of noise lol.
    Janjie likes this.
  18. StickBreitling
    StickBreitling Formula Junior
    Oct 12, 2012
    342
    Adding the Kline (or equivalent S pipe design) exhaust will quieten it down, but also give the noise a bit more character. Just make sure you have those 200 cell cats to dial the volume back up.
    The aftermarkets by themselves with stock everything else sound a bit boomy.
  19. klointheridge
    klointheridge Karting
    Jun 5, 2017
    219
    Westchester Cty, NY
    Kevin Long
    I LOVE this idea! Anyone in the Tri-state area want to let me drive their aftermarket exhausted (that actually sounds like they're tired) F430's around for a bit? 😁
  20. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    @Mikael-F360: Thank you!
    @f355spider = Thanks Hugh!
    @SCKOMS = Thanks Spiro! And thanks also for sharing your experience that your headers cracked. How can I inspect? It is very easy to cut the stainless steel tie wraps to inspect the headers. And I think by that time I should have enough money saved up and upgrade to Fabspeed blanket heat wraps. I understand those do a better job insulating header heat.
    @CarAholic: Thanks for sharing additional info and the excellent gear wrench!
    @ Doug2D: I agree, Tubi is a much better made headers. But $8,700.00 is steep!
    @dvb247: Thanks for sharing your experience. We are all different. To each his own. Looks like the AP headers is too loud for you. For me, the volume is perfect.
    Thanks again to all of you for chiming in.
    Dan
    Janjie likes this.
  21. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    By the way, in case anyone out there also think AP is too loud and wants to switch back to stock - I plan on selling my OE exhaust manifold soon.
    Dan
  22. CarAholic
    May 10, 2016
    519
    Not really sure about the comments of the exhaust is to loud with headers. When the valves are closed it is maybe 10% louder and I think that is over exaggerated. Once the valves are open she is definitely louder but that is only under a good amount of throttle. For those that say it's to loud are you not running the stock cars?
