Door Hinge pins for L Series. Photo & dimensions needed. | Page 2 | FerrariChat
Discussion in '206/246' started by swift53, Aug 17, 2011.
  1. dgt
    dgt Formula 3
    Jan 14, 2011
    1,292
    Northeast, USA & Oz
    Andrew
    I still see the early type door hinges on #02750 E-series, seem original to me.
    Does Matthias or anyone else have an update on when the hinge type changed?
  2. GermanDino
    GermanDino F1 Rookie
    Aug 14, 2007
    3,502
    Germany
    Matthias
    change within E-series makes sence.....
  3. dgt
    dgt Formula 3
    Jan 14, 2011
    1,292
    Northeast, USA & Oz
    Andrew
    Thanks... I’ve been looking around for new early type pins and they are available in stainless steel with new brass caps ($499/set), which I’ve used before however I think these might wear the door hinges over time.
    There’s a trade off on corrosion resistance vs wear.... I had a hell of a time removing the pins on my E-series, blow torch, 2 lb hammer and drift but ended up drilling one out.
    I found all 4 caps for my E-series (two under the seat!) so I’m thinking of having a run of new pins made in mild steel and reuse my caps, unless Alberto or someone has already done this?
  4. swift53
    swift53 F1 Veteran
    8,533
    E.S.
    Alberto
    Came out rather well, the lathe work, not the pins.
    They were hell to remove, but then they were never intended to, right ?
    Andrew, yes, we did have 4 pins made.
    Regards, Alberto
    PS. This thread is 8 years old?
  5. dgt
    dgt Formula 3
    Jan 14, 2011
    1,292
    Northeast, USA & Oz
    Andrew
    Yes, time flies when you’re having fun.
    I’ll look into making some.
    Best Andrew
  6. swift53
    swift53 F1 Veteran
    8,533
    E.S.
    Alberto
    Andrew, I was not aware you needed some...
    Regards, Alberto
