Just got back home. Mike spelled it out pretty well. I was going to bring my car up to Huntsville for a few runs on the dyno next to Mike's car but 2 blocks from my house the alt/water pump belt snapped so I turned around and drove back home, parked it and pulled the TB and Krank Vents. It wasn't a perfect day on the dyno for a few reasons. First we didn't know the best gear to run in so we just picked 3rd. Second, we did not have my intake, just my TB which as everyone knows is bigger than Mikes intake opening. It would have been nice to have them match. Last, I discovered that one of my Krank Vent's is leaking so there was no reason to even try those. I was a little confused as to why we could not get a number over 180 hp and we only got that once. Mikes car ran consistent #'s every other time but they were really no better than 170. We were stuck not knowing the gear ratios and we were told that it is best to pick the gear that is closest to 1:1 Is it possible that the computer was making assumptions on a different scale which resulted in final #'s that are about 10% low across the board? The K&N did make a small difference which was really the highlight of the weekend for me since I at least have one of those. The TB did show a drop in HP on each run. No doubt about it. The worst I expected was only a couple HP increase - similar to putting in a K&N. I NEVER expected a drop. A bigger TB was always the first thing we did to the 4 cyl VW's back in the 80's to wake them up a bit (and they have the same fuel inj. as my 308 too). Anyway, I am only going lose a little sleep over this until I can get my whole car up there, manifold, test pipe and all.. And, Paul, there is no need to make me feel any worse than I already do by saying how sorry you are with little happy faces next to it. Go pick on sombody else. I am not your enemy in all this. Once I get my car running again we plan on having another little party up there and this time be more prepared with all working parts, gear ratios, etc.
That was our expectation going in, but that's not what the dyno showed. What I'm wondering is whether adjusting the mixture to richen it with the bored TB on might have overcome the extra air draw. We definitely want to try it again in a few weeks with Tommy's car since he has the bored TB and Plenum combination, and after dyno'ing his car, we'll retrofit my stock TB and see what happens.
Tommy, the rated HP was between your memory of 240 and mine of 230, being 235 in the owners manual. And either 4th or 5th gear would be equally near to 1:1 though of course 5th gear won't hit redline. Actually, not having that information, we actually ran all the tests in 3rd gear.
On the old carb cars, one thing that you'd do would be to add a spacer between the carb and the plenum, raising the carb up an inch or so. That would often get a better fuel/air combination/mixture, but it would also slow down the fuel/air velocity. Conversely, the tighter that you squeeze down the nozzle of a fire hose, the faster the water will spray out. Well, a larger TB is like opening up the nozzle of a fire hose in that the *velocity* of the air is going to decrease. So if you already have a well-matched TB, then a larger one will cost you horsepower because your air intake velocity is reduced by the larger TB bore. If you have a TB that is too small, then a larger TB is a good idea, of course, but not every TB is too small from the factory. Some factories get it right on occasion. On my old 5.7 liter Corvette, I went from the OEM 48mm TB to a 52mm TB and saw a pleasant HP increase. Then I went to a 58mm TB and saw a decrease not only in HP but also in throttle control/drive-ability, etc. So it was back to the 52mm TB for me back then. I'd guess that this effect would be even more pronounced if the TB in question wasn't the main restriction in the air intake on any particular car.
Here is a shot of my TB on Mike's intake. See the 6hp difference? (those 6 little horses must have all been trapped around that edge) Image Unavailable, Please Login
3rd gear - 1: 1.693 4th gear - 1: 1.244 5th gear - 1: 0.919 I have always pulled in 4th gear. I'm sure someone out there can do the math to extrapolate you 3rd gear pull to a 1:1 based pull. It's too late in the evening for me to do it. That might explain some of the questions as to hp readings.
On my dyno pulls we used 4th gear as the 1:1 and start a pull from 2000 - 7500. When I dynoed my carb boxer we also used 4th gear for the 1:1 ratio.
What's with the huge lip around the butterfly valve-flap inside the TB?? That's like putting an airbrake on your intake.
That is one reason it was not a perfect weekend. That is MY throttle body on MIKE'S stock intake. My intake has been bored out to match it but it was on my car back home (broken alt belt). I just brought it anyway since we already had the placed booked. I thought it would be interesting to see it run.
Sorry, I meant on the brass-looking valve-flap itself, not on the intake plenum that you had bored to match (which Mike doesn't have). That valve-flap looks as though it has a spoiler lip on it! Also, the two screws aren't counter-sunk that hold it onto the TB-bar in the center of the picture. That's a lot of unnecessary air resistance for a performance TB. The internals should be smoother via better screws and a perfectly flat valve-flap. Image Unavailable, Please Login
I don't think so... wouldn't pulling in 3rd gear make it look *higher* than pulling in 4th gear, making my real numbers even lower?
It does if your mind doesn't properly interpret what you're seeing. It kind of does look like that at first glance. What you're seeing as a "lip" if that was the far side is really just the flap thickness on the NEAR side. See below. Image Unavailable, Please Login
That's a good analogy and good observation. I guess that's the real question we're trying to answer... will the added flow of a bored TB -- at least on a 308QV -- result in more power here or does the loss of velocity become the bigger factor and cause a loss of efficiency? Only the dyno knows for sure!
Theoretically it shouldn't make a difference, in practice the difference is huge. Depending on the gear used my car puts out 280kw (3rd gear) -350kw(5th gear) at the rear wheels on the same dyno.
Yes, my math was off, sorry Am I to assume these are not brake dynomometers, that hold you back at a steady speed? I dont understand how what gear your in would have any bearing unless its calulating torque based on acceleration. If thats what its doing, parts like lighter flywheels would make it look like you had more power when in fact you wouldnt have any more at all. Also, I can see now why you would lose power with that TB, I can almost see the air tumbling over that ridge from here. Good test though, when you going back????
Excellent information. Thanks guys for taking the time to post this. I would also guess that the disruption of linear laminar flow at the tb/plenum opening and possible 'bouncing waves' played a part. What we can say for sure based on your data is that solely increasing tb size without anything else is definitely bad, as well as the importance of mixture. Again, many thanks! Just as an obtw, I had always heard to do and always did my pulls in 4th.
i am in Lost Wages. And yes i am reading this, and no, i never sent in my plenum/TB. Ok, guess i need to wait until i have $$$$ as i REALLY would like to dump the distributors and also go with a blower If you see a homeless guy living out of a red Italian car on the side of the road with a sign saying "Will Work For Custom Ferrari Blower," please donate generously
Thanks for the explanation and photo illustration...My mind was seeing the top valve-flap *away* from me instead of towards me.
Exactly what I was going to say. If you have a 2 ft section of 2" pipe and you cut out a 6" piece in the middle and replace it with a 2.5" pipe you will disrupt the flow. Not only going from small to big, but then from big to small again. Fluids don't like this kind of stuff. That's why exhaust have mandrel bends so that the turns don't "neck" down. At least that's what I think. I'll be interested in seeing what numbers come up with Tommy car.
We have a track event here in Mar and I plan on making another trip back to the dyno with my car long before then to see what all the matching parts do on a similar car in 4th. This story isn't over yet...
