Easy Fix to "Abrupt Shifting" 458 DCT | FerrariChat
Discussion in '458 Italia/488/F8' started by rickwjenn, Feb 29, 2016.
  1. rickwjenn
    rickwjenn Formula Junior
    Mar 8, 2012
    544
    Minneapolis
    Rick
    Over the last few drives, my 2013 458 would increasing shift very hard and very abrupt. Felt like the clutches were engaging before engine RPMs were matched thus creating lurches or big doses of engine braking at the lighting speed this marvel shifts as.
    On Saturday , it was so bad I had to put it auto mode. On the way home, the "Gear Box" failure light came on and I parked it in the garage.
    Wasted time on Sunday reading and worrying about the DCT issues on early cars. Sensor packages for $4k. New DCTs for $28K. etc.
    Called the San Diego Ferrari dealer this AM and chatted with a service tech. He said the DCT transmissions are SUPER sensitive to Voltage and, even a few millivolts drop will cause issues. My car is three years old so I swung by and bought a new factory battery.
    Put the battery in and the DCT shifts as smooth as the day I took delivery. Made me realize the shifting had become gradually more "abrupt" over the last few weeks as the battery must of hit end of life.
    Also, I always used the battery conditioner and the Service Tech told me the conditioner just keeps the battery at is charge level, never increases it. So as the battery ages, the charge level drops, and all the conditioner does is keep it at that level between drives.
    Anyway thought I would share for those with 2-3 years on their battery....
    Pocty likes this.
  2. Dolceexte
    Dolceexte Formula 3
    Dec 20, 2015
    1,008
    I have to say my 2014 458 spider felt this way will get it checked!
  3. 458trofeo
    458trofeo F1 Rookie
    Feb 4, 2013
    4,426
    City of Angels
    101 aki
    Thanks for the info!
    All the more reason to get a lightweight Lithium Ion battery..
  4. spiders
    spiders Formula Junior
    Jun 8, 2012
    474
    Periodically check the quick release clamp on the battery terminal. If the connector is not pushed all the way down tight before clamping, the connector can eventually vibrate loose and move slightly up the conical shaped terminal post. If this happens, the connector is held in place only by gravity. It will slip when you push on it and may even lift off with finger pressure. A loose connection means trouble for the sensitive electronics in these cars.
  5. italiafan
    italiafan F1 World Champ
    16,121
    Stickbones Swagglesmith
    Sounds as if we should think of a new battery as part of every biannual major maintenance....what is one installed, $400 or so?
  6. Randyslovis
    Randyslovis Formula Junior
    Jul 7, 2011
    897
    Atlanta, GA
    Randall J Slovis
    I started a thread in January entitled "The best $1500 I ever spent." In it, I spoke about replacing the battery. For the reasons you site and the electronics sensitivity in the dash and elsewhere, a perfectly functioning battery is a must.
    Additionally, I would argue that because these cars are so computer dependent that going to your dealer - if convenient - to just clear error codes probably helps performance. View it like a computer at home that slows due to cookies etc. building up. Have them just hook up OBD and clear the codes. Takes minutes. Wouldn't be surprised if this helps drivability.
    Best
  7. rickwjenn
    Mar 8, 2012
    544
    Minneapolis
    Rick
    Damn - wish I had thought of that. The factory battery is at least 50 lbs! It is a beast to lift and navigate into the passenger foot well compartment.
    I think I will order one now! It takes about 30 minutes to remove:
    Leather cover Under glove box
    Upper Cross bar bracket
    Battery hold down
    Lower battery clamp fixture
    Negative cable (has a cool lever release)
    Positive cable (which is a pain in the ass due to the complex cover).
  8. rickwjenn
    Mar 8, 2012
    544
    Minneapolis
    Rick
    +1
    I also have a PC based Code OBD code reader. Forgot to do that and will check and clear codes tonight. Only time I used on my 458 I got a beautiful sight - no codes :)
  9. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,246
    Mel
    Here is the link
  10. rickwjenn
    Mar 8, 2012
    544
    Minneapolis
    Rick
    I paid $560 for my battery at the dealer. Thought it would be covered with the ferrari stickers like OEM, but it is not. It is an official part.
    I am going to go find the light weight lithium battery....
  11. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Lithium ion batteries can overheat and catch fire. I'd rather get a good AGM replacement like an Interstate MP-7/48.
  12. Randyslovis
    Jul 7, 2011
    897
    Atlanta, GA
    Randall J Slovis
    To Melvok, grazie mille for posting my thread.
    In regards to Interstate battery, much less than 50 lbs.
    In regards to lithium battery, I cannot justify unknowns with fire risk, etc. Additionally, as I do not track car where any weight savings might help, it loses another of its benefits for me. Net, given all the above and the cost which I believe is > 1K (based on another thread here a few weeks back) I just don't see the benefit.
    Rick, good luck with code reader -hope all is well - and good luck with the Li battery.
    Best
  13. Noblesse Oblige
    Noblesse Oblige F1 Veteran
    Nov 7, 2011
    6,114
    Three Places
    Sounds like Dale, a man who really knows these cars....
  14. rickwjenn
    Mar 8, 2012
    544
    Minneapolis
    Rick
    Thanks - I was looking at the prices and the pros/cons on the Li batteries. Definitely not a slam dunk.
  15. Randyslovis
    Jul 7, 2011
    897
    Atlanta, GA
    Randall J Slovis
    If I am not mistaken, Porsche now has Li battery option. If Ferrari had one as factory option I would feel better using one. NOT that I trust Ferrari implicitly. Lord knows the poorly engineered things they have done over the years. Rather, with the complicated electrical systems these cars now have, I am afraid to mess with any part of their manufactured equations.
    Keep us posted.
    Randy
    johnr265 likes this.
  16. Dolceexte
    Dolceexte Formula 3
    Dec 20, 2015
    1,008
    I have to say the electrical system clicks and knocks when you are stop and go in traffic, have you heard that in your 458s?
  17. 4th_gear
    4th_gear F1 Rookie
    Jan 18, 2013
    4,425
    Michael
    #17 4th_gear, Mar 1, 2016
    Reducing the weight of the battery will definitely change the weight balance of your car and may adversely affect traction and handling. People put rear wings on race cars to increase pressure on the drive wheels, to improve traction, especially when cornering. Reducing weight on your rear wheels can make the car less stable in the corners.
    I am also not sure the 458's charging circuitry will work on a lithium battery. Even the AGM battery has a different charging voltage level requirement from the standard starter battery and will not work 100% unless that is sorted.
    You need to be very careful substituting a battery different from the OE unit.
    No. He's completely wrong. Why would car manufacturers provide a charger that only maintains whatever charge the battery has discharged to - makes no sense at all?
    The regular 458 battery tender is simply very weak when it comes to recharging the battery. It can recharge the battery so long as it is not already discharged beyond 50% capacity or so. But it will take more than a day to do so. However, if you buy a proper battery tender like the CTEK 7002 or 25000, they will can very quickly recharge your battery even if it's discharged past 50%.
  18. PhilNotHill
    PhilNotHill Two Time F1 World Champ
    Jul 3, 2006
    27,855
    Aspen CO 81611
    FelipeNotMassa
    My OEM tender says "charger" right on it.
    Best
  19. 458trofeo
    458trofeo F1 Rookie
    Feb 4, 2013
    4,426
    City of Angels
    101 aki
    Here you go Rick:
    https://www.braillebattery.com/index.php/braille/product_batteries/i48cx
    I have the 48cx in my Italia now for about 2 months and love it :)
    I can get the same battery for around $1400 from my source, shoot me a pm
    if interested, best
  20. rickwjenn
    Mar 8, 2012
    544
    Minneapolis
    Rick
  21. Nex
    Nex Rookie
    Apr 13, 2014
    23
    Anyone have suggestions for aftermarket batteries vs the OE one? I've heard Odyssey and interstate. Anyone know the model numbers?
  22. Caeruleus11
    Caeruleus11 F1 World Champ
    11,422
    Great point! I think everyone with these cars would be best served by keeping the included tender packed away and using the 7002.
    And here is a solution for connecting to the factory connector:
    https://www.kumari.net/index.php/cars/ferrari-battery-charger-cable
  23. Nex
    Nex Rookie
    Apr 13, 2014
    23
    Just another quick question. I currently use a battery tender charger for all my other cars. It hooks directly to the positive and negative posts of the battery.
    Would that be a better option than the factory included charger?
  24. rost12
    rost12 Rookie
    Apr 6, 2007
    32
    Rost
    It's not about how it's connected to the car, it's about what it can actually do. The better CTEK models can and will maintain the health of a battery, whereas a cheap battery charger (the one shipped with the cars) can't. Get a better CTEK charger, pay for an adapter dongle because Ferrari cheeky, and enjoy a battery that will last much longer.
  25. 308mash
    308mash Formula Junior
    May 20, 2009
    534
    MA
    Joe
    this
