355 - Electrical issue car shutting down, fault possibly found? | Page 3 | FerrariChat
355 Electrical issue car shutting down, fault possibly found?
Discussion in '348/355' started by Ben111, Apr 17, 2025.
  1. Ben111
    Ben111 Karting
    Jun 14, 2018
    137
    Ben
    To remove the ignition switch/barrel does the whole column need to come off?
    is there a procedure available?
  2. Qavion
    Qavion F1 World Champ
    14,601
    Ian Riddell
    No, just the plastic covers. There is a thread on the forum somewhere on how to remove the lock. As I said, you have to drill a hole in the security shear bolt and use an easy out.
    I can only find this at the moment:
    https://www.ferrarichat.com/forum/threads/ferrari-348-ignition-switch.585995/#post-146235069
    I think there is one or two screws and the shear bolt.
  3. Ben111
    Ben111 Karting
    Jun 14, 2018
    137
    Ben
    #53 Ben111, Jun 8, 2025
    so was in the process of removing the switch, before I started I checked to see if the fault was currently present, which it was I.e ignition would only come on if i shorted the amp wires.
    I left the key on with the amp wires disconnected, and was handling the ignition switch connector (white plug into black plug) this caused the ignition to come on, the more I handled it the ignition would jump on and off.
    The white connector seemed to be plugged into the black connector unevenly, I noticed this burn mark on the white connector.
    looking back through my photos from a few weeks ago you can just about see what I mean regarding the uneven connection in the last photo, could this possibly cause the overheat?
    Qavion likes this.
  4. Ben111
    Ben111 Karting
    Jun 14, 2018
    137
    Ben
  5. Qavion
    14,601
    Ian Riddell
    #55 Qavion, Jun 8, 2025
    I'm not sure why Ferrari used a jumper wire (on the key side of the white plug). If you cut off the jumper wire (and threw it away). Then moved the thick red wire on the other half of the plug (car side) to match the remaining red wire on the key side, you should be good to go.
    Looking at the plugs from the wire side....
    blox79 likes this.
  6. Ben111
    Ben111 Karting
    Jun 14, 2018
    137
    Ben
    @Qavion
    so ive done as you suggested, and just come back from an hours drive troublefree, considering the issue went from infrequent to being stuck on the faulty state I’m cautiously optimistic this issue has been resolved.
    I can’t thank you enough for your time in assisting me, and to everyone else who has helped.
    brogenville and Qavion like this.
  7. Qavion
    14,601
    Ian Riddell
    I guessed it was an ignition issues in message #3... but it was an interesting ride. :D
    Yelcab also said he had had an issue with this plug. I hope this isn't a sign of things to come for other owners.
