Engine Cylinder numbers | FerrariChat
Discussion in '360/430' started by RobScud, Dec 18, 2014.
  1. RobScud
    RobScud Karting
    Dec 29, 2010
    154
    Rob
    Hi,
    Does anyone know the layout of the cylinder nos for a 360 and 430 please?
    Also when changing a coil, do u need to disconnect the battery?
  2. rustybits
    rustybits F1 Rookie
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    No need to disconnect battery. No.1 is r/h bank,nearest front of the car. 4 is the rearmost of the same bank. 5 is opposite 4 and 8 furthest forward of l/h bank..
    billy.gif likes this.
  3. vrsurgeon
    vrsurgeon F1 World Champ
    16,440
    Charleston, SC
    Curt
    change coil: no. just make sure car is turned off. unbolt, replace , plug back in.
  4. RobScud
    RobScud Karting
    Dec 29, 2010
    154
    Rob
    Thanks.
    This diagram seems to suggest that 1 is opposite 5
    Ferrari 360 GT Challenge Stradale group N-GT (2004) - Racing Cars
    Confused now.
  5. THINKFAST
    THINKFAST Karting
    Jan 13, 2011
    195
    Earth, mostly ...
    No need to be confused.. Eddie,s description is the same as your photo..
  6. RobScud
    RobScud Karting
    Dec 29, 2010
    154
    Rob
    No it is not, he says 8 is furthest forward of left bank, on diagram it shows nearest left bank.
  7. RobScud
    RobScud Karting
    Dec 29, 2010
    154
    Rob
  8. vrsurgeon
    16,440
    Charleston, SC
    Curt
    I presume you've had a misfire and want to replace that coil? And I presume that its on the drivers side bank 5-8?
    If it was me and I was so unsure, I might disconnect the fuel injector at the #8 cylinder. Start the car for a few seconds then stop it, reconnect the injector and then plug the OBD2 reader in and obtain the codes present. You should have a code that indicates an error with cylinder 8 injector. Then reset the codes and note it in your log for future reference. Then I would have confirmed that #8 cylinder is the front most on the drivers side. (unless anyone can offer a reason why this would kill the engine? if only a few seconds)
  9. RobScud
    RobScud Karting
    Dec 29, 2010
    154
    Rob
    sounds a bit extreme, so no one can give a definitive answer, must be a diagram somewhere.
  10. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,394
    San Carlos, CA
    Mitchell Le
    Front
    8 1
    7 2
    6 3
    5 4
    Rear
    Good?
    Cairndog and billy.gif like this.
  11. RobScud
    RobScud Karting
    Dec 29, 2010
    154
    Rob
    Thanks, that confirms what a local garage just said. Looks like there is some incorrect info floating on net!
  12. NbyNW
    NbyNW F1 Rookie
    #12 NbyNW, Dec 19, 2014
  13. voicey
    voicey Formula 3
    Jul 29, 2009
    1,193
    London, UK
    Aldous Voice
    Correct.
  14. Cairndog
    Cairndog Rookie
    Jun 6, 2021
    15
    Scotland
    Iain Cairney
    My fuel injector cabling, on my F430, has small silver strips of tape with numbers on them which agree with the above.
  15. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
  16. Qavion
    Qavion F1 World Champ
    13,844
    Ian Riddell
    #16 Qavion, Jul 7, 2021
    Greg, what's the 1, 4, 2, 3 on the LH intake plenum? I understand that there is some crossflow between the LH intake plenum and the RH cylinders, but I don't understand the numbering.
  17. 24000rpm
    24000rpm F1 Rookie
    those are for caption puproses.
    like: 1 = vacuum line going to somewhere
    2. screw for tightening down the cap
    10 bracket for something
  18. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    #18 GCalo, Jul 7, 2021
    I thought they indicated the number of sodas one had to drink to get those particular pistons to TDC!!!
    Honestly I have no idea but maybe 24000rpm has something
    Here's the firing order pictorial
    Qavion likes this.
  19. Qavion
    13,844
    Ian Riddell
    Sorry, I meant on the colour photo in the post before mine. My diagram was to show the crossflow tubing.
  20. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    I knew to what you were referring.
    I honestly have no idea what the numbers reference
  21. yelcab
    Nov 29, 2001
    13,394
    San Carlos, CA
    Mitchell Le
    That is the firing order for bank 1.
    Qavion likes this.
  22. Qavion
    13,844
    Ian Riddell
    Thanks, Mitch. Makes sense.
  23. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    so my idea of # sodas to TDC did not do it!!!
  24. 67bmer
    67bmer F1 Rookie
    2,703
    MD
  25. kaj750
    kaj750 Formula Junior
    May 9, 2022
    260
    Fresno, CA
    I came across this thread while trying to confirm L vs R side of engine so I know which timing tensioner is which. "Driver side" and "passenger side" are a horrible way to describe things as our steering wheels aren't all on the same side. "Left side" and "right side" depends on which end of the car you are on (not everyone gets it). Some are confused on which end of the engine is front and back. I'm reading the replies and they aren't really too helpful for those new to all of this, otherwise they wouldn't be asking. So, here is a picture for anyone else who happens to find this thread while searching. I tried to compile all the posts (I didn't come up with any of this information on my own) to make it as simple and definitive as possible so there is zero confusion. If it's wrong, it's due to the fact that all of these posts are a bit confusing. LOL.
