Engine Failure | Page 3 | FerrariChat
Engine Failure
Discussion in '360/430' started by ChampIII, Apr 9, 2011.
  1. TheMayor
    105,027
    Vegas baby
  2. SfefVan
    SfefVan Guest
    Nov 28, 2008
    1,370
    Switzerland
    Stef
    #52 SfefVan, Apr 14, 2011
    Thanks very much ChampIII for keeping us updated and for your very detailled pictures. First, it's a good relief to read that the distribution chain isn't the issue, neither the chain tensioners.
    Secondly, I agree with bhelp, it looks like the broken small pieces from the intake are not the root cause of the engine damage. I think that these small bits would have fallen down in the intake base without being sucked in the engine. Something else got sucked in there. On your pictures, the dents were maybe marked by another object that got in there. Maybe a screw with a circular head? It must be something light to able to follow the air flow but hard enough to cause all the damage. If the factory mishandled the intake, the alimunium bits would have broken off immediately and not after 10K miles as alimunium is braking off straight away.
    Wishing you good luck with the further investigation and cross fingers you'll get support from FNA.
    Stef
  3. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,612
    The Brickyard
    The Bad Guy
    WOW! That sucks!
    Glad to know it wasn't the tensioner. Thanks for the update, and I REALLY hope you get some help with this.
  4. PAP 348
    Dec 10, 2005
    100,200
    Mount Isa, Australia
    Pap
    GOOD to hear from you Ape! :D:D
  5. PAP 348
    Dec 10, 2005
    100,200
    Pap
    Also, this is unbelievable! :eek::eek:
    Two failed engines?? SAME issue?? :(:(
    Probably the same guy who built both those engines. I am sure they can find out who did and I hope they clip him behind the ears and "tell him to wake up to himself". :rolleyes::rolleyes:
  6. Schmick325
    Schmick325 Formula Junior
    Mar 10, 2004
    879
    Bris east
    Sorry to hear of your pain.
    If i ever buy an F430 Ill be pulling the intake cover off to have a looksee!
  7. Piper
    Piper Two Time F1 World Champ
    25,408
    Northern Virginia
    Bob
    I'd actually appreciate, as the dust settles, a prescription to take to the ferrari dealer to have my intake examined for signs this could happen. What exactly do I tell them to look for?
  8. The Ape
    The Ape Formula 3
    Feb 28, 2007
    1,793
    Los Angeles
    Ape
  9. ELP_JC
    ELP_JC Formula 3
    Dec 13, 2008
    1,264
    Clearly 100% manufacturing defect (unless somebody opened the motor before), so hopefully Ferrari NA will fix it under 'goodwill' warranty. I'd definitely shoot for that. Good luck, and please keep us posted.
  10. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    So sorry to hear of this problem Champ. All will be well in time and quite possibly at considerable cost but a shame to have damage like this occur in such a random way.
    Just as regards it being a factory problem I note the orange gasket sealer on the plenum chamber gasket. I would generally interpret that as evidence of the unit having been opened since it left the factory as generally on new assemblies I don't think that kind of sealer tends to be used.
    Good luck with the repairs. Hopefully she won't be off the road too long and once you clip 8.5 a few times on the way home any inconvenience and cost will begin to fade away.
  11. FerrariDublin
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    Even at 4200 rpm there's 7,500 litres of air per minute going through each bank which means a lot of wind. Probably enough to pull in those small pieces no problem.
    Also the engine damage probably not actually caused so much by the small pieces themselves. More likely the small pieces caused a valve or valves to stick open, then get hit by piston, maybe break off and then........
  12. tazandjan
    39,046
    Champ- That is really just horrible luck. I have a feeling FNA will make good on this one.
    Ape- Welcome home.
    Taz
    Terry Phillips
  13. PAP 348
    Dec 10, 2005
    100,200
    Pap
    Excellent! :D:D
    Hope you see you back in a 430 again someday Ape! :):)
  14. crcs
    crcs Formula 3
    1,306
    Burlington Ontario
    Ferrari should replace the engine at their expense, ridiculous to let that leave the factory.
  15. Ingpr
    Ingpr F1 Rookie
    Jun 30, 2009
    2,619
    PR
    David
    1+!
    If not my lawer will on top of it!
  16. blackbolt22
    blackbolt22 F1 Veteran
    5,797
    Boca Raton, FL
    Mr. Anderson
    The APE returns ...just when you need him.
  17. TheMayor
    105,027
    Vegas baby
    I'm not disagreeing with you but let's not jump to conclusions on what caused it.
  18. Piper
    25,408
    Northern Virginia
    Bob
    There you go with that voice of reason again.
  19. PAP 348
    Dec 10, 2005
    100,200
    Pap
    :eek::eek::eek::eek:
  20. The Ape
    The Ape Formula 3
    Feb 28, 2007
    1,793
    Los Angeles
    Ape
    Thanks Taz!
  21. The Ape
    The Ape Formula 3
    Feb 28, 2007
    1,793
    Los Angeles
    Ape
    HAHAHA!!! : )
  22. ChampIII
    ChampIII Karting
    Oct 27, 2008
    53
    #72 ChampIII, Apr 14, 2011
    Ape - you a very popular guy! Thanks for your offer to help me.
    Regarding the screw idea or some large piece of metal entering the engine: In the attached pictures you will see that the large and small filter screens were undamaged (as were the air filters) so whatever got into the engine did not come from the intake. So if it was a screw, it had to be laying in there - very doubtful - I would have heard it rattling around there at idle when the hood was up and all screws were accounted for when they broke it down.
    So if it didn't come through the intake, then it had to come through the exhaust manifold - which I find hard to believe. Even with extreme back pressure or a backfire, the material would have to be substantial to make that kind of mark and I just cant fathom a big chunk going up through the exhaust manifold, squeezing through the exhaust valves, then after being battered around, squeezing through the intake valve on the left and then over the plenum to the right bank and taking out the lip of the velocity stack multiple times without making a mark on any of the other velocity stacks - they were all perfect.
    Lastly, that piece in the picture is only what was left in the cylinder - if you look closely you can see tiny pulverized aluminum bits all over the suction intake (you can see it clearly in the picture around where the oil collected). So there was more in there than that little piece - it was all that survived so far.
    So I come back to the lip being damaged by the cover upon assembly. Nothing else makes sense to me.
    Still open to any theories...
    Thanks again for all the input.
  23. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    I assume we have eliminated the spark plug electrode ...
    Pete
  24. ReinD
    ReinD Formula Junior
    Sep 16, 2010
    472
    First, sorry about your troubles. I have my fingers crossed that Ferrari will come to the rescue and save the day!
    Since you're looking for theories...
    Check out this post from July 2009. Might Ricambi knows something...? You might want to give them a call.
    http://www.ferrarichat.com/forum/showthread.php?p=138834173
    Read steelej's post on this page:
    http://www.clubscuderia.co.uk/forum/showthread.php?t=41599
    And lastly... Ever have any exhaust work done? I would think that a problem would have surfaced immediately, but who knows? Just throwing out ideas. :D
  25. wildkalabaw
    wildkalabaw Karting
    Jul 11, 2008
    127
    Is it a good idea to purchase a higher mileage f430? maybe about 20k miles...if there were debris sucked, it would have toasted the cylinder heads before 20k.
