Engine lights | FerrariChat
Engine lights
Discussion in '360/430' started by RB9, Oct 10, 2011.
  1. RB9
    RB9 Karting
    May 27, 2011
    128
    Perth
    Robert
    #1 RB9, Oct 10, 2011
  2. jbbachman
    jbbachman Karting
    Oct 10, 2009
    189
    Milwaukee, WI
    Joe B
    Its actually pretty cool...
    Can you elaborate in further detail-how did you do it?
  3. RB9
    RB9 Karting
    May 27, 2011
    128
    Perth
    Robert
    It was pretty simple. At the moment I am only using 2 LED strips ($60.00 for 2). I plan to add some more to even out the light distribution. These strips are coated and can withstand the heat from the engine.
    I had my friend who is a car audio installer mount and chase the wires to the rear lights so when ever the lights are on the engine is lit up. There is also a toggle switch in case it needs to be turned off.
    Total install time 3 hours. Including changing over my license plate bulbs to LED and repositioning the reversing camera.
    I will take some close ups of the strips etc over the weekend.
  4. raywong
    raywong Formula Junior
    Aug 29, 2004
    673
    Hong Kong
    Raymond
    pretty cool!
    is the installation reversible?
  5. RB9
    RB9 Karting
    May 27, 2011
    128
    Perth
    Robert
    The leds are clipped in and have connectors that can be undone.
    If you want to permanently remove the cabling its just a matter of cutting the cable connected to the rear lights and taping up where the cable was spliced in. We did hide all the cables through the side engine bay panels but you would only need to remove one panel to gain access to the splice point.
    The only physical change to the car is the 4 tiny drill holes to mount the clips and the splice in to the rear light.
  6. F430addict
    F430addict F1 Rookie
    Sep 17, 2010
    4,460
  7. SfefVan
    SfefVan Guest
    Nov 28, 2008
    1,370
    Switzerland
    Stef
    It's not a "faux pas" at all :) I just love it. Did the same on my F430 but with a remote control dimmer : http://www.ferrarichat.com/forum/showpost.php?p=140366549&postcount=61
    I found even this engine bay light mod very practical when I need to work on the engine.
  8. RB9
    RB9 Karting
    May 27, 2011
    128
    Perth
    Robert
    Very nice I like how the light is diffused around the bay. With the addition of the other led strips hopefully it will balance the dispersion. I'm trying to think of a way to shield the strips so they arent seen when you look inside.
  9. F430addict
    Sep 17, 2010
    4,460
    Now that would be very oem-ish. Setting up camp for updated pix.
  10. mmollo
    mmollo Formula Junior
    Oct 20, 2010
    435
    [x] Texas [ ] Maui
    Can you have the lights on when the car is turned off? How cool would it look to have the car sitting at the valet in front of a restaurant with the engine bay glowing?
  11. SfefVan
    SfefVan Guest
    Nov 28, 2008
    1,370
    Switzerland
    Stef
    With the Parking button, I can leave it on as I connected the engine bay LED's to the tail lights. Having LED's in the tail lights and the head lights, I can leave it on for ages without draining any current from the battery ;)
  12. djastral69
    djastral69 Formula 3
    1,896
    Fl
    David
    #12 djastral69, Oct 12, 2011
    Can you give us the specs on what you used specifically on the parking lights, tail lights and engine bay. Thanks :)
  13. SfefVan
    SfefVan Guest
    Nov 28, 2008
    1,370
    Switzerland
    Stef
    If you don't mind, I will reference the different threads with all the details:
    Headlights : http://www.ferrarichat.com/forum/showthread.php?t=319127
    This long thread explains 3 different versions : Ikea lights - SMD5050 Leds - Superflux Leds
    Tail lights and engine bay light: http://www.ferrarichat.com/forum/showthread.php?t=301476
    You'll find in these threads a lot of very detailed information on these mods.
  14. 50hdmc
    50hdmc Formula 3
    Oct 10, 2006
    1,211
    Michigan
    mark s
    I think it looks great too.....
  15. djastral69
    1,896
    Fl
    David
    what did RB9 use for the engine bay lights and how were they hooked up?
  16. Epwerkz
    Epwerkz Formula Junior
    Oct 12, 2010
    275
    Jakarta,Indonesia
    FXL
    good job bro! hehehe how are u doing?have u install the capristo level 3 exhaust yet?
  17. Chiaroman
    Chiaroman Formula 3
    1,687
    New Jersey
    Great Job!!!!
    Looks fantastic!!!
  18. [R]
    [R] Karting
    Jul 10, 2011
    114
    look nice!!!!!
  19. RB9
    RB9 Karting
    May 27, 2011
    128
    Perth
    Robert
    No :(
    I'm still waiting on my capristo fitting kit from Vivid. Its been held up waiting for my wheels to arrive. The Advan distributor in the States hasnt made it easy for them or myself. Hopefully I will have everything in about 3 weeks.
    But to be honest I'm loving the Tubi its soooooo loud and the cops can't figure out if its legal or not. If I put on the stage 3 I'm definately going to get pinged.
    Are you back in J Town yet? I was supposed to go up next weekend but family commitments have over ruled me.
  20. RB9
    RB9 Karting
    May 27, 2011
    128
    Perth
    Robert
    I used coated LED light strips (heat resistant) just bought from the local electronics store. They were about $35 each. We then took all the panels off and ran the cable through tubing and tapped it into the rear lights.
    The car is currently in the workshop getting a new condensor fan fitted so when I get it back next week I will take some pics and post.
  21. DoctorWill
    DoctorWill Formula Junior
    Jun 12, 2010
    761
    Playa Vista
    Will
    Can you tell us more about the reverse camera set up. I am looking for a good solution!
  22. RB9
    RB9 Karting
    May 27, 2011
    128
    Perth
    Robert
    If you have a look at this thread it has all of the relevant info you might need.
    http://www.ferrarichat.com/forum/showthread.php?t=336448
    If not please feel free to pm me.
  23. RB9
    RB9 Karting
    May 27, 2011
    128
    Perth
    Robert
    Its actually wired up to the Park lights so you can actually do that :)
  24. RB9
    RB9 Karting
    May 27, 2011
    128
    Perth
    Robert
    #24 RB9, Nov 7, 2011
  25. RB9
    RB9 Karting
    May 27, 2011
    128
    Perth
    Robert
    #25 RB9, Nov 7, 2011
