Engine out and much more | Page 2 | FerrariChat
Discussion in '348/355' started by blackcross, Oct 20, 2009.
  1. blackcross
    blackcross Karting
    Jun 23, 2007
    100
    Completely forgot to mention that we also discovered that one exhaust valve on cylinder 3 was missing the inner return spring!
    Looking at that cylinder, the seals on the head, the marks on the outer spring etc, we came to the conclusion that the spring was never installed at the factory. Could be wrong but I believe Claudio given his transparency, attention to detail and work ethic.
  2. PAP 348
    PAP 348 Ten Time F1 World Champ Lifetime Rossa Owner
    Dec 10, 2005
    100,245
    Mount Isa, Australia
    Pap
    Wow! Glad he found it! :D:D
    Too many glasses of Barolo at the factory in the engine room when they put your engine together perhaps? :eek::eek:
  3. 50hdmc
    50hdmc Formula 3
    Oct 10, 2006
    1,211
    Michigan
    mark s
    ..looks awesome....nice work indeed!
  4. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,763
    You have an excellent eye!
    200 PSI ?!
    What does this convert back to in xx:1 compression ratio?
  5. saw1998
    saw1998 F1 Veteran
    Jun 8, 2008
    8,237
    San Antonio, Texas
    Scott
    Yup, Erine and Pap are very bright guys. However Mitch, you're pretty slick yourself there with some of your informative posts.
    With regards to the post. The engine looks great. You must feel very satisfied and comfortable knowing that it been done correctly. In addition, this is one more post that exemplifies the reason why a proper 30K service should be performed with the engine out, rather than in situ. The quality of the job, attention to detail, and the high probability of noticing other problems makes it, at least to me, a no-brainer.
  6. Mitch Alsup
    Nov 4, 2003
    9,763
    I was kind of disappointed in myself for having seen the pictures and not seen the headwork itself. I usually catchs this kind of detail. So I'm sort of kicking myself on this one.
  7. Kayearc
    Kayearc Rookie
    Oct 22, 2009
    36
    Florida
    Chris
    how would that happen?! doesn't the exhaust flow away form the engine, in to the cats (and pre-cats before those) then out the muffler at the tail pipe?
  8. Kayearc
    Kayearc Rookie
    Oct 22, 2009
    36
    Florida
    Chris
    I dont believe there is a accurate relationship between results from a compression test (cyl pressure) and the static compression ratio.. much having to do with cam profile (overlap), ring/quide leakage, etc. I'm not a Ferrari expert at ALL.. but that is my understanding of typical four stroke engines.
