348 - Engine repair thread | Page 2 | FerrariChat
348 Engine repair thread
Discussion in '348/355' started by Ferrarium, Oct 13, 2021.
  1. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,169
    CT
    John Kreskovsky
    #26 johnk..., Oct 17, 2021
    It really does looks a lot like these guys work. https://www.ferrarichat.com/forum/posts/142183798/
  2. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Horrible welding for a 90k car it should look more like the tigged one I posted above. Absolutely crappy job, it's not even refutable.
    Sent using FerrariChat.com mobile app
  3. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    I'll be using OEM valves, some aftermarket ones have thicker seats and stems restricting flow. The OEM ones are waifish. Once you go bigger valves then you have other issues like injectors and fuel pump flow and intake restrictions and possible AF issues etc.
  4. KevZep
    KevZep Formula Junior
    Feb 17, 2020
    568
    New Zealand
    Kevin Bennett
    Not to mention changing the fuel and ignition map....Best to leave these engines as close to stock as possible....
  5. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
  6. johnk...
    Jun 11, 2004
    11,169
    CT
    John Kreskovsky
    Come up Eric, we all want to see the bent valves. Flip those heads over and take a shot! :eek:
    And don't forget one of the pistons too! :)
    QSA likes this.
  7. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    #32 Ferrarium, Oct 19, 2021
    Show the damage, show the damage, bunch of animals.:p
    Kind of hard to see they are not overly bent likely the seats and guides are fine, the pistons are not gouged either, more kissed.
    bradyward and WATSON like this.
  8. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    #33 Ferrarium, Oct 19, 2021
    Am I supposed to scotchbrite the old gaskets off before putting the new ones on? Seems the extra gasket material would help seating.:):p;)
    WATSON likes this.
  9. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    I'm so f'in pissed on that pulley job btw. The upside is new valves will seat 100% there is some carbon build up on some exhausts valves likely from putting around.
    Heading to Olsen Machine tomorrow bright and early, picking up mr308gtb on the way he lives 20 min from Olsen. :)
  10. johnk...
    Jun 11, 2004
    11,169
    CT
    John Kreskovsky
    Yea, death and destruction. That's what we want. :D Looks like you got off pretty easy. That piece of the fence probably got caught under the belt and the belt slipped a couple of teeth before it spit the fence out.
  11. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    #36 Ferrarium, Oct 19, 2021
    I noticed if you do not compress the tensioner enough and you pry the belt off the tensioner it presses hard against the fence since there is not enough clearance and that can loosen the fences over time it I suppose. In my case I compressed it enough with 2 hands while another set of hands tightened it back down the belt simply slid off with no pressure against the the fence. Another option is to remove one intake cam gear and the belt falls off as well.
    Actually yes John, I never though of that... it probably went under the drive pulley itself then spit out, I was trying to imagine how it got under the other pulleys. With timing marks lined up with piston 1 the other bank cam marks were off, about 10 o'clock instead of 12 o'clock. Main drive pulley would do that. Thanks.
    So main timing pulley is now a major or every other major item for me. Found a brand new one for $415 on the shelf at a parts vendor whom I called on a lark. Got a cart full on Ricambi's site for parts needed for re-assembly. First things first though, get them rebuilt. Then winter hits so not in a hurry now. Damn OEM valves are spendy.
  12. johnk...
    Jun 11, 2004
    11,169
    CT
    John Kreskovsky
    Those vales don't look to bad. Just wack them with a hammer until they sit flat in the seats. Good as new. :D
    Here is one way. :eek:
    Yes, some one actually posted that on Pelican Parts forum. :rolleyes:
  13. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Yeah that's sage advice very few things are as accurate as an eyeball and a hammer [emoji38]
  14. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Olsen Engines not Olsen Machine I meant.
  15. johnk...
    Jun 11, 2004
    11,169
    CT
    John Kreskovsky
  16. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    WATSON, chopsui, IvanRico and 4 others like this.
  17. johnk...
    Jun 11, 2004
    11,169
    CT
    John Kreskovsky
    Fix right. Fix it once.
    jimmym likes this.
  18. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    #43 Ferrarium, Oct 23, 2021
    Water manifold crossover has an aluminum fitting that goes to the expansion tank. They get pretty corroded and nasty. Stick the back end of a drill bit in clamp it like a mofo with a set of vice grips and crank it off.
    Hill engineering makes the stainless steel replacement although I suppose you can get a brass one from plumbing supply.
  19. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    #44 Ferrarium, Oct 23, 2021
    Cleaning head gaskets by hand with some light scotch-brite and some brake cleaner, what a b*itch. Hands cramp up after about 10 minutes.
    Add a couple spacers to the crank pulley snout so you can turn the engine without bottoming out the crank pully bolt.
  20. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
  21. QSA
    QSA Formula Junior
    302
    Kingwood, TX
    Quinn
    How is the fence on that new pulley attached?
  22. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
  23. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Qavion likes this.
  24. Rupp3r
    Rupp3r Karting
    Aug 26, 2016
    184
    France
    Hello
    Wow I got TIG welded my fences but I am not anymore confident when seeing your case..
    I look forward to see how it will goes on with the head gasket and the liner protusion issue with the new head gasket..
    Good luck with the repair.
  25. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    What is the liner protrusion issue? The protrusion crusheds the metal part of the gasket between the block and heads, 355 heads and 348 heads get done all the time. There is a Ferrari torque sequence and special tool, what am I missing?
