348 - Engine repair thread | Page 22 | FerrariChat
348 Engine repair thread
Discussion in '348/355' started by Ferrarium, Oct 13, 2021.
  1. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    It definitely pulls harder and longer, it's not like someone dropped a LS1 in it or anything but it's most definitely stronger you can feel it, it's not drastic but it's noticable. 2% leak down will do that I suppose. :)
    ernie and fdekeu like this.
  2. KevZep
    KevZep Formula Junior
    Feb 17, 2020
    568
    New Zealand
    Kevin Bennett
    Great stuff Eric, you must be so pleased to finally have it back on the road again....
    Now, drive the pants off it!! Just like its supposed to have....
  3. Zamboniman308
    Zamboniman308 Formula Junior
    Feb 2, 2020
    504
    Chicago IL
    What a great accomplishment. I've been following along on your journey and a great one its been. Now time for the reward.
  4. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Quick tips...
    I ordered all new OEM shock studs with correct part number, they suck, either you have threads for the nut and it only goes in the shock mount 8mm or it goes into the shock then you have no threads. Below is the part number from Bell metric that fits way better along with the short OEM stud next to the bell metric one.
    Also the brembo part number for the brake caliper bleed caps 100% work on the Teeves calipers that whose beed caps are NLA.
    ernie, KevZep and steved033 like this.
  5. steved033
    steved033 F1 Veteran
    Apr 12, 2017
    9,744
    Atlanta, GA
    Steve D.
  6. AceMaster
    Feb 6, 2009
    34,762
    Ontario, Canada
    You should put this in the "348 parts" thread
    ernie likes this.
  7. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
  8. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    #533 Ferrarium, Jul 24, 2023
    Image Unavailable, Please Login Still shaking it down, want to cross 100 miles before I call it good. Doing 15 min loop of city and highway. Back in and check for leaks, brakes. GB, engine, cooling etc, had one 3/4 in bulkhead cooling hose had to swap a new clamp in as it kept weeping, surprised I missed that clamp. Still not gone over 5500 rpm, not till 100+ miles logged.:)
    Will drop front end 6mm or so to avoid lift if I experience it, usually happens on highway around a sweeper which is un-nerving but so far so good, and I have to say... with factory fresh functional front suspension it's a different car.
    Man the clutch grabs and locks hard, stalled it few times like a noob, in front of people :confused::)
  9. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Ran out for lunch, better pic of current stance and chassis angle. Seems rather close to what it should be, maybe a tad lower in front which is advantageous to avoid lift.
  10. JLF
    JLF Formula 3
    Sep 8, 2009
    1,703
    Love the wheels!!
  11. solana_sc
    solana_sc Rookie
    27
    SC, USA
    Walt Oliver
    It looks terrific, Eric. So glad you'll be able to drive it all over now!
  12. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Ok not sure if there's a rule but did 100 miles spinning motor in a gear to get 4k while driving around, highway blasts, stop and go stop lights, crossed 100 miles and head gaskets hold and no leaks and engine still purrs, I'll call it good.
    Runs like a raped ape, purrs like a singer sewing machine.
    Thanks for the support and tech advice and watchful eyes spotting things I missed or did not consider.
    Time to end this thread. Watch for new ones, rear shock rebuild, carpet install, maybe repaint the black lower sections as they tend to fade, maybe yellow calipers. :)
  13. 308 GTB
    308 GTB F1 World Champ
    11,663
    New Jersey
    Barry Wolinsky
    You worked hard on your 348, Eric. Now it's time to enjoy the ride.
    Bravo!
    Barry
  14. KevZep
    Feb 17, 2020
    568
    New Zealand
    Kevin Bennett
    Give it some full boot to redline, they love it, especially if its got a few miles on it with no issues....
    You've done a very meticulous job, time enjoy the fruits of the labor!!
    The car looks great, ride height looks and stance looks awesome...
  15. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,613
    The Brickyard
    The Bad Guy
    Nice job Eric.
  16. Ricambi America
    Sponsor Owner
    And let's be honest here, that's one fine looking chapeau you're sporting.
  17. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Ha ha! I need more of them!
  18. Zamboniman308
    Feb 2, 2020
    504
    Chicago IL
    Ha I hear you. I was disappointed i didnt get one with my last big order. Time for a new crisp white one.
