Engine symbol at start? | FerrariChat
Discussion in '360/430' started by cyclisto, May 23, 2009.
  1. cyclisto
    cyclisto Formula Junior
    Nov 21, 2008
    357
    Utopia
    Sy Kleesteau
    Sometimes the engine symbol will light up when I start the 430, other times it won't. Sometimes it stays on for roughly a minute, then it turns off. I guess I shouldn't worry about it unless it stays on, but why does it sometimes light up at all? Another Ferrari gremlin rearing it's ugly head? Should I take it in to the dealer?
  2. TheMayor
    TheMayor Nine Time F1 World Champ
    98,797
    Vegas baby
    My 08 430 always stumbles at start up and the engine light is on. Then, after about 5 seconds or so, the engine smooths out and the light goes off.
    I've had a problem with the engine light staying on permanently and the dealer has sent the ECU's back to FNA 2 times for reprogramming. I haven't had any problems with the light staying on since the last reprogramming but the stumble remains as it has since I received it new. I have to assume that this is the way it's supposed to start and run as the two banks synchronize. Honestly, I don't worry about it as long as the light doesn't stay on permanently.
    As to not coming on at all, I've never seen ANY "check engine" light in any car not light up when started. That does sound a bit weird. If that's happening, I would have it checked out. They should be able to read the codes pretty easily and figure out what's up.
    And, a minute of stumbling sounds like quite a bit. A few seconds I would say sounds normal. A minute of stumbling sounds extreme, even in severe weather.
  3. RSQP
    RSQP F1 World Champ
    15,463
    California
    Beaker
    When firing up the Scuderia, the CEL comes on and the engine almost sounds like it's going to stall, but then picks up as if nothing happened. The techs said not to worry about it. Sounds like it might be a feature.
    The fact that these mostly hand-built cars perform the way they do, not to mention the fact that they run at all, is pretty remarkable.
  4. fc2
    fc2 F1 Veteran
    Nov 2, 2006
    5,263
    Silicon Valley Ca.
    Frank C.
    Every time I start my '07 F430, the CEL comes on and stays on for roughly 15 seconds, but of course it feels like it's a lot longer because I'm staring at it wishing it away.
  5. cyclisto
    Nov 21, 2008
    357
    Utopia
    Sy Kleesteau
    that's what i thought. i guess the 15 secs feel like "a minute." but if it doesn't come on at all, should i be worried?
    thx guys!
  6. Rifledriver
    34,138
    Austin TX
    The light is supposed to come on as a test every time the motor is started. It is run by a timer and should go off at the same interval every start.
  7. 430-Scuderia
    430-Scuderia Karting
    Oct 20, 2008
    63
    Netherlands
    Ok, my Scuderia also does that sometimes. Cold-start. The car shakes, oil pressure is low and when you hit the accelerator to get out of the garage it almost stalls. I always turn it off and start it again. When you do that, second time, no "problem" whatsoever.
  8. $$$=SPEED
    $$$=SPEED F1 Veteran
    Aug 18, 2004
    5,330
    Portland, Or. USA
    Depends who's asking
    So funny I do the same thing. "come on go off...come on go off" :)
  9. Solobagpiper
    Solobagpiper Karting
    May 6, 2009
    114
    Piedmont, California
    Mark Frost
    check to make sure that your gas cap is tightened all the way down.
  10. JMC08
    JMC08 Rookie
    Oct 30, 2014
    23
    I am having similar issues. The car always stumbles at start up, and acts like it will stall. The CEL light usually stays on for 12-17 seconds. According to the owner's manual, it is only suppose to stay on for 4 seconds after startup. Today, I drove it to Lowes. I turned off the car long enough for my wife to take the key and turn the passenger airbag back on, then I turned started the car back up. After startup (from the engine being off for maybe 30 seconds) the car idled extremely rough for a good 30-45 seconds before smoothing out. Ten minutes later after my wife came back out from the store we pulled away and left. Going through the parking lot (10 mph) we came to a stop sign. The car then stalled on us. I put the car in neutral and pressed the starter button, the car fired right up as if nothing had happened. Any ideas what may be going on? Thank you in advance.
  11. Red 27
    Red 27 Formula 3
    1,001
    San Diego, Ca
    Dave
    Are you waiting for the "OK" to appear before pushing the start button?
    My 07 430 check engine light stays on for about 17 seconds before going off after startup.
  12. Perkins
    Perkins Formula Junior
    Dec 22, 2013
    702
    Sacramento
    Rick
    Mine does the same thing. I'd guess about 10-15 seconds at each start.
  13. big_guy
    big_guy F1 Rookie
    Sep 9, 2007
    3,190
    Ontario, Canada
    Same with mine.
  14. Rbwiii
    Rbwiii Formula Junior
    Aug 9, 2014
    606
    Cali
    BW
    My 07 does the same also
  15. Joegnsx
    Joegnsx Formula Junior
    Dec 1, 2012
    955
    Valrico, FL & Franklin, NC
    Joe Gliksman
    My 05 also takes about 15 seconds for the CEL to go off--every time I'm pretty sure.
  16. scudF1
    scudF1 F1 Rookie
    2,866
    Long Island, NY
    Billy
    I timed mine before. It is not consistent all the time. Sometimes it takes 8 and sometimes 10 min. I noticed that the first time you start the car and its cold, it takes longer.
  17. F360-1386
    F360-1386 Formula 3
    Oct 8, 2006
    1,685
    Markham, ON, Canada
    51216M
    Normal , nothing to worry! Mine was on since day one for few years around 10 sec , it was gone.
  18. JMC08
    JMC08 Rookie
    Oct 30, 2014
    23
    Thanks for all the replies. The Scuderia is our first Ferrari, a lot to learn. I did wait until the dash gave me the ok before pressing the starter button today. The car did not stumble upon cold start. The only thing I still question though is the rough idle after restarting the engine (warm) 30 seconds after turning it off...and then the stall ten minutes later. Otherwise, the car is amazing and loads of fun. Very mechanical, and just takes a bit of time to adjust to.
  19. Red 27
    Red 27 Formula 3
    1,001
    San Diego, Ca
    Dave
    You need to wait for the "OK" every time you start the car.
  20. Xcheckme
    Xcheckme Formula 3
    May 10, 2011
    1,682
    Tampa Bay
    Lukas
    This - but even then it is normal for the check engine light to stay illuminated for up to 15 seconds.
