Espada thread | Page 19 | FerrariChat
Espada thread
Discussion in 'LamborghiniChat.com' started by lambomiura, Mar 26, 2008.
  1. Olivier NAMECHE
    Olivier NAMECHE F1 Veteran
    Aug 18, 2007
    5,099
    CANADA
    Olivier
    #451 Olivier NAMECHE, Jun 6, 2009
    I want to upgrade my thermostat & cooling with this device.
    Anybody can provide me where I can buy it ?
    Thanks in advance.
    Olivier
  2. raymondQV
    raymondQV F1 Rookie
    Aug 22, 2007
    4,069
    Switzerland
    Raymond S.
    This a simple FIAT Thermostat, the same was also used in the 4 and 5l Countach and the Jalpa.
    Unfortunately I don't have the FIAT reference in mind, number is 9.10.331.00
  3. Olivier NAMECHE
    Aug 18, 2007
    5,099
    CANADA
    Olivier
    Raymond,
    is this number the Lambo reference for the casing itself or the complete part including the thermostat ?
    if you can find the FIAT reference, my wallet will own you a favor !!!
    Olivier
  4. staatsof
    96,503
    Fuggetaboutitland
    Bob
    #454 staatsof, Jun 7, 2009
    I don't remember if we had this discussion on VLG or if I had it privately with someone but here's what I found out when I started looking at doing this.
    I have the earlier system pictured here:
    http://www.eurospares.co.uk/partTable.asp?M=2&Mo=653&A=1&B=37752&S=
    This is the later system: #7
    http://www.eurospares.co.uk/partTable.asp?M=2&Mo=653&A=1&B=37755&S=
    This is on Ebay so it looks like a 67-77 Fiat 124 spider:
    http://cgi.ebay.com/ebaymotors/1977-67-77-FIAT-124-SPYDER-SPORT-WORKING-THERMOSTAT_W0QQcmdZViewItemQQ_trkparmsZ65Q3a12Q7c66Q3a2Q7c39Q3a1Q7c72Q3a1205Q7c240Q3a1318Q7c301Q3a1Q7c293Q3a1Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZitem4398754cdfQQitemZ290320633055QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
    Is this what you're trying to do?
    I found a thermostat from a 3500 Maserati that was very similar for about $70. It looked like it might be able to be adapted. Length between the pipe and the radiaor is the issue since there's not a lot of room between the existing pipe and the radiaitor. You need some hose for flexibility or things will crack. I'll bet there are several types of these out there. I don't know if the temperature calibration is correct enough though.
    These are the guys that had it:
    http://stores.shop.ebay.com/OVRST2-AUTO-PARTS__W0QQ_sidZ191625243?_nkw=thermostat&LH_TitleDesc=1
    Bob S.
  5. Olivier NAMECHE
    Aug 18, 2007
    5,099
    CANADA
    Olivier
    #455 Olivier NAMECHE, Jun 8, 2009
  6. GIOTTO
    GIOTTO F1 Rookie
    Dec 30, 2006
    3,941
    France
    #456 GIOTTO, Jun 9, 2009
  7. Jota 5084
    Jota 5084 Formula 3
    May 18, 2006
    1,922
    Sweden
    Eric Andersson
    There was an original blk/white photo of this car for sale on ebay some while ago.
    I think the F-Chat member italiancars who has an Iso Lele Marlboro #184 maybe can give us some input on this car?
  8. Olivier NAMECHE
    Aug 18, 2007
    5,099
    CANADA
    Olivier
    #458 Olivier NAMECHE, Jun 10, 2009
    I don't have the original one-negative (that is also a copy)...
    Here is the pic, it was shoot at Formula 1 Grand Prix of France in the paddock !
  9. raymondQV
    raymondQV F1 Rookie
    Aug 22, 2007
    4,069
    Switzerland
    Raymond S.
    Ha, have the VIN of this car:
    7858 1970 ~ Red White Philip Morris SA in 1972, registred VD11395
    finally also pictures...
  10. Olivier NAMECHE
    Aug 18, 2007
    5,099
    CANADA
    Olivier
    You wake up early Raymond...did you found that FIAT thermostat reference ? I got the price from Lambo for it (S3 Espada OEM) and just for a Thermostat I believe it expensive : 123 €. Should be half of that at FIAT ?
  11. Daryl
    Daryl Formula 3
    Nov 10, 2003
    1,036
    Barrington Hills, IL
    Daryl Adams
    After getting no response from the VLG forum I thought I'd ask you guys. We're doing a clutch job on my 1968 SI Espada and it looks like the flywheel needs attention. Does anyone know what the dimensional specs are for resurfacing a series I flywheel? Thanks.
  12. Olivier NAMECHE
    Aug 18, 2007
    5,099
    CANADA
    Olivier
    #462 Olivier NAMECHE, Jun 10, 2009
    Bod,
    Thanks God to...Raymond, he provides us the correct number for that original FIAT 124 Spider thermostat #910331 used as well as in 5000S and Jalpa. Your mind is not that altered yet !!!
    Thanks to Martin, here is a pic of it, it will be in my hands next week and I will publish modification on my GTS later.
    Since, one of my LCB members owning & driving an Espada S3 confirmed me he never overheats downtown, trafficjam as well as at high speed in summer, his engine stays cool around 80° C to 90° C.
    Ciao
  13. raymondQV
    raymondQV F1 Rookie
    Aug 22, 2007
    4,069
    Switzerland
    Raymond S.
    Yes, Savara, most of the Lambo Thermostats were produced by Savara, I had one in stock but sold it when I sold the Jalpa in 2006.
  14. staatsof
    96,503
    Fuggetaboutitland
    Bob
    Hi Daryl,
    I think I'd contact Jack on VLG directly as he'd know. Also, Gary Bobileff who is on this site from time to time will certainly know. But I think that a really decent clutch rebuilding company will be able to adequately judge this. They can probably rebuild the clutch disc and pressure plate as well as balance everything.
    Bob S.
  15. staatsof
    96,503
    Fuggetaboutitland
    Bob
    #465 staatsof, Jun 11, 2009
    Well good to have that number. I'm just not clear which car you have and whether you're just replacing the same thermostat or if you have the older style one that's inside the coolant tube?
    From what I've heard the later radiators had changes made to them to alter the flow inside of the radiator and this helped to make them more efficient. A modern set of fans will surely help in slow traffic. I also think that fans mounted on the backside with a shroud that has the rubber blow through flaps probably would do a lot better than the front mounted ones.
    I'm not convinced that a simple thermostat change is going to help unless your current one is deffective. My interest in the later style thermnostat is to allow for engine block recirculation while the engine warms up,
    As far as I can see with the early design cooling system you have to put the heater valve open to allow for any recirculation within the block before the thermostat opens. This is not a popular idea in mid summer ...
    I think this is probably the part you're looking for?
    http://www.international-auto.com/index.cfm?fa=p&pid=2474&posid=853103
  16. thedoc
    thedoc Formula 3
    May 27, 2009
    2,159
    Gents :
    I just finalized my deal and this car is now mine and on its way to Gary Bobileff shortly and then on to its new home just outside of Toronto. If anyone has info on this car in addition to what has been supplied would be welcome.
    Warm regards
    Gary
  17. lambomiura
    lambomiura Formula Junior
    May 18, 2006
    646
    Canada
    Philippe Muratori
    Hey Gary, that is good news, glad you bought the car after all. Welcome to Espada and classic Lambo ownership. Wish you years of driving and pleasure.
    Best.
    Philippe Muratori
    S2 7987
    www.lamborghinimiura.com
  18. thedoc
    thedoc Formula 3
    May 27, 2009
    2,159
    thanks !
    It will be on its way to Gary Bobileff next week or the one after should see it here mid july
    i will contact you further on email
    Gary
  19. f1lupo
    f1lupo Formula Junior
    Aug 4, 2008
    727
    Toronto, Canada
    Johnny S
    Big congrats Gary !!! It'll be great going on drives with both the Espada and 328GTS :)
  20. Olivier NAMECHE
    Aug 18, 2007
    5,099
    CANADA
    Olivier
    #470 Olivier NAMECHE, Jun 15, 2009
    NEP likes this.
  21. lambomiura
    May 18, 2006
    646
    Canada
    Philippe Muratori
    Nice find Olivier! I can't read the engine number: 411??
    Philippe
    S2 7987
  22. Olivier NAMECHE
    Aug 18, 2007
    5,099
    CANADA
    Olivier
    Engine #41185
  23. Miura Jota
    Miura Jota F1 Rookie
    May 26, 2004
    3,632
    Toluca , Mexico
    Martin
    a newbie question :
    was the ESPADA the blueprint for the early 70's american muscle cars ?
    or why does it look so different than the other 60's Lambos
    and similar to ...let's say Charger etc. ?
    what happened back then ?
    and I'm still amazed bu the fact of a ESPADA being more expensive than a Miura back then
  24. Olivier NAMECHE
    Aug 18, 2007
    5,099
    CANADA
    Olivier
    #474 Olivier NAMECHE, Jun 16, 2009
    Bob,
    this simple thermostat is making a difference, due to its recirculation in the engine while still water cold OR while warm it opens to radiator. If I mis-explain, have a look on the chart at Eurospares, you will notice the different head cap on the water pump with a dual access instead of a single one on previous model. So this modifications requires one dual cap on water pump or a transformation with a "Y" hose in addition to that thermostat.
  25. espada1952
    espada1952 Karting
    May 4, 2008
    150
    London
    stephen keen
    Hi Olivier
    Your car is like mine,late production model,they have a different radiator and hose arrangement to the earlier cars,I have changed the hoses and the thermostate housing is now in a different position,I believe the bottom hose is no longer available? I tried a late Espada bottom hose but it did not fit. The other problem with the late Jarama with power steering is the steering ball joints which are fixed to the tie rod as a complete unit,I don.t think these are available?
    Stephen Keen
