Euro model front indicator/parking light cross slot screws | Page 2 | FerrariChat
Discussion in '206/246' started by GermanDino, Oct 6, 2023.
  1. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,350
    Norfolk - UK
    Tony
    Stefan,
    Nice ACAD work. One thing that troubles me is the length. Although the original is 12.mm long (from under head) I fear these may be to short.
    If owners have replaced the lens gasket, which is thicker than the original, then the lens cover will be set further away from the fixing holes. For me they need to be 16mm long min.
    The head dimension is also critical
    Tony
    DinoParts, Stefan likes this.
  2. racerboy9
    racerboy9 F1 Rookie Silver Subscribed
    Nov 3, 2003
    2,687
    Those screw holes in the lens are notorious for cracking. I put a small o-ring or x-ring behind the screw head and just snug them.
  3. dgt
    dgt Formula 3 Owner Silver Subscribed
    Jan 14, 2011
    1,293
    Northeast, USA & Oz
    Andrew
    Yes - originally, there was a plastic washer behind the head to seal and spread the load - you can see it in the photos Matthias posted at the start of the thread. Long since disappeared on many cars along with the correct screws!
    BTW these were my photos, we got started looking for these some time ago... I was missing these from my Dinos and used a similar M4 from McMaster Carr.
  4. DinoParts, Stefan
    DinoParts, Stefan Karting Sponsor
    Mar 1, 2015
    144
    Eschwege, Germany
    Stefan Kratzer
    OK I will get the stainless screws ordered from the link 4CamGT showes.
    The head will have a slightly different apearance as shown in the CAD comparison. Is that fine for you guys?
  5. bradley baum
    bradley baum Rookie
    May 1, 2005
    36
    Count me in for 10. Please post pricing and availability. Thank you for sourcing these.
  6. DinoLasse
    DinoLasse Formula Junior Silver Subscribed
    May 26, 2009
    606
    Sweden
    Lars
    No, not for some of us. The CAD comparison shows clearly that the head is a Pozidriv type. I would not use a Pozidriv screw on a Dino. Not period correct to me - and not the correct type to use on a fragile plastic lens (the main advantage with the Pozidriv is the higher torque possible). I would use the Phillips head screw and turn the head diameter down.
  7. daytonaman
    daytonaman Formula Junior
    May 1, 2007
    986
    Australia
    howard pigdon
    Correct, if the head is not high enough in the lens then use an extra plastic washer
    DinoLasse likes this.
  8. DinoLasse
    May 26, 2009
    606
    Sweden
    Lars
    Sorry to be the troublemaker, Stefan DinoParts. I know we are a difficult crowd to please around here. But since you asked for our opinion, we have to give it.
    For most halfway normal people, I am sure the version you planned will be perfectly OK. But I and a few others would not like the Pozidriv head. That's all I wanted to say.
    swift53 likes this.
  9. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,350
    Norfolk - UK
    Tony
    Tend to agree with Lars on this, to get something close to the original is near impossible as most standard machine screws are to big. The M4 x 0.7 mm thread is OK. However i found some machine screws which match the original but are too long.
    from Left to Right
    The 1st screw is the original, the next is the unmodified captive M4 screw but with 6.8mm head and Philips drive, the next is one i modified to suit my car. I made them longer so they actually sit into the lens holder better and because of new gaskets.
    The last one is a standard M4 machine screw but the head diameter is 8mm and doesnt fit into the recess of the lens cover.
    Downside is that these are nickel plated and after re-threading they will need coating to prevent rusting.
  10. tx246
    tx246 F1 Veteran Owner Rossa Subscribed
    Nov 4, 2003
    6,705
    Texas
    Shawn
    I don't think I have ever had so much interest in watching talk about these screws.
  11. DinoParts, Stefan
    Mar 1, 2015
    144
    Eschwege, Germany
    Stefan Kratzer
    No worries. That's why I asked and pointed it out. Will try to source some with philips heads then but fear will have to compromise with a less high head that needs to be corrected with a thicker washer.
  12. DinoParts, Stefan
    Mar 1, 2015
    144
    Eschwege, Germany
    Stefan Kratzer
    Making a few longer ones will not be a problem.
  13. racerboy9
    Nov 3, 2003
    2,687
  14. Mark Shannon
    Mark Shannon Formula 3 Silver Subscribed
    Dec 28, 2003
    1,248
    Surrey, UK
    What was the outcome of all this please ?
    My indicator units are off the car right now. The lens covers had been held down with self tapping screws and we recently cleaned up the threads in the housings which will now take M4 screws easily again.
    Right now I have nothing that will work at all.
    Mark
  15. lagunacc
    lagunacc F1 Rookie Rossa Subscribed
    Aug 24, 2013
    4,753
    Same as the 206 screws, right?
    swift53 likes this.
  16. Pantdino4
    Pantdino4 Karting
    Sep 17, 2015
    197
    Los Angeles
    Jim Oddie
    I love McMaster-Carr. Great source of things you'd never find otherwise.
  17. lagunacc
    Aug 24, 2013
    4,753
