News
Exhaust recommendations - 360
Discussion in 'United Kingdom' started by Hud, Sep 29, 2005.
  1. Hud
    Hud F1 Veteran
    Jan 26, 2005
    6,353
    Rob
    Not really heard too many different exhausts on 360's yet. Whats the options and prices? Any sound bites appreciated. Which one's the daddy.
  3. stevep
    stevep F1 Veteran
    Jan 19, 2004
    8,330
    Geordie Land
    steve
    leave the standard one on , capristo is crap on 360 and tubi's are for men with small willies
  4. tonyh
    tonyh F1 World Champ
    Dec 23, 2002
    14,372
    S W London
    Tony H
    standard is cack, let everyone know you have a small willy and buy a Tubi ;)
  5. Hud
    Hud F1 Veteran
    Jan 26, 2005
    6,353
    Rob
    Standard sounds ok at high revs, but car is f1 so cant drive round revving it:)
  6. monge2
    monge2 Karting
    Feb 24, 2005
    90
    Essex
    Martin
    going de-cat mate??
  8. 360stimo
    360stimo Formula 3
    1,284
    If i didnt give a **** about my neighbours, i probably would have put a Tubi on, but because i do give a **** and the times i was going in and out, i left the standard on. I personally think the Standard is fine. If you want to make noise with it, you can. With a Tubi, you can only make noise, which is fine, but if you have close neighbours or live in London where everyone is on top on everyone else, it can get really annoying and a little embarrasing !
  9. Hud
    Hud F1 Veteran
    Jan 26, 2005
    6,353
    Rob
    It was nice with the flames on the 355 but seems more hassle come MOT time than its worth. The cats on the 355 were knackered ill wait till the 360 ones are shot i think.
  10. spidermanUK
    spidermanUK Formula 3
    Feb 26, 2005
    1,602
    Clive
    If you really MUST leave the awful std exhaust on, at least disconnect the bypass valves so that it sounds slightly less like a Nissan Micra.Instructions including pics have been posted on here, and it's simple enough that even I managed it in about 10 minutes!;)
  11. Hud
    Hud F1 Veteran
    Jan 26, 2005
    6,353
    Rob
    Sounds good - wheres the post?
  13. spidermanUK
    Feb 26, 2005
    1,602
    Clive
    Rob
    I've e-mailed you the details which were very kindly sent to me by a chatter from the Euro section
  14. Hud
    Hud F1 Veteran
    Jan 26, 2005
    6,353
    Rob
    Spank your hairy crutch. Ill check my box.
  15. Ade
    Ade Formula 3
    Jan 31, 2004
    2,095
    I dont like the standard one at all. Tubi is your best option, perhaps get a secondhand one a try it out
  16. Trax
    Trax Formula 3
    May 26, 2005
    1,349
    Douglas
    Could you send me a copy please
  17. stevep
    stevep F1 Veteran
    Jan 19, 2004
    8,330
    Geordie Land
    steve
    and me please
  18. Robgvx
    Robgvx Formula Junior
    Oct 7, 2004
    250
    RobGvx
    Stock exhaust sounds gay.
    Tubi for me (and let me tell you guys, I laugh in the face of your willie association).
  19. ferrari355gtb
    ferrari355gtb Formula 3
    Nov 3, 2003
    1,600
    R
    Totally agree.
    Drive it std for a month then put a Tubi on - it's like a new car again !!
    Sod the neighbours (having an on going rant and rave at the moment - "can you park it round the corner ?" - yeah WHATEVER !!)
    Rick
  20. spidermanUK
    Feb 26, 2005
    1,602
    Clive
    #18 spidermanUK, Sep 29, 2005
    Here are the details I was sent, all credit to the nice guy, Vaughan, who sent them to me!
    on the spider there are some panels in the engine bay that you might have to remove to gain access to the connector. It is really as simple as unclipping the connector, there is a square spring device on the collar or the connector that you press in and then the connector pulls off neatly. The sound is much deeper at idle and you have the advantage of being able to connect them again at will. On cold startup it will sound rather loud, however this quietens down as the engine and exhaust opens.
    I am not aware of any potential damage/warranty issues, however if your taking your car in for servicing at a authorised dealer you could just reconnect prior to taking you car in. If anything at is allowing you car to breath easier, also a lot of car manufacturers install these devices purely to get past strict drive by noise regulations for licensing reasons. Some manufactures deliberately program power drops at the exact point (RPM) where the noise reading would be taken, typically ½ through the rev range.
  21. Modena Scotland
    Modena Scotland Karting
    Mar 2, 2005
    196
    Scotland, UK
    Mass
    Get a Capristo level 2. It sounds so much better. I am usually the loudest car on a track.
  22. barabus
    barabus F1 Rookie
    Aug 22, 2004
    4,777
    12 Cylinder Village
    Si
    Clive get cleaning that injuns filthy :D
  23. spidermanUK
    Feb 26, 2005
    1,602
    Clive
    Wasn't mine Si, belonged to the bloke who helped me make my car sound a bit more grown up!
    No idea how clean mine is, haven't seen the car for a few months!
  24. jimmmy
    jimmmy Rookie
    Aug 8, 2005
    43
    Jimmer
    where abouts in the engine bay is it located ? cheers
  25. barabus
    barabus F1 Rookie
    Aug 22, 2004
    4,777
    12 Cylinder Village
    Si
    How come??
  26. spidermanUK
    Feb 26, 2005
    1,602
    Clive
    IIRC As you stand at the centre of the back of the car, if you lean into the engine bay (best done with a cold engine unless you want a Ferrari logo on your forehead), and look down to the right,near the exhaust box, just fwd of the rear light covers, you should be able to see it. There is a matching one on the LHS. If you print the pics above, and take them out to your car, you should recognise certain features.
    On a Spider, you need a hex key to remove the covers at each side of the engine bay.
    Good luck, and don't blame me if you pull the self-destruct lever, rather than the tasty noise switch!;)
  27. spidermanUK
    Feb 26, 2005
    1,602
    Clive
    Mine's in a certain showroom seeking a new owner! Alas not found one so far!:(
