F1 Clutch Job | Page 12 | FerrariChat
F1 Clutch Job
Discussion in '360/430' started by Andrie, Jul 18, 2016.
  1. mike01606
    mike01606 Formula Junior
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
    You bleed the fluid from the clutch bleed block which is on the RHS of the gearbox.
    Run the fluid into a container and make sure the reservoir stays topped up. Don't just run it back into the reservoir.
    If it is the original bleed block be careful not to crack it by over-tightening the bleed nipple.
    HE do a replacement part which is better made.
  2. mike01606
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
    That's a real pity......how did you get the update? Via MS6?
  3. Virulosity
    Virulosity Karting
    Jun 26, 2017
    162
    Orange County CA
    Rob
    This is the brake reservoir or the F1 reservoir?
  4. chdavis
    chdavis Karting
    Sep 19, 2015
    66
    Philadelphia, PA
    Christopher
  5. ShineKen
    ShineKen F1 World Champ Silver Subscribed
    Aug 3, 2007
    19,892
    Southern California
    Nostradamus
  6. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,775
    It is only a matter if time before it works. Good to know they are working on it.
    People need to submit a bug report for stuff that needs fixing.
  7. Motob
    Motob Formula 3 Professional Ferrari Technician
    Nov 11, 2003
    2,365
    Frederick, Maryland
    Brian Brown
    The e-diff bleed is not a part of the F1 transmission software. The E-diff has its own separate software with bleed function.
  8. chdavis
    chdavis Karting
    Sep 19, 2015
    66
    Philadelphia, PA
    Christopher
    I have twice!
  9. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,900
    Central NJ
    Dominick
    Any updates on software ?
    Sent from my Moto G (4) using Tapatalk
  10. Wayne 962
    Wayne 962 Formula Junior Rossa Subscribed
    Nov 27, 2003
    503
    I have the same car (2000 360 Modena), and it shows that the first version of the gearbox is installed, but then it won't let me connect to it. This XDiag software is good if you have nothing else, but it really doesn't work too well on these specialized cars.
    -Wayne
  11. mechanicservice6
    mechanicservice6 Karting BANNED
    Feb 13, 2017
    71
    Only the 360 has had issues, for other models is great, key programming, proxy alignments, new airbag module initialization, tpms calibration, odometer corrections, plus all the actuations test that can be performed on almost every module. Besides the 360 which I been bugging the developers about, it works great. As soon as they get a fixes update, I'll let you know to test on the 360.
    Sent from my SM-G955U using Tapatalk
    flash32, Hacan and KJB355 like this.
  12. mike01606
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
    Just to keep adding to this thread.....
    I’ve been using xdiag on my car over the last couple of months for some clutch work.
    Car is a 2000 Modena with a CFC231 based CS TCU part number 196986
    I’ve used it to take lots of readings on clutch and actuator positions along with bleeding the clutch after a release bearing change.
    So far very good and I couldn’t have done any of the work without it.
  13. sanfran
    sanfran Formula Junior BANNED
    Apr 10, 2004
    523
    LA
    Oliver
    I looked though the entire thread and did not find where I can get the software for $50.
    Any ideas?
  14. unhguy86
    unhguy86 Rookie
    Feb 10, 2013
    4
    Reading earlier in the thread, you can PM mechanicservice6 and should be able to help you out.
  15. tonino ct
    tonino ct Karting
    Mar 1, 2018
    140
    tony
    please help anybody..my 360 transmission warning buzzer goes off in traffic or backing up a hill.
    does anybody knows y?
    is a pump problem?
  16. Skidkid
    Skidkid F1 Veteran Owner Rossa Subscribed
    Aug 25, 2005
    9,519
    Campbell, CA
    John Zornes
    With your apparent knowledge about the system you need to seek professional help. Get your car to someone who has the tools and experience to work on the F1.
  17. tonino ct
    tonino ct Karting
    Mar 1, 2018
    140
    tony
    but it only happens when get hot in traffic,somebody told me it is normal,is it true?
  18. mkzhang
    mkzhang Formula Junior Silver Subscribed
    Oct 5, 2009
    544
    Philadelphia
    No. It's not. Your clutch is overheating
  19. tonino ct
    tonino ct Karting
    Mar 1, 2018
    140
    tony
    the clutch as 80% left. can it be a bad sensor?
  20. Skidkid
    Aug 25, 2005
    9,519
    Campbell, CA
    John Zornes
    This is likely true. Is there a sensor issue? Who knows but the little bit of information you provided doesn't give any way to determine that. I stand with my first post, get professional help. You don't know enough, and no one on this board can tell without a readout from an SD or similar tool. Even then, it may take some testing to diagnose the issue.
  21. scuderia09
    scuderia09 Formula 3 BANNED
    Sep 6, 2007
    1,045
    Check the pressure of the pump when hot you would need a Leonardo scanner to find and check the pump relay could be over heating also
  22. evilruss
    evilruss Karting
    Jan 27, 2015
    57
    Rockford
    Just checking if anyone has heard anything further on updates to adjust PIS using decimals? Spring is around the corner here and was hoping to be able to try and fine tune the PIS value when I get the car back out.
  23. dwil
    dwil Karting
    Nov 8, 2003
    114
    ozarks
    Dave Wilson
    I am looking at this topic often as my car skipped in to neutral twice when shifting 1st to 2nd a few weeks ago. It was a very cold
    day and the car wasn't quite warmed up. I have driven about 100 miles since and it has worked
    fine. I know there is a day that i will have to deal with f1 issue, and i never have owned a car
    that required me to go to a mechanic to resolve a problem. (I am 59 and never hired a mechanic
    in my life) So a functional, affordable diagnostic tool for the f1 would be invaluable for me
    to keep my car on the road.
  24. Wayne 962
    Nov 27, 2003
    503
    Here's what I can add: I have a 2000 360 F1, and I just upgraded the computer to a 2002 model (don't have the PN handy). The xdiag tool still would not read the transmission computer property (it would identify it, but it wouldn't communicate with it). I just sent the computer to Eric in France to have it reflashed with the Challenge CS programing. Not the xdiag tool will read and communicate with it. I have not checked to see if it fixed the decimal problem yet. One step at a time!
    thx
    Wayne
  25. evilruss
    evilruss Karting
    Jan 27, 2015
    57
    Rockford
    Definately curious if you find the decimal working and if so what version of the software you have. As far as I know up through 10.26 doesn't work unless you were able to get a newer version than that.
    Sent from my SM-G920V using FerrariChat.com mobile app
