430 - F1 gearbox annoyances | FerrariChat
430 F1 gearbox annoyances
Discussion in '360/430' started by Gillis Haasnoot, Dec 30, 2020.
  1. Gillis Haasnoot
    Gillis Haasnoot Karting
    Feb 4, 2020
    104
    Leiden, Netherlands
    Gillis Haasnoot
    Hello. I just recently purchased a 2006 f430 F1 with 40k miles.
    For some years I am driving a Maserati 4200 with the same gearbox.
    I noticed some annoying differences in my f430.
    On the f430 when I slowly accelerate and shift up at low rpm, let's say 3k, the car slightly blips. Just a tiny bit, but it feels a bit odd. It's like when you shift in a manual car, but not release the accelerator enough. Is this normal? It seems to be creating unnecessary slip.
    Second. When I accelerate full throttle I smell and see smoke coming from the clutchplate occasionally. I did some tunnel accelerations today and it was clearly visible between the hard shifts.
    Third. With the f430 it feels that I have to press the accelerator deeper to get the car going forward/backward starting from a still position. There is much more slip. And creates the feeling that the f430 weights twice as much as the Maserati (which is of course not the case at all)
    And the last point is that I noticed two times that the gearbox had some difficulties selecting the first gear from neutral. You hear these gearbox lever clicks a couple of times more than normal. In both cases it succeeded after 1 or 2 retries. This happened just twice in the 1000 miles I drove last 2 weeks.
    My Maserati from 2002 with 100hp less, a 30k old clutch and an older TCU doesn't have these annoyances at all. It's shifts a bit slower, but feels somehow better.
    The clutch of the f430 got replaced about 3k miles ago. Car drives amazing.
    Keen to hear some options.
  2. imahorse
    imahorse F1 Rookie
    2,778
    WI
    Dustin
    Ummm if your clutch is slipping that bad you have problems.
    armedferret likes this.
  3. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,138
    Seattle, Wa
    Dan L.
    Take your car to your local dealer or a reputable Ferrari mechanic and have them adjust the clutch properly ASAP.
    Your clutch needs adjustment big time.
    Anytime you slip the clutch, anytime you see smoke you are burning your clutch and shortening its life.
    I say dont drive it until you get your clutch adjusted properly.
    jag-oo-r and Flyingbrick242 like this.
  4. nickorette
    nickorette Formula Junior
    Jun 19, 2017
    341
    Canada
    Has the accumulator ever been replaced? Low hydraulic system pressure can cause all kinds of F1 gearbox issues, the F430 accumulator is a wear part. You can also install scud inc relay to detect faults in system. Maybe even relay is gone bad over time.
    honda corse likes this.
  5. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,692
    Central NJ
    Dominick
    Where was it replaced? Could it be it was never setup properly? I would have the place that did the clutch connect a diagnosis tool to the car and look at the parameters. A skilled eye will see exactly what is going on from the numbers ..clutch setup wrong , bad pressures , etc
    Sent from my moto g(7) using Tapatalk
  6. RichardCH
    RichardCH F1 Rookie
    4,661
    new clutch $9k, just done it
  7. Ferrari Tech
    Ferrari Tech Formula 3
    Mar 5, 2010
    1,126
    Georgia
    Wade Williams
    As stated already. Get to a shop that has the proper diagnostic tools and a skilled tech to use them and have it checked. It is clear that the set up is all wrong.
    whatheheck likes this.
  8. armedferret
    armedferret Formula 3
    Mar 24, 2018
    1,140
    Maryland
    Mark
    Was the shop that replaced it local to you? Sounds like they definitely didn't do it properly. If it was done by a dealer I'd take it to them and ask them what they were drinking that day. Then ask them to make it right.
