F12 height adjust on stock springs | FerrariChat
Discussion in 'F12/812' started by Phillychoi, May 23, 2020.
  1. Phillychoi
    Phillychoi Karting
    187
    Lansdale, PA
    Hey guys,
    How can I adjust height on stock springs? I heard it can be done. I want to lower a little bit. Is it similar to coilover adjustment? Stock springs on the adjustable perches like coilovers.
    Thanks in advance.
  2. Doc_Dent
    Doc_Dent Karting
    Mar 2, 2015
    215
    It can be done I guess -if I correctly understand UR question-.
    But may I ask Y would U want to do it in the first place?
    I mean the car is low already (with lifting kit off obviously:)).
    Don't 4get the car has a very powerful engine, and with all the aerodynamic stuff going on with the body, playing with height is not a great idea in my opinion.
    Plus, I guess doing so would void guarantees on the car in case of any future problems.
    I would highly recommend to think twice b4 deciding to get UR self into SMTH like that.
    TC...
    Phillychoi likes this.
  3. Romaihi
    Romaihi Rookie
    Apr 26, 2020
    35
    Qatar
    Hamad Al Romaihi
    I would recommend installing Novitec springs
    Rather than cutting OEM springs.
    I heard some installing TDF springs as well.
  4. Gh21631
    Gh21631 F1 Veteran
    9,078
    East
    I lowered mine on stock springs but if you have a lift you are limited on the adjustment. This is as far as you can go but it was enough for me.
    JPSMD and Phillychoi like this.
  5. Phillychoi
    Phillychoi Karting
    187
    Lansdale, PA
    The reason why I want to lower is that I just got 21/22" wheel set up and the fender gap seems more due to a lower profile tires. I don't want to slam with lowering springs just minor drop is all I want.
  6. Phillychoi
    Phillychoi Karting
    187
    Lansdale, PA
    Like I said above I don't want too low with Novitec springs. I just want to reduce the fender gap a little bit.
  7. Phillychoi
    Phillychoi Karting
    187
    Lansdale, PA
    That looks great. How much lower is that? I would be fine with that height. I don't have a lift system.
    Thanks for the pic!
  8. Gh21631
    Gh21631 F1 Veteran
    9,078
    East
    I dont recall the exact adjustment but I want to say about 1/2" in the front and the rear to balance it out.
  9. Phillychoi
    Phillychoi Karting
    187
    Lansdale, PA
    Ok thanks. Did you do alignment after that?
  10. Gh21631
    Gh21631 F1 Veteran
    9,078
    East
    Yes, thats highly recommended.
