355 - F355 / 355F1 Parts Thread | Page 5 | FerrariChat
355 F355 / 355F1 Parts Thread
Discussion in '348/355' started by CRAIGF355, Aug 7, 2011.
  1. jimmym
    jimmym Formula 3
    Sep 30, 2008
    1,995
    Northeast U.S.
    Jim
    The little light that is on the square key for a 1995 F355 can be sourced from BMW.
    Part number is 51 21 1 935 001. Cost is ~$6.95 from BAVAUTO.
  2. pnicholasen
    pnicholasen Formula 3
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    If you need a new ABS computer search Ebay for ATE E5LC-2C219-AA. Same unit, but for a Lincoln for about 1/1000th the price.
  3. cavlino
    cavlino Formula 3
    Mar 6, 2002
    1,740
    Ottawa, Canada
    Carm Scaffidi
    Nice find! :)
  4. saw1998
    saw1998 F1 Veteran
    Jun 8, 2008
    8,237
    San Antonio, Texas
    Scott
    I'll say!!!!! :)
  5. Intheflesh
    Intheflesh Formula 3
    Jun 2, 2006
    1,180
    Salem NH
    John T
    Hi there. Is there a 'generic' Air bag ECU or accelerometer?
    My air bag light has been on since day 1 of ownership. I've been told it is the ECU. recent service has confirmed this.
    More recently, my suspension light is on. I suspect the gears needed rebuilding, but was told that is not the case. The computer cannot communicate with the accelerometer, and it needs replacing.
    Any leads appreciated.
  6. ready321now
    ready321now Formula Junior
    Jan 5, 2013
    507
    New Jersey
    I will be buying these, since my bonnet seems to creep shut! Thank you!!!!! You just saved me $10,000 probably.
  7. ready321now
    Jan 5, 2013
    507
    New Jersey
    http://www.amazon.com/3M-Scotchprint-Carbon-Fiber-Vinyl/dp/B0058DIDTY
    Carbon-fiber wrap for door handles and other interior components. I test drove an F 355 that had these wrapped on the door handles (the handle to open the door, of course, from the interior). I thought it looked great. I am going to do this. Other parts can be wrapped, such as the climate control panel. I have the vector file for the stickers that go on the climate control panel. Email me and I will forward it to you.
  8. roadracer311
    roadracer311 Formula 3
    May 6, 2009
    2,398
    San Francisco
    Paul
    Radiator drain plugs $3.69 a pair! Mfg: Dorman. Part number: 902-404 (originals from Ricambi are ~$8 each, so the Dorman plugs aren't a huge savings in raw dollars, but percentage-wise more than 75% off and free shipping.
    Took a lot of searching to figure out the specs on these. I bought them as spares, in case I broke the originals when removing them, but then didn't break the original. So I haven't actually installed them, but I've got them in hand and they sure look to be the right fit M10 x 1.0mm
    Dorman 902-404 Bleeder Screw : Amazon.com : Automotive
  9. MAFIOSA
    MAFIOSA Rookie
    Oct 4, 2013
    46
    can anyone get me the part number for this i have heard this part matches many other types of vehicles.i have seen it listed on ebay,but i dont want to but the wrong item
    thanks
  10. WATSON
    WATSON Two Time F1 World Champ Owner Rossa Subscribed
    Sep 9, 2010
    24,081
    WI
  11. SoCal1
    SoCal1 F1 Veteran Owner
    Jun 14, 2011
    8,637
    SoCal LA/OC/New Mexico
    Tim Dee
  12. taz355
    taz355 F1 Veteran Owner Silver Subscribed
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
  13. bcwawright
    bcwawright F1 Veteran
    Jul 8, 2006
    5,234
    Georgia
    Bruce
  14. f355spider
    f355spider F1 World Champ Owner Rossa Subscribed
    May 29, 2001
    18,060
    I would have simply replaced them. These are a not too uncommon failure point on BMWs, which use a similar screw for bleeding air out of the system. They crack and fail from heat and age. There are companies that make them in brass specifically for the BMW application to eliminate the failure point.
  15. SoCal1
    Jun 14, 2011
    8,637
    Tim Dee
  16. marora88
    marora88 Rookie
    Aug 9, 2007
    17
    los angeles
    manoja rora
    Any idea on wear to get replacements parts for center console, door handles etc as mine are all sticky due to sun damage?
  17. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,970
    London
    Mark McCracken
    hi, loads of threads on this if you do a search. I sent mine to Robbie at Sticky No More - Exotic Cars Interior Refinishing Services
    1 week turn around from the Uk to the USA and back, perfect result.
    cheers
    Mark
  18. Badabing!
    Badabing! Formula Junior
    Mar 30, 2014
    731
    NYC
    There was a document on this board that listed all the interchange parts in one list.
    Anyone know where it went?
  19. tomw
    tomw Formula 3
    Feb 25, 2004
    2,413
    London
    Tom
  20. taz355
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
    Other options to regitar parts
    The O'Reilly part number for the regulator with lifetime warranty is 29-0188. Cost when I purchased it was $73.99. It's been on the car for 6 months, so, as I mentioned, I don't have long-term data yet.
    Also, wires to check are on the rotor, and if you pull the diode and look in the cage you can see them. This requires a qualified alternator shop to fix.
    If you buy the regulator and install it, have O'Reilly check the alternator before you install. They will ask you what alternator you're testing; just tell them it's from a 1991 Toyota Celica.
    Thanks to the outcast
  21. Badabing!
    Mar 30, 2014
    731
    NYC
  22. Badabing!
    Mar 30, 2014
    731
    NYC
    Air intake temp sensor
    Ferrari # 162419
    BOSCH Part # 0280130039 Temperature Sensor - Intake Air; Intake Air Temperature Sensor
    $16.38
  23. drbob101
    drbob101 F1 Rookie Owner Silver Subscribed
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
  24. taz355
    Feb 18, 2008
    6,059
    Indio Ca/ Alberta
    Grant
  25. mosierjr
    mosierjr Karting
    Sep 29, 2009
    154
    Texas USA
    J.R.
    This is great stuff, has anyone consolidated this into a single list like a nice PDF? Maybe I'll do it unless someone already has. -- J.R.
