F355 Fabspeed Secondary Cat Bypass Pipe (Y-Pipe) | FerrariChat
Discussion in '348/355' started by Fabspeed Motorsport, May 17, 2011.
  1. Fabspeed Motorsport
    Fabspeed Motorsport F1 Rookie Sponsor
    Feb 5, 2009
    3,158
    Fort Washington, PA
    Fabspeed Motorsport
    Hello Everyone,
    I wanted to offer special pricing on our F355 Y-Pipe for our FChat friends. We have adjusted the pricing between the 2.7 and the 5.2 (since the 5.2 pipe is a much more complex design/construction. In the photos below, the 2.7 pipes are straight where the 5.2 is curved.
    2.7 Special Price: $1049
    5.2 Special Price: $1449
    Highlights:
    -Fits all Ferrari F355 Berlinettas, GTS, & Spiders 1995-1999
    -Maxflo sports racing secondary catbypass replacement pipe for the stock dual cat pipe.
    -Fabspeed catbypass pipe is engineered with T304 stainless steel, C.N.C. mandrel bent tubing.
    -Simple and direct bolt on replacement.
    -Allows increased exhaust flow from the headers to the mufflers, improving power and sound.
    -Dual velocity merge collector, precision T.I.G. welded to replace stock cats.
    -Specify 2.7 or 5.2 Motronic
    Please let me know if you have any questions. Thanks!
    Jeff
    [email protected]
  2. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,737
    Written without any hint of malace towards the product portrayed::
    In what way is the merge collector able to deal with two different velocities?
    Are not the gas velocities from left and right banks essentially the same?
    How is a dual velocity merge collector different from a single velocity merge collector?
    That is: why is the name "dual velocity" merge collector?
  3. JohnsonsMedia
    JohnsonsMedia Formula Junior
    Sep 14, 2009
    254
    AZ
    do you have the power gains with this?
  4. cladd2000
    cladd2000 Formula Junior Silver Subscribed
    Jan 18, 2005
    519
    Yes, because your wallet is lighter.
  5. Fabspeed Motorsport
    Feb 5, 2009
    3,158
    Fort Washington, PA
    Fabspeed Motorsport
    Hello,
    The name dual-velocity merge collector is a bit wordy, huh? Basically, we wanted to point out that the two pipes aren't just crudely welded together like the factory piece. We use a cast merge collector that is similar to the ones we use on our headers to maximize airflow. The term "dual velocity" was used in the description before my time here, but I assume they are just refering to the fact that we are bringing the two banks together, and therefore, (slightly) different velocities. This is different from our header merge collectors which are just dealing with one bank each. Notice the picture below shows our merge collector before being polished versus the factory pipe (5.2). Please note that this is a prototype pipe and is different from our current 5.2 pipe, but the collector is the same.
    Yes, you will see power gains with this pipe since we remove the small secondary cats and improve airflow. The gains will be about 5-8 hp. Please let me know if there are any other questions.
    Jeff
    [email protected]
  6. Smyrna355Spider
    Smyrna355Spider F1 Rookie Owner Silver Subscribed
    Feb 9, 2008
    3,763
    In my Garage
    Scott
  7. UConn Husky
    UConn Husky F1 Rookie
    Nov 11, 2006
    4,425
    CT
    Jay
    Scott you stole my picture! :D or maybe it's just that mine look identical after similar mileage...actually I'm probably on 6k miles...with ceramic coating.
    I also agree it's good to get rid of those secondary cats, mine were getting blocked up and had signs of heat build up at the entry. The Fabspeeds are a great solution...or if you're really adventurous it could be a DIY removal, with lots of cutting welding.
  8. Fabspeed Motorsport
    Feb 5, 2009
    3,158
    Fort Washington, PA
    Fabspeed Motorsport
  9. jmbarba76
    jmbarba76 Formula Junior
    Sep 12, 2009
    408
    New Jersey
    Joe B
    Is it possible to get the stock secondary cat pipe out without removing the bumper and muffler? If so, please share. I have everything loose but don't seem to have the room to slip it out. I'm hoping the Fabspeed pipe will fit in better because of the smaller size.
  10. treedee3d
    treedee3d F1 Rookie
    Apr 1, 2011
    3,726
    Montreal
    Fab
    Love that quote, LMFAO!
  11. ruey220
    ruey220 Formula Junior Rossa Subscribed
    May 24, 2019
    316
    Sf bay area
    RM
    emailed directly if this is still available.
  12. Fabspeed Motorsport
    Feb 5, 2009
    3,158
    Fort Washington, PA
    Fabspeed Motorsport
    The secondary cat bypass pipes are still available. I would be glad to talk to you about them.
  13. jeffdavison
    jeffdavison F1 Rookie
    Jul 29, 2002
    2,544
    Suwanee Georgia
    Jeffrey Davison
    Still available? Thanks!
  14. ruey220
    May 24, 2019
    316
    Sf bay area
    RM
    Yes they are made to order. Just got mine delivered last week!
  15. jeffdavison
    Jul 29, 2002
    2,544
    Suwanee Georgia
    Jeffrey Davison
    same pricing?
  16. Fabspeed Motorsport
    Feb 5, 2009
    3,158
    Fort Washington, PA
    Fabspeed Motorsport
    Hey Jeff, I will shoot you a pm to talk about that.
