F355 HVAC ECU | Page 11 | FerrariChat
F355 HVAC ECU
Discussion in '348/355' started by baschul, Jun 28, 2016.
  1. WATSON
    23,685
    WI
    Do we know what the other 5 chips control? More curiosity than anything.
  2. Qavion
    Qavion F1 World Champ
    14,288
    Ian Riddell
    I'm not sure of the orientation of the HVAC ECU connector.
    Cedrik, if you're checking wiring at the HVAC ECU, can you confirm that the live battery power wire (brown) is in the top left hand corner of the yellow plug (as viewed from the socket side)
    It may be in any of the corners.
  3. Qavion
    14,288
    Ian Riddell
  4. Qavion
    14,288
    Ian Riddell
    WATSON likes this.
  5. WATSON
    23,685
    WI
    So:
    1 = unknown
    2 = Blower Fan Motor
    3 = Electric Water Pump
    4 = Re circulation Flap Motor
    5 = Air Distribution Motor
    6 = Heater Control Valve
    Any idea what chip #1 does?
  6. Qavion
    14,288
    Ian Riddell
    Not really. The chip seems to be associated with the control panel.
    The white ECU plug in @Zamboniman308 's diagram has pins labelled A thru M. The OEM wiring diagrams are labelled 1~13. Assuming A = 1, B = 2, etc, the H and I pins would correspond to OEM pins 8 and 9. These are hooked up to pins 4 and 5 on the HVAC control panel. They may have something to do with STOP/RECIRC control. I got some pretty strange results when I was carrying out resistance checks on pins 4 and 5. It wasn't clear what the signals represented.
    WATSON likes this.
  7. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,224
    CT
    John Kreskovsky
  8. Qavion
    14,288
    Ian Riddell
    All 6 ;)
    WATSON likes this.
  9. Qavion
    14,288
    Ian Riddell
    MAD828 and WATSON like this.
  10. gatekeeper
    gatekeeper Rookie
    Jun 8, 2021
    33
    Paul
    Hi,
    I'm going to attempt to replace the op amps on mine, but does anyone have any suggestions on how to remove the hard plastic like film which has been sprayed across the board? I'm tried isopropyl, but it doesn't lift it. I've tried with a screwdriver in the safe area on the bottom right of the photo and it comes off, but needs a gentle amount of force and clearly I can't do this on the main area of the board.
  11. Zamboniman308
    Zamboniman308 Formula Junior
    Feb 2, 2020
    504
    Chicago IL
    Try a little heat to soften. Its a messy process and takes awhile. I can't remember exactly how it went. You basically need to unsolder the chip. The cleanup is more of the area after you get it removed.
    Equipment that is really helpful is a soldering station for surface mount with hot air. I know i used traditional soldering iron to get the board all cleaned up along with some alcohol and hot air and paste to solder the replacement.
  12. johnk...
    Jun 11, 2004
    11,224
    CT
    John Kreskovsky
    Google PCB conformal coating removal. Lots of products for it. Depends on type of coating.
  13. brendon0
    brendon0 Formula Junior
    Dec 13, 2003
    611
    Tampa FL
    Brendon
    Send it to the guy I recommended earlier for doing thr chip replacement he only charged $100 if he is still doing it, sooo worth the money vs hassle.
    johnk... likes this.
  14. gatekeeper
    gatekeeper Rookie
    Jun 8, 2021
    33
    Paul
    Thanks. I've ordered a conformal coating remover pen and will give that a go on a safe area before trying around the chips.
    Unfortunately I'm based in the UK therefore shipping each way can be a pain, along with the re-import tax.
  15. johnk...
    Jun 11, 2004
    11,224
    CT
    John Kreskovsky
    look for a local electronics repair shop.
  16. gatekeeper
    gatekeeper Rookie
    Jun 8, 2021
    33
    Paul
  17. Qavion
    14,288
    Ian Riddell
    ShineKen likes this.
  18. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,566
    San Carlos, CA
    Mitchell Le
    I recently found a place called connectorexperts.com, they can see your pictures, measurements, and sell you pins, housing, and removal tools.
    WATSON likes this.
  19. gatekeeper
    gatekeeper Rookie
    Jun 8, 2021
    33
    Paul
    953736 does seem to be the one and I also can't find anyone that stocks it. I'll just have to modify a right-angled pin PCB one.
    Qavion likes this.
