F355 HVAC ECU | Page 4 | FerrariChat
F355 HVAC ECU
Discussion in '348/355' started by baschul, Jun 28, 2016.
  1. brendon0
    brendon0 Formula Junior
    Dec 13, 2003
    611
    Tampa FL
    Brendon
    Awesome.
    Can you share with us how you did the diagnostics on the temperature sensors? This
    is one step I did no complete and am curious how it is done.
  2. baschul
    baschul Karting
    May 27, 2015
    177
    Dallas, TX
    Brian S
    #77 baschul, Feb 24, 2017
    I used an ohm meter to test resistance based on the current temperature and the correct revised resistance when the temp was slightly elevated using a heat gun at a distance. The attached chart that shows the resistance for each sensor by temperature reading and was provided in another FChat thread by m.stojanovic.
  3. dr fabio del rio
    Dec 4, 2015
    18
    I have problems with the AC heater ECU fan comes on full with full heat I am rebuilding the ECU and replacing the bad TCA2465G power amp chips can anyone tell me what parts of the system are controlled by each of the 6 chips ? I saw a thread on this but it ran cold thanks your help is much appreciated
  4. Qavion
    Qavion F1 World Champ
    14,009
    Ian Riddell
    Are you saying the HVAC system always give you high heat and high fans speeds (even though you've selected cold)? Or are you saying the fan runs fast when you select higher temperatures only?
  5. Qavion
    14,009
    Ian Riddell
    Just wondering how you know it's the ECU. Have you tried a new one?
    Why would two driver chips fail? Wouldn't it more likely be a faulty CPU or one of the sensors sending false information to the ECU?
    3 of the 6 chips have been identified (see message #67 above):
    If you have the time (and your car is in pieces), can you find out which pin on the yellow plug corresponds to the ECU fan (speed) control output? If you can trace this to a chip, that will most likely be one of the chips you are looking for. According to the Workshop Manual (WSM), the fan speed command from the ECU goes to a pin labelled "6" on the Fan Power Control Unit (refer to the HVAC section in the WSM Volume 3, I-26. If you can match the wire colour on this pin 6 of the Fan Power Control Unit to the same colour wire going to one of the ECU pins, that will give you a good start. Note: Using Fig 6 of the Wiring Diagrams, I've narrowed it down to either pin 8 (purple/white wire) or pin 20 (purple wire). I can't pinpoint the exact pin number because I don't know if the WSM numbering system in the HVAC section (I-26) corresponds to the pin order in the wiring diagrams.
    In the following diagram, I've labelled the pins on the Fan Control Power Unit plug "B" (temporarily) "4, 5, 6", but I don't know if the colour sequence on the car is Black, Purple-White, Purple... or Black, Purple, Purple-White.
    http://www.members.iinet.net.au/[email protected]/FerrariF355Spider/Fig6_Cooling_Circuit_&_AC_System.gif
    Hope this helps
    Cheers
    Ian.
    Perhaps if someone has their luggage compartment in pieces at the moment, they could tell us the wire colour sequence on the Fan Control Power Unit?
  6. Qavion
    14,009
    Ian Riddell
    #81 Qavion, May 13, 2017
    If you can trace the fan control speed signal ECU yellow connector pin to a chip in the ECU, that will most likely be one of the chips you are looking for. According to the Workshop Manual (WSM), the fan speed command from the ECU goes from ECU yellow plug pin 20 to pin "6" on the Fan Power Control Unit (refer to the HVAC section in the WSM Volume 3, I-26). It's a purple wire.
    (EDIT) I previously wasn't sure of the pin order on the Fan Power Control Unit plugs, but I've confirmed that my diagram is correct by checking my car's wiring.
    Hope this helps
    Cheers
    Ian.
    P.S. I'm starting to wonder is the Fan Control Power Unit even needs a driver chip. The function of the Fan Control Power unit is to boost a weak signal from the ECU to one which will control the fan speed.
  7. Skiday
    Skiday Karting
    Feb 22, 2016
    111
    Isle of Wight, UK
    Andrew Day
    This sums up my situation exactly. I have my own thread here; https://www.ferrarichat.com/forum/threads/new-owner-with-ventilation-problem.514304/page-2
    Thank you for taking the time to put all this down. It is proving very helpful. It goes to show that car are just too damn clever for their own good these days! Anyway. I haven't found the chips so cheap, only for over £35 each, but located in London. So I'm getting one and replacing just chip No.6 and hope that works.
    Incidentally, you say that you tested the control unit. How did you do that? I've had mine open for a visual inspection and all looks good, but I can't be totally sure that it is (although everyone's problem seems to turn out to be the ecu chip). I wonder what is causing these chips to fail for so many people. There must be a weak link somewhere.
  8. Qavion
    14,009
    Ian Riddell
  9. cheungchoyui
    cheungchoyui Karting
    83
    Hong Kong
    Joe Cheung
    Did the chip solve your problem finally ?
  10. brendon0
    Dec 13, 2003
    611
    Tampa FL
    Brendon
    My ECU rebuild worked perfectly. All systems functional.
    Really you can test these with a voltmeter if you have the time.
  11. cheungchoyui
    83
    Hong Kong
    Joe Cheung
    Hi,
    Assuming I have taken out the ECU board , what are the procedures to test if the chip is bad by voltmeter ?
  12. Rifledriver
    36,866
    TUV requirement. When system fails it is supposed to default to that mode of operation for safety.
    Qavion likes this.
  13. brendon0
    Dec 13, 2003
    611
    Tampa FL
    Brendon
    I dont know how to test with the board out. I just had my guy replace all 6 chips.
    If the ECU is in, you can measure voltage at the motor connector levels.
    Qavion likes this.
  14. Shurik355
    Shurik355 Formula Junior
    May 19, 2013
    297
    USA Tulsa, OK
    Alex Velet
    So now Im in the situation of fixing my HVAC! :confused:
    Found out my drive boss for the flap is broke, and need fixing or replacing. My heater valve wasn't even plugged in for some reason when I got the car. (Just found out recently)
    Been reading these threads and trying to figure out as I go whats what. Might most likely replace the bad chips in the AC ECU as well.
    What exactly does that hidden AC 30amp fuse does??? its not blown but it was getting hot there that the plastic around it was melting.
  15. Qavion
    14,009
    Ian Riddell
    The 30 Amp fuse is basically for the heavy duty stuff, such as the fan motor (in the luggage compartment) and the aircon compressor clutch. Some voltage also goes to the HVAC ECU, but it may be only to let the ECU know there is power available (I'm not sure if it powers the ECU itself).
    If the fuseholder is melting, it might just be old age or a sign that the components are drawing too much power. Hopefully the former.
  16. Ricambi America
    Sponsor Owner
    drbob101, baschul, Shurik355 and 2 others like this.
  17. WATSON
    23,558
    WI
    Some of us have replaced that 30 amp fuse and holder with a bullet style holder/ fuse that does not melt the housing like the current design has a tendency to do.
  18. brendon0
    Dec 13, 2003
    611
    Tampa FL
    Brendon
    Hey Guys,
    I just went thru a nightmare fixing my HVAC again. The 30 amp fuse was blowing constantly. Eventually gave up and took
    it to exotic auto in Clearwater and Gabe got it sorted out.
    Turns out my blower motor had extremely high resistance so turning the fan to "4" would blow the fuse. Ended up having to pull
    the entire HVAC unit out and replace it with a used part.
    Once that was put in my compressor was not working. That was diagnosed as a short on the electro-magnet. Ended up replacing
    the whole compressor and dryer as well.
    Pumping out ice cold air now. Had the windows tinted too so the car is my daily in Florida from now on.
    They also replaced the main cable for the system and put in a heavier fuse holder so there is no more overheating.
    If you are getting alot of heat in the cable and fuse holder you have major resistance somewhere.
    baschul and Qavion like this.
  19. Ari Paul
    Ari Paul Rookie
    Sep 18, 2018
    34
    Ari Paul
    Hi! Where is the HVAC ECU located??!! I am trying to remove mine to fix it and I can't find location or instructions anywhere!
    Thanks.
  20. Qavion
    14,009
    Ian Riddell
    #95 Qavion, May 4, 2020
    It's in the forward luggage compartment. You have to remove the liner (carpet/felt) which sits in front of the windscreen. The ECU is mounted vertically to a metal bracket near one of the bonnet latches (I can't remember if there are variations between left hand drive and right hand drive cars so I won't specify the side it's on).
    You may find the windscreen wiper ECU ("intermittency unit") mounted in the same area.
    It may be easier to remove the mounting bracket than the ECU (?)
    I don't know if you've removed the luggage liner before, but you need to remove the rubber seal, the metal rub strips, the surround to the fresh air/blower motor assembly (4 screws), the fusebox cover (and its counterpart) and numerous screws holding that liner piece to the side pieces. On my car, it's a bit of a jigsaw puzzle and it helps if I remove the side pieces, noting that these pieces are rather fragile. Some folks can remove the windscreen section without doing this.
    Don't drop the screws for the fresh air inlet surround into the holes in the assembly as you may never find them again.
  21. Ari Paul
    Ari Paul Rookie
    Sep 18, 2018
    34
    Ari Paul
    Man, you're awesome! That was so helpful and so quick!
    Qavion likes this.
  22. Qavion
    14,009
    Ian Riddell
    You're welcome )
    Here's a photo of the ECU location on a LHD car (thanks to Eric).
    https://www.ferrarichat.com/forum/posts/137388399/
    I just used the F348/F355 Forum Search (searchwords HVAC, ECU, where) to find it.
  23. Ari Paul
    Ari Paul Rookie
    Sep 18, 2018
    34
    Ari Paul
    WATSON,
    Did you ever get your A/C working???
  24. Ari Paul
    Ari Paul Rookie
    Sep 18, 2018
    34
    Ari Paul
    Hi everyone:
    I can confirm that I too just did this HVAC ECU repair (replacing all 6 TCA2465G microchips) and my system now works!
    I was a bit skeptical when I first read about this online, but when I took it into my electronics repair guy, he looked up the factory specs of the chip and immediately said "oh, of course these chips went bad, they're amps!" Since I don't understand a thing about electronics I asked him to explain in simple terms. He explained that over time, based on the configuration of the chips, they will go bad due to heat cycles, especially since they didn't come with any heat sinks. He discovered that the manufacturer offers a heat-sink version of these chips (with metal fins on top) but speculated that Ferrari didn't put them on either because they weren't available at the time, or it was planned obsolescence...
    Anyway, I hope my experience helps anyone else who is on the fence about this.
    Illyria, Qavion and MAD828 like this.
  25. Qavion
    14,009
    Ian Riddell
    Looking at the datasheet for the chip, it looks like the ones with the heatsink have a different type of mount. I guess the repair guy fitted the standard ones?
