F355 major service | FerrariChat
F355 major service
Discussion in 'Technical Q&A' started by Mitch Alsup, Dec 22, 2003.
  1. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,404
    I got my F355 with 22K miles in June of 2001 at which time it had a 30K engine service., this december we are doing a major with 40K miles on the clock
    Why?
    Well, since the last major it has done 32 track events. As one who drives to the track, drives on the track, and drives home; reliability is paramount. But the car was giving all the signs it should be looked at.
    The first visible symptom was the characteristic whine at cold startup of tensioner bearings that are about to die.
    The second was missing oil.
    As we shall se in a couple of frames, it was good we got in there and took a look.
    This first picture is the drivers rear quarter of the engine.
  2. Mitch Alsup
    Nov 4, 2003
    9,404
    The drivers front
    Dave is holding a water hose that is about to fail.
  3. Mitch Alsup
    Nov 4, 2003
    9,404
    passenger fromt
  4. Mitch Alsup
    Nov 4, 2003
    9,404
    Passenger rear
  5. Mitch Alsup
    Nov 4, 2003
    9,404
    As long as the engine was going to be out anyway, might as well return it to a state of clenliness.
  6. Mitch Alsup
    Nov 4, 2003
    9,404
    drivers rear
  7. Mitch Alsup
    Nov 4, 2003
    9,404
    passenger front
    The long oil hose hanging down is suspected of having a slow pressure leak.
  8. Mitch Alsup
    Nov 4, 2003
    9,404
    passenger rear
  9. Mitch Alsup
    Nov 4, 2003
    9,404
    transmission area
  10. Mitch Alsup
    Nov 4, 2003
    9,404
  11. Mitch Alsup
    Nov 4, 2003
    9,404
    Front of engine
  12. jeffdavison
    jeffdavison F1 Rookie
    2,544
    Suwanee Georgia
    Jeffrey Davison
    Mitch,
    Who's doing the service? What do you think the final ammount will come to?
    Just want to prepare for the inevitable on my 355 (probably early '05)
    Jeff Davison
  13. vref
    vref Karting
    Dec 18, 2003
    214
    1 Hr North of Housto
    Jim
    fantastic pictures! you can really see how the engine comes out of the car with the suspension and all. Do you have any of the engine compartment of the car?
    Could you get to that bad hose without pulling the engine or was it buried in the firewall?
  14. f355spider
    f355spider F1 World Champ
    17,974
    Mitch,
    Nice documentation, and appreciate your sharing this great information. Can you describe how you cleaned the engine? What products? Pressure washer?
  15. Mitch Alsup
    Nov 4, 2003
    9,404
    I used simple green as a solvent/detergent and water (and compressed air to blow dry). 90% was done with a parts brush and 10% with a tooth brush.
    More pictures will be forthcomming as this process transpires.
  16. Mitch Alsup
    Nov 4, 2003
    9,404
    The hose was where the overflow container is plumbed into the main water lines. You might have been able to get at it with the engine in the car, but you would have had to at least pull the bonnet, and perform the repair lying on the top of the engine.
    But the crack was so small, you would have not been there to take the look, and anything less than excellent dilligence would have missed the hose.
  17. titanium360
    titanium360 F1 Rookie
    3,446
    what is the cost of major service on the 355?
  18. Mitch Alsup
    Nov 4, 2003
    9,404
    Well, today, we found 2 more water hoses that are ready to die, I got a picture of one, but left the camera at the service bay. I decided to replace all water hoses. This decision will cause me to have access to the interior bay between the cylinder banks, so I can continue cleaning up the engine to a pritine state.
    Instead of 2 tensioner bearings having gone south, we have 2 original tensioner bearings (both original) one bad, one ok--both will be replaced. We know the tensioners are original because the spacing of the holes for the tensioning fork is different on the upgraded bearings. The belts look fine, but the tensioning bearings had to be replaced of face major trouble. The cams were within 1 degree of dead nuts on, we will set with a dial indicator tomarrow.
    The other bearing that is kaput is the alternator idler bearing.
    More as data arrives...
  19. vref
    vref Karting
    Dec 18, 2003
    214
    Jim
    Sounds like progress. would you upload a pic of the car without the engine in it (engine compartment), be cool to see what it looks like?
  20. nart2222
    nart2222 Rookie
    Nov 28, 2003
    46
    are you going to replace your valve guides while the engine is out or has it already been done?
    N
  21. ze_shark
    ze_shark Formula 3
    Jul 13, 2003
    1,274
    Switzerland (NW)
    Hi Mitch,
    Intersted in this whine at cold startup, my car is doing something that appears similar, happens only at idle for the first minute the engine is on, a high pitch noise. Which tensioner is that and can it be replaced without taking the engine out ?
    Tks, JC
  22. Mitch Alsup
    Nov 4, 2003
    9,404
    A picture of another hose burried in the bay:
  23. Mitch Alsup
    Nov 4, 2003
    9,404
    On the right is a heat shield that has seen better days; Ferrari wanted $1200, an importer wanted $850; I mocked it up out of $25 worth of parts and 2 hours of my labor (e.g. $0). The aluminum frame was covered with a heat shielding fabric high temp silicone glue and pop rivits.
  24. Mitch Alsup
    Nov 4, 2003
    9,404
    A look at the engine bay
  25. Mitch Alsup
    Nov 4, 2003
    9,404
    And a look at why these engines breath so well. You are looking down the intake manifold. The throttle body at the top at WOT you can see the back sides of all three valves. The intake has a nice rough finish from machining and casting, and narry a port face needs the smallest matching.
