F355 spider roof stops halfway down | FerrariChat
Discussion in '348/355' started by minimadtan, May 15, 2019.
  1. minimadtan
    minimadtan Rookie
    Jan 30, 2019
    2
    Hi I’m having trouble lowering my f355spider roof seats move forward with switch roof starts to fold and seams to stop after a few inches car is new to me so am I doing something wrong many thanks
  2. 355OXO
    355OXO Karting
    Apr 16, 2006
    204
    Simon
    Has the bar attached to the elastic straps got in the wrong position. happens when the elastic has become stretched. This can stop roof opening.
  3. Qavion
    Qavion F1 World Champ
    14,275
    Ian Riddell
    #3 Qavion, May 15, 2019
    Grab some popcorn....
    https://www.ferrarichat.com/forum/posts/146423577/
    or skip ahead to the 10 minute mark.
    The straps, although not available to purchase, can be made relatively easy. You just have to know the original dimensions (Yours has probably stretched a little). In the meantime, the crossbars can be easily manipulated into the right position, then the roof operation will continue normally.
  4. WATSON
    23,683
    WI
    Help the overhead cross bar back as the top opens. It will catch and stop the top operation if the elastic has expired.
    If you continue to force it, it will tweak the frame and then the alignment forks won't engage when you put the top back up.
  5. deeej84
    deeej84 Karting
    Jun 9, 2013
    64
    Sylvan Lake, Alberta
    Dustin Johnston
    There's a window switch that needs to activate to lower the windows slightly before the roof lowers as well, so check that. If this is malfunctioning, the top won't go down.
  6. Qavion
    14,275
    Ian Riddell
    The seats wouldn't move forward if the windows didn't go down. Also, the original poster said his top started moving ;)
    It's the straps.
    Minimadtan, make sure this bar is in the right position (up).
    F355 Convertible Top Manual Conversion Help
    Note the elastic straps attached to it.
  7. Enzojr
    Enzojr F1 World Champ
    Dec 12, 2013
    14,001
    West of PDX
    Tomy
    This is what mine did, the first bar back flipped the wrong way and stopped everything half way.
    New elastic straps will fix this.
    You can make them or just find some with Velcro on them.
    Adjust as necessary to get the crossbar pulled in the right direction.
  8. Qavion
    14,275
    Ian Riddell
    #8 Qavion, May 15, 2019
  9. minimadtan
    minimadtan Rookie
    Jan 30, 2019
    2
    Thanks for all your help it was the straps and bar
    Qavion likes this.
  10. hsd635
    hsd635 Rookie
    Jan 13, 2008
    10
    Brum, England
    Hugo
    Hi Does anyone know where I can buy these elastic straps from or the instructions on how to make them.
    thanks
  11. Qavion
    14,275
    Ian Riddell
    #11 Qavion, Jan 9, 2022
    I don't think anyone on the forum has offered these recently. You may be lucky and find your local independent Ferrari tech has some spare "home made" ones.
    I would just copy the old ones (but make them half as short, depending on how much the old ones have stretched and how strong the new elastic is). Just get a seamstress/tailor to sew them up for you.
    I found some "heavy duty" elastic (3/4 inch) and tried to use press studs instead of sewing the loops on the ends, but it took a lot of experimentation and didn't look very professional. Note that you can use something like a soldering iron to stop the ends fraying.
    @drbob101 's versions looked better:
    https://www.ferrarichat.com/forum/threads/f355-spider-elastics-for-converticle-top.492984/
    Haven't seen him around recently, though.
